Galaxy Nexus - ZenSERIES [JB][Linaro] **Entwicklung eingestellt** [Kernel]Dieses Thema wurde im Galaxy Nexus Forum geschrieben. Solltest Du auch Probleme oder Lösungen zu diesem Thema haben, so nimm doch einfach an der Diskussion teil. |
#1 | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
![]() ![]() Features: Build Infos
Verfügbare Takte
verfügbare Governors
verfügbare Schedulers
zusätzliche Features
![]() Downloads: Android 4.1.x
Android 4.2.x
![]() Entwickler: androiddeveloperalliance (http://androiddeveloperalliance.org/) Original Kernel Thread: http://forum.xda-developers.com/show....php?t=1958143 Geändert von freedroid (16.01.2013 um 20:20 Uhr) |
#2 |
Changelog:
Code:
ZenSERIES_v17
- v3.0.58
- More sysctl tweaks.
- Misc. fixes (anarkia/imoseyon)
- Interactive+ZenX upstream updates
- ZenX updated from v2.1-v2.2 (re-worked a lot of hotplugging handling in the timer, other improvements.
- see https://github.com/AndroidDeveloperAlliance/ZenKernel_TUNA/commit/32e1f3ff8b62a4214949295d639bc6b5c852079d for details)
ZenSERIES_v16
- Rebased the tree for sanity and to fix a bunch of slop bugs.
- Several cleanups and misc. fixes.
- Added ROW I/O scheduler and made it default.
- Updated ZenX to v2.1 (code improvements, infinite CPU support)
- More block layer updates
- Sysctl tweaks
- Some more wifi updates
ZenSERIES_v15
- Updated to v3.0.57
- Some arm v7 updates
- Multiple interactive governor updates
- Zen I/O scheduler bug fix in add_request
- WiFi bcmdhd: merge in a couple wakelock fixes
- Cleaned up zip template and scripts.
- Replaced 192MHz and 230Mhz with 218.88MHz frequency.
- ZenX v2:
- Complete Rewrite
- Hot(un)plug logic is now determined on the per-CPU timers.
- Hot(un)plug logic performance improvement is substantial over ZenX v1.
- Eliminated racy calling of the hotplug workqueue.
- Support up to 8 CPUs (unplug_load_cpu3 replaced with unplug_load_cpumore, which is for CPUs 3-7)
- Actual cpu_up and cpu_down work is performed in separate workqueues that play mostly dumb (does exactly what the timer tells them to do)
- Removed insert_delay and unplug_delay
- Implemented hot_remove_sampling_periods and hot_add_sampling_periods.
- Now if average CPU load after hot_add_sampling_periods is > unplug_delay_cpu{#} the CPU will be removed. 20 sampling periods should be about a ~400 millisecond delay before adding a CPU.
- Now if average CPU load after hot_remove_sampling_periods is <= unplug_delay_cpu{#} the CPU will be removed. 20 sampling periods should be about a ~400 millisecond delay before removing a CPU.
- Use a longer-term load calculation for hot(un)plugging.
- ZenX will tune certain values on suspend for power savings and revert them on wake (go_hispeed_load, timer_rate, hot_add/remove_sampling_periods).
- ZenX sends a boost pulse on device wakeup (target higher frequency for a short time/80ms default)
ZenSERIES_v14.1
- ZenX SoD Hotfix
- Multiple misc. wifi fixes
- Some other misc. fixes, a couple scheduler fixes backported to v3.0 by faux
- Some more adjustments to the lower-end voltages/margins. One of the mid-higher range voltage steps was wrong
- Several improvements in the kernel config.
- Fix some scripting issues, typo in sysctl.conf, don't rely on the sysctl binary to set sysctl values*
- Many roms don't have it, helps with permissions for min/max/governor, and other misc*
- Deprecated zeneractive
- Added ZenX (zeneractive v2)
- Fixed rare SoD (phone alive & accessible, but perm. suspended state) bug that was present on zeneractive
- The hackiness of total_below/above_unplug_time arrays got the axe. Now we actually set and use the data set on each CPU as we should have all along.
- Ditto last_time_above/below_unplug_time
- We now calculate the average load across _all_ ONLINE CPUs instead of using the potentially incorrect current CPU load
- On device wakeup, all cores are forced to wake up
- XXX Quirk! If you are on pegasusq/hotplug/ZenX and you change governor to a non-X gov including*
- Ondemand/interactive/intellidemand/performance/adaptive/conservative* _while your second core is OFF_, it will never re-enable itself
- This only applies if you change your governor while the core is removed
- Workaround: I added a helper script, so, as root, you can just run "set_core_online" to manually re-up your CPU (you only have to do this once)
- This is a pretty rare case, and if your governor is set on boot - this won't affect you anyway!
ZenSERIES_v13
- Updated to v3.0.56 upstream
- SoD work, Adjusted SR margins and voltages
- Replaced glados' color control with the CM/voodoo color control port
- Re-added some SR updates that were lost in v12
- Added some misc. updates/some from android-3.4
- Interactive upstream updates
- Decreased 512MHz GPU voltage slightly
- Zeneractive: upstream updates, also added tracing, boost, and boostpulse
- Zeneractive: Re-introduce set_speed_mutex*
- Prevents hotplugging from occuring while frequency scaling occurs*
ZenSERIES_v12
- Updated to v3.0.55
- Rebased the whole kernel tree to clean up
- Updated bcmdhd+ipv4 with some upstream fixes/wakelock related
- Disabled merging on deadline and no-op
- Added in some more TCP congestion schedulers (cubic still default)
- Some misc. updates - More SoD Actions taken
- Replaced interactiveX with "Zeneractive." (documentation: http://pastebin.com/UrkEke8k)
- Interactive-based governor with "live" CPU hot plugging.
- Behavior on Zeneractive with Great Battery:
- If CPU load is <= unplug_load[cpu] for a given CPU for time = unplug_delay, that CPU will be removed (if online)
- If CPU load is > unplug_load[cpu] for a given CPU for time = insert_delay, that CPU will be inserted (if offline)
- Tunables: unplug_load_cpu1 (default: 25%), unplug_load_cpu2 (default: 60%), unplug_load_cpu3
- Zeneractive (default : 75%), unplug_delay (default: 5s), insert_delay (default: 30ms)
ZenSERIES_v11
- Reverted some DSS+OPP & SR adjustments (May fix SoD some users are experiencing)
- Raised default screen_off_freq to 729.6MHz
- Added 512MHz GPU clock setting (512 in progress for some users)
- Available GPU options are 307/384/512 (384 still default)
- Re-did ondemandX (suspend/wake code + CPU hot plugging)
- Added adaptiveX governor, adaptive with suspend/wake code + CPU hot plugging
- Added intellidemandX governor, intellidemand with suspend/wake code + CPU hot plugging
- New list of governors with early suspend/wake/hotplugging*
- InteractiveX, pegasusq, adaptiveX, ondemandX, intellidemandX
- 4.0/4.1 kernels will progress maybe another few builds for stability
ZenSERIES_v10
- Hotfixes for Maximum Stability
- Two Versions
- ZenSERIES 4.1
- ZenSERIES 4.2
- Fixed PGM support
- New Adaptive Governor by Samsung
- Fixed Tethering & WEP by reverting back to 3.0 wifi drivers
- NEW modified version of imoseyons sysfs for GPU UC/OC @307/384*
- GPU OC changes live using TricksterMOD to clock GPU's* - 512 will show but Currently Inactive
- Reverted to the latest Interactive/InteractiveX with the proper scaling fixes
- Fixed apps setting min/max frequencies sticking upon reboot for some users
- ZenSERIES 4.1 Fil Updated Build Changelog:
- All of v9/v10 major changes below are included - Exeption is different bluetooth drivers
- Enjoy!
ZenSERIES_v9
- Updated to v3.0.53 Latest Upstream Google Source
- Added in some additional omap-specific fixes
- Pulled in the core block layer from axboe/linux-block.git up to 3.3. Includes the following:
- http://git.kernel.org/?p=linux/kernel/git/axboe/linux-block.git;a=shortlog;h=refs/heads/for-3.1/core
- http://git.kernel.org/?p=linux/kernel/git/axboe/linux-block.git;a=shortlog;h=refs/heads/for-3.1/drivers
- http://git.kernel.org/?p=linux/kernel/git/axboe/linux-block.git;a=shortlog;h=refs/heads/for-3.2/core
- http://git.kernel.org/?p=linux/kernel/git/axboe/linux-block.git;a=shortlog;h=refs/heads/for-3.3/core
- Updated BFQ to for-3.3 version to reflect it
- SOD issues should now be fixed
- Added FIOPS v2 I/O scheduler
- Added logic to cpufreq_set_policy so it only sets policies with a valid min/max frequency*
- Vs any min/max frequency within the range*
- Adjusted Ondemand/OndemandX/Intellidemand/Pegasusq settings
- Updated wifi drivers to 3.4 ones
- Enabled frontswap and cleancache
- Added script to apply some fstab tweaks to current roms ramdisk (mount with noatime+disable barriers)
- Applied zRam updates
- Added ZRAM_FOR_ANDROID (Optimizes zram for android, adds bits to zram+lowmemorykiller)
ZenSERIES_v8
- Two Versions
- Final ZenSERIES 4.1 build
- Ongoing support for ZenSERIES 4.2
- Updated Base to 3.0.52 Latest Upstream Google Source
- Fixed deep sleep on 4.2 ROMS
- More core build optimizations
- Updates from the android-3.0 tree
- More conservative default cache_pressure
ZenSERIES_v7
- Now should be Compatible with 4.0/4.1/4.2 ROMS
- Merged in latest 4.2 Source tuna+omap updates
- Revert to using stock ramdisk for capability
- Pegasusq tweaks, some suggestions from EniGmA1987
- Set CPU_DOWN_FREQ to cpu frequency policy minimum on pegausq
- Set sysctl values via script, overrides anything set by ROMS Ramdisk initially
- To remove, rm /system/bin/set_zen_sysctl and /system/etc/init.d/99ZenKernel
- Deep Sleeping was more ROM Related vs Kernel - v7 has worked on our end
- Fixed Zram & CPU Sticking
ZenSERIES_v6
- Added a New Custom Ramdisk Rewritten with Zen settings
- Ramdisk originally pulled and modified from leanKernel
- Sysctl settings won't be overridden by rom's default ramdisk now
- This should fix any lag/idle slowdowns that were minutely present
- Modified CPU scheduler settings
- Modified sysctl settings for the "Zen-Tune" branch settings
- Now matches what is set by the ramdisk just for easier reference
- More upstream lowmemorykiller updates
- Updated Interactive & InteractiveX using latest upstream from android common
- Added Brand New 4.2 Ramdisk by Google's Kernel Source *Testing Phase*
ZenSERIES_v5
- Rebased Entire Kernel - Cleaned up all code in source
- More sysctl tweaks, min_free_kbytes is now at ~4Mb by default
- Added OndemandX Governor
- Added ZRAM Support
- Fixed OC issues for some users by enabling trim quirks
- Updated lowmemorykiller to latest from ~3.6
- Updated OPP driver to latest from ~3.6
- Adjusted intellidemand default settings to match our ondemand ones
- Some omap DSS fixes
- Reduced android logger ram usage (dorimanx)
- More accurate nohz load accounting (dorimanx)
- More tweaks by default
- Dirty_expired_centisecs -> 200, vm_dirty_background_ratio - >
- 60, sched_nr_latency -> 10, sched_min_granularity ->
- .4msec, sched_latency -> 3ms
ZenSERIES_v4
- Breaking Ground *Serious Kernel Power*
- Built with a more vanilla crosstool-built gcc 4.7.2 instead of Linaro*
- Should solve affected Chrome users & any remaining boot issues*
- Fixed 384MHz Maximum GPU Frequency
- Updated to v3.0.51
- Adjusted CFLAGS
- Raised default vfs_cache_pressure from 20->30
- Re-added some incidentally removed PM updates
- Lowered fifo_batch to 1 on deadline/SIO/zen/V(R) as it may be most desirable for flash memory
- Set cpu transition latency back to 30ms
- Slightly increased voltages for 1.4-1.7~GHz frequencies
- Proprotional rate reduction for TCP
- Westwood as default TCP congestion scheduler
- Thalamus' updated target residencies
- Zen I/O scheduler is now default
- A couple cleanups to Zen I/O
- Adjusted default lowmemorykiller minfree, for min ~80Mb.
- 2048/3072/6144/15360/17920/20480
ZenSERIES_v3.1
-Added cleaner.sh script to zip template & runs in the updater-script
-Thoroughly cleans any & all remaining kernel scripts
-Should fix issues for users who can't boot the kernel
-Added Zen Info sysfs interface for future usage
- Latest Upstream v3.0.50
- Added back in screenoff_maxfrequency support*
- *Defaults to 576MHz - Should solve wakelocks/wake issues
- Removed rev_penalty even though it's the main feature of VR
- Also removed logic based on choosing request *
- *Depending on head because our phones don't have spinning hard drives.
- Added +10mV to 192/230Mhz frequencies
- Reverted some memory patches that were problematic
- Added "Zen" I/O scheduler.
* Based primarily off of no-op, but also VR. Very similar to SIO.
* Primarily FCFS, dispatches back-inserted, deadlines ensure fairness between requests.
* Synchronous requests chosen over asynchronous ones
* Even simpler than the "Simple I/O scheduler"
Geändert von freedroid (16.01.2013 um 20:18 Uhr) |
#3 |
ich hatte den Kernel vor ein paar Tagen mal am laufen. War nicht sonderlich zufrieden. Hatte auch zwei unfreiwillige Reboots, was sonst fast noch nie bei mir vorkam. |
#4 |
Ich hab ihn seit letzter Woche mit einem Neuflash von rasbean drauf. Läuft bei mit super.
Deshalb dachte ich, ich will den der Community nicht vorenthalten
#5 |
Vielleicht teste ich nochmal eine neue Version
![]() Welche Vergleiche kannst du zum Trinity ziehen? |
#6 |
Bei mir läuft der wirklich gut. Mir kommt es so vor, als ob er sogar einen Tick flotter läuft als der Trinity A67.
#7 |
Update auf ZenSeries v3.1 erschienen
Download siehe Post #1 Changelog siehe Post #2 |
#8 |
Probiere ich mal aus
#9 |
Falls es jemand interessiert hier mal ein paar Einstellungen für den Kernel, die bei mir super sind.
Eingestellt mit Trinity Toolbox CPU: Min. Takt: 384 MHz Max Takt: 1230 MHz Governor: pegasusq Scheduler: Deadline Farben: Kontrast: -10 Farb Multiplikatoren: Rot 140, Grün 140, Blau 195 |
#10 |
Hab ähnlich eingestellt. Schauen wir mal was der Kernel leistet.
| eingestellt, entwicklung, galaxy, jb linaro, jb linaro oc uv, nexus, zenseries |
| [Custom-Rom] Samsung Galaxy Note II - CarbonRom JB 4.2.2 [AOSP][LINARO] | andreas02 | Galaxy Note 2 - Custom Roms | 8 | 30.03.2013 08:29 |
| Samsung Galaxy Nexus I9250/Google Nexus/OVP/Schutzhülle/Garantie | markuese | Samsung Anzeigen | 1 | 30.10.2012 15:40 |
| Galaxy S I9000 - Bei 100% automatisch Akkuladen eingestellt | shocker619 | Samsung i9000 Galaxy S Forum | 8 | 20.09.2011 20:26 |
| link Petition zur Entwicklung Entwicklung der FRITZ!App Fon für Bada | maternus12 | Samsung S8500 Wave Forum | 7 | 07.07.2011 23:47 |
| Werden Wave und Galaxy S eingestellt ? | Gummybär | Samsung S8500 Wave Forum | 34 | 06.10.2010 23:27 |
