cojo
LG Optimus Speed - Ghostrider goes ICS 4.0.4 [Aromainstaller]
so,1 Download ist fertig,es folgt noch nen Mirror!!!
Viel spass
Sauber:danke:
bin gerade am saugen, werde später mal berichten
Nur denk dran,wenn Rom Bugs auftauchen,die haben nichts damit zu tun!! Aroma ist halt nur ne Installationsroutine
Mal abgesehen vom aromainstaller ist das dieselbe ROM wie Stefans deodexed?
jepp,hab ich aber auch in Post 1 geschrieben
ich weiß es ist immer so ne sache aber welches BB/RIL läuft mit 28g besser?
die von 28e oder g?
kann ich dir auch nicht sagen,hab mich mal auf nen kommentar von Stefan bezogen und 20e Ril genommen
Small heads up regarding battery drain on v28G
I found out the reason for the higher battery drain some people noticed @v28G: It is the power consumption of WIFI that drains the battery quickly. (Maybe also phone network connection in general drains it, I just noticed WIFI draining because I had it permanently on.)
I'm on deodexed version of v28G.
4 possible causes:
- deodexing introduced some wifi bug that leads to high drain when using wifi (unlikely)
- the RIL of v28G drains the battery when using WIFI or phone network much quicker than the v28E RIL (plausible)
- the wifi module of v28G kernel or v28G kernel itself draining battery faster than v28E equivalents when using WIFI (plausible)
- something else in v28G ROM causes it (unlikely)
So for finding out what causes drainage under v28G I ask you to do the following:
compare battery drains between v28G non-deodexed and v28G deodexed version
try to use v28E RIL on v28G (I made a flashable CWM ZIP, available in my download folder)
try to use v28E kernel on v28G (I made a flashable CWM ZIP, available in my download folder)
I'm looking foward to receiving a couple of reports from you guys over the next days! We need to figure out the reason for the higher drain.
For now I've switched myself to v28E kernel and v28E RIL to see if it gets better. But I recommend you only to try one change at a time because if you change two things at once you don't know which of the two is responsible for again better battery.
oje... trial and error! ich habs mir fast gedacht.
kannst du mir vielleicht erklären wieso die eingabe, egal was etwas verzögert reagiert?
das einzige was echt schnell und direkt ist wenn ich die apps öffne.
das scrollen im einstellungsmenü ist sehr verzögert.
ich habe auch einen fehler entdeckt.
selbst wenn im aroma lgemail drin bleibt meldet mir das handy,das der prozess beendet wird.
habe erst mal wieder das backup zurück gespielt.
aber ansonsten gute arbeit!!! :-)
grüsse
@all
Nochmal,Das ist eine Installationsroutine!!!
Die eigentlich Rom ist wie in Post 1 beschrieben die von Stefan.
Aroma hat absolut NICHTS mit der Rom zu tun
Man sollte nach der Installation warten bis die SD KArte gescannt ist,währenddessen hakelt es natürlich
bearbeitet von cojo
@Opi-Power
Habs mir eben selber nochmal neu komplett neu installiert,LG Mail läuft bei mir ohne probleme
vieleicht lag der fehler auch bei mir.
beim p990 ist nichts ausgeschlossen.
grüße
Jetzt habe ich es nochmal probiert und jetzt geht es. Ich finde die akku % anzeige nicht mehr. Wo ist die nochmal?
Die Installation verlief reibungslos, so muss es sein…
Endlich ist die Crap weg, als Bootanimation habe ich CIA genommen:cool:
ansonsten ist alles so wie vor dem flashen ausgewählt.
Einstellungen/Energieverwaltung
suuuper thx.
grüße
Erste AROMA Version, sehr schön :respekt:
Solltest du auf XDA auch anbieten!
Je mehr Custom ROMs für den neuen Bootloader und die neue Partitionierung in Umlauf kommen, desto besser. Damit sich beide etablieren.
Wer seinen Bootloader upgraden möchte (betrifft jene, die nicht mit Smartflash verbinden können) und statt CWM 5 mit großer Schrift lieber CWM 6 mit normaler Schrift haben möchte, der kann sich meine neue NVFlash Version installieren:
http://d-h.st/PNj
Um ohne Datenverlust wieder auf Cojos ROM zurück zu kommen:
  • bei NVFlash Version auswählen, dass man /data Partition sichern möchte
  • später auswählen, dass man /data Partition wiederherstellen möchte
  • nach dem Wiederherstellen direkt ins CWM 6 booten. Cojos ROM wieder installieren (ohne Full-Wipe)
Alternativ kann eventuell auch einfach ein CWM5 Backup mit CWM6 wieder eingespielt werden. Einfach probieren. Backup nicht auf der internen SD lagern, weil die durch NVFlash gelöscht wird.
bearbeitet von Stefan Gündhör
Frage: Kann es zu Problemen kommen wenn ich mein Backup meines CyanogenMod7 wiederherstellen will?
Gibt es bei dieser ROM Probleme beim Telefonieren?
Gruß Matze
bei der LG ICS gibts absolut keine telefon probleme.
Hab noch nie nen Backup von CM7 auf Stock gemacht,ich persönlich bin für eine komplette neuinstallation,ist in meine Augen das sauberste.
Machs doch so,installier dir Rom,leg direkt ein Backup mit CWM an und versuch einfach,wenns schief geht stellst das backup wieder her.
Denke aber dran,du musst erst den neuen Bootkernel flashen,git ja genug anleitungen hier.
Gruß Matze
Null Problemo mit Titanium Backup (meinst du doch?)
habe selbst 70 App's zurückgespielt,und schon viele ausprobiert,
Alles bestens.
Edit:
Sry,ich habe deine Frage Falsch interpretiert
