manule
[Leaked JB Firmware] I9300XXUFME7 (4.2.2) - ODIN Firmware [21-06-13]
New enhancements in Android 4.2.2 update
- Android 4.2.2 - Build ID: JDQ39
- New S4 Lockscreen: Multiple Widgets, two Unlock effects (Ripple and Light), improved ripple effect than Android 4.1.2, ability to change clock size and set a personal message
- New Screen modes (From S4): Adapt Display and Professional Photo
- Daydream
- Driving mode
- Actionable notifications
- New Additions in Notification Center
- Completely revamped Settings UI (Tabbed interface - Exactly like the S4)
- Addition of Voice controls (Let’s you control various parts of the phone using voice commands - Galaxy S4 feature)
- Gallery modes have white background (When changing gallery modes to 3D the background changes to white)
- Full screen Samsung apps
- New S-Voice (from S4)
- New smart switch widget
- Found more? Tell us about them in the comments below!
WARNINGS
- This is a PRE-RELEASE firmware and is not officially released by Samsung.
- This is just like any official firmware, it DOESN'T increase the binary counter nor changes the system state.
Firmware Details
Android Version: 4.2.2 - JDQ39 (Jelly Bean)
PDA: I9300XXUFME7
CSC: I9300OXAFME7
MODEM: I9300XXUFME7
Region: Open Europe
Carrier: Unbranded
Changelist: 702147
Build Date: 21 May 2013
Download: I9300XXUFME7_I9300OXAFME7_OXA.zip
Flashing Instructions
- Unzip the file
- Open Odin 3.04 (already included in the firmware package)
- Restart phone in download mode (Press and hold Home + Power + Volume down buttons)
- Connect phone and wait until you get a blue sign in Odin
- Add I9300XXUFME7_I9300OXAFME7_I9300XXUFME7_HOME.tar.md 5 to PDA
- Make sure re-partition is NOT ticked
- Start flash, sit back and wait a few minutes.
- If you encounter any issues with the firmware (Any FC, Bootloop etc)
- Boot into recovery mode (Home+power+vol up)
- Choose to wipe/factory reset. (THIS WILL ERASE ALL OF YOUR DATA INCLUDING YOUR INTERNAL SD CARD!)
- Then choose reboot and you should be good to go!
wie immer übernemhme keine haftung für falsches flashen ode rumgang das zu defekt eures handy bringt
hm habs vorhin raufgemacht I9300XXUFME7 alles paletti.....in deutsch hmmmm...
