Shurkien
Shurkien
[COLOR="SeaGreen"][B]Changelog Rom[/B][/COLOR]
RC19-35
Fixed browser rotation bug
Fixed brightness bug after reboot
Fixed Signal loss after WIFI
New Recent Apps layout
PDroid Support
Update SuperNova to RC1-R
Removed 2 fonts
Remove Harsh Kernel
RC18-31
Updated Harsh Kernel to Build-3003
Updated Apex Launcher to v1.0.4
Updated Flash Player to the latest available
Set Nova HD as default boot animation
Removed New Nova HD boot animation
Removed 0622 RIL option
New Splash Screen
RC17-30
Updated HP Kernel to Test Build2
Updated Harsh Kernel to Build-2703-1
Removed 3G tweaks to save more juice
Deleted the DPI change wizard
Fixed beam animation on and off working
Added Custom Font Option
RC16-29
Updated SuperNova to RC 1
Updated Harsh Kernel to Build-2503-3
RC15-29
Removed Circular Battery Mod (Can be downloaded at #3)
Second attempt to fix bootloop
Removed IronKrnl, Added HP ICS Kernel by Spica
Tweaked Stock Kernel, named SuperNova
Patched Ad-Free Mod
RC14-29-R
Attempted to fix bootloop
RC14-29
Added center clock to circular battery mod
Added custom notification area background to circular battery mod
Added kernel 3.0.8 by wkpark
DHCP wlan fix by pastime
RC13-27
Fixed Google Play Store Black Text
Fixed 405 RIL not installed problem
Remove some steps in installer
RC12-21
Update Titanium Backup to v4.8.4.1
Update Holo-Dark Google Play Store to 20120317
Added New Nova HD boot animation option
Added back Circular Battery Mod
RC11
Update Apex Launcher to v1.0.2
Update Nova Launcher to v1.0.2
Update Google Apps to 20120317
Added Mountpoint option
Fixed calendar app and widget background
Fixed gmail textcolor for white/black backgrounds
RC10
Update Apex Launcher to v1.0.1
Added 3G Speed Tweak
Added black/holo themed Gmail
Fixed black/holo themed Play Store & Calender Option
Fixed OOM Grouping & Priority, V6SuperCharged
Remove Reloaded ICS mod to avoid bootloop
Remove Beats & HTC Boot animation option
Remove Root Browser option
RC9-18
Update Nova HD Plus Boot Animation
Added Reloaded ICS option
Added black/holo themed MMS & Calender Option
RC8-17
Added Circular Battery Mod
Added Ad Block Mod
Added Nova HD Plus Boot Animation
Update to Google Play Store v3.4.7
Remove AdAway option
RC7-17
Update Nova Launcher to v1.0.2beta4
Update Apex Launcher to v1.0.0
Added Ironkrnl with 32MB ramhack option
Deleted wake with volume rockers option
RC6-15-R
Fix Google Apps not installed problem
RC6-15
Tweak Ondemand Governor
Disable selection of Battery Mod(May add it back later)
Revise the installation UI
Remove the useless Beats Audio
Fix Galaxy Nexus boot animation not installed problem
Update Google Apps to 20120304
Custom carrier text in notification pulldown
Add preference for enabling root access
Deleted system update part from settings it is useless on KANGs
Modified the services.jar to be more battery friendly
Modified the framework.jar to have smoother volume steps
RC5-13
Fix instability problem
Adjust some tweaks
Fix some memory leaks at installation
RC4-10
Removed many options to reduce the ROM size
Enable selection of wipe option at every type of installation
Configurable display rotation
Enable long press volume to skip tracks
Enable landscape mode and adjust widget background in Torch
Enable face detection in Camera
Settings and Framework support of Profiles
RC3-6
Added Beats Audio Animation
Added Beats Audio
Added possiblity to remove stock apps
Minor Debug
RC2-6
Removed Useless Bravia Engine
Removed System Priority tweaks
Removed some paid Apps
Added a few options
Added possiblity to customize tweak
Lowered touchkey brightness to save some juice
RC1-3
You can choose default, minimal and custom installation
More Apps are included for customizing.
Improved feedbacks during installation (Great thanks to TweetyPeety)
Improved Options description
Touchscreen should work
RC0-0
Initial Release
[COLOR="SeaGreen"][B]Changelog Kernel[/B][/COLOR]
RC1-R (In progress)
Updated TouchScreen Drivers
Lowered RAM voltage a bit
Changed Default boot freq to 1015MHz
Optimized Tegra2 compiler
RC1
Improved voice quality patch
Tweaked Read Ahead
Lowered TouchLED max brightness
Overclocked GPU/RAM/VDE
Adjusted CPU Voltage a bit
Voodoo Sound Support
OC/UV Support (Up to 1.4GHz)
Added Battery Life Extender Support
Unlimited Max Charging Limit
bearbeitet von Shurkien
FredFeuerstein1977
sorry für diese vieleicht laien hafte frage, aber welches ist der richtige download?
NovaHDPlus_RC0-0.zip 29-Feb-2012 04:13 201M
NovaHDPlus_RC1-3.zip 01-Mar-2012 05:34 208M
NovaHDPlus_RC2-6.zip 02-Mar-2012 05:22 215M
NovaHDPlus_RC3-6.zip 03-Mar-2012 14:09 236M
NovaHDPlus_RC4-10.zip 04-Mar-2012 09:33 210M
NovaHDPlus_RC5-13.zip 05-Mar-2012 04:21 205M
NovaHDPlus_RC6-15-R.zip 07-Mar-2012 04:12 190M
NovaHDPlus_RC6-15.zip 06-Mar-2012 14:49 197M
und sollte man auch baseband mit flashen wo man dort auch downloaden kann?
Shurkien
Die aktuellste ist die NovaHDPlus_RC6-15-R.zip 07-Mar-2012 04:12 190M wie du auch am Datum erkennen kannst :)
Baseband empfehlung ist:
218,725 oder 824 :)
Am besten soll wohl das 725 laufen.
Ich nutze das 218 und habe keine Probleme bisher.
tyr75
Also ich hab sie seit gestern drauf und bin eigentlich bisher ganz zufrieden.
Es muss ja jedem klar sein das sie noch net 100% alltagstauglich ist, aber die wichtigsten funktionen sind vorhanden.
Ich nutze die BB0824 und bin ganz zufrieden damit.
Ne echt schöne ROM !
Guest harry2612
Ich hatte dieses ROM installiert und war eigentlich zufrieden. Leider funktionierten eingehende Anrufe nicht. Das Handy war immer im "Besetzt-Modus". Ausgehende Anrufe funktionierten einwandfrei.
BB hatte ich 725 installiert. Wo könnte der Fehler liegen?
Bismarck105
ich hatte ein änliches problem, besetzt oder sim nicht erkannt :confused:.
Bei mir passten RIL und Baseband nicht zusammen :icon_roll .
Versuche mal die gratis App getRil, Sie überprüft, ob das zusammenspiel ok ist.
Wenn da ein Fehler ist, kann man es gleich über die App downloaden und installieren.
casa1887
läuft ja mal ziemlich geil :danke:
bisher kein Bug festgestellt...
nur doof das man bei der Gesichtsentsperrung nur nen Foto vorhalten muss :D
aber das lässt sich wohl aktuell noch nicht umgehen. Also weiterhin alternative entsperrmethode wählen.
Was Akkulaufzeit betrifft kann ich nach 4 Stunden Test noch keine Aussage treffen.
banker31
Update:
[CM9][ROM][MAR08] Nova HD Plus RC7-17 | Highly Customizable | ICS 4.0.3
Hier gehts zum Download >>KlickMich<<
Changelog:
Gruss
rhartinger
Ich hatte die auch drauf. Funktionierte prima. Bis auf Video. Weiß denn jemand wann Videoaufnahmen funktionieren?
Und eins stört mich noch, das ist der Anrufbildschirm. Das ist aber bei jeder CM9 scheinbar. Die Nummer des Anrufenden steht oben nur an den Rand gedrückt und ist fast nicht zu erkennen.
Shurkien
gibs irgendwo ein paar screens? :)
Wofür? Sieht aus wie CM9.
Meiner ist ganz Normal.
Fehlende RIL
hmm, interessant.
wo ist der unterschied zu der : Owain's KANG BUILD RC0-15???
im Prinzip sind doch beide auch gleicher höhe was update betrifft, oder?
hast du mal beide getestet?
Update Stand ist immer gleich, ja.
Habe beide getestet und finde die Nova besser, aus dem Grund das dort mehr Tweaks enthalten sind
rhartinger
Hat jemand Videocam Illusion drauf? Bei mir ruckeln die Videos da immer
lgp9900
So danke erstmal für das bereitstellen des Roms und natürlich vielen Dank an alle Entwickler!!!
Rom läuft wirklich sehr schnell :)
Nun meine Fragen:
- gibt es einen Stock-Mount Fix?
- lässt sich ein Musik Widget nachinstallieren? (beim MIUI Player ist keins vorhanden)
viele Grüße
Shurkien
Stock Mount Fix gibt es noch keinen.
Musik Widget, also Stock könnte man mit der .apk bestimmt nach installieren
alternativ anderen Player nutzen (Doubletwist/PlayerPro)
ronstadt
wäre nett wenn einer die LG tastatur app machen kann ^^
Guest harry2612
Das hatte ich natürlich überprüft. GetRil zeigte dass RIL und Baseband zusammenpasste. Ich habe jetzt die Vers. RC6-15-R drauf und hier funktioniert es bei gleichem BB (1035.21_20110725) und RIL (0725 (V10d, Europe).
Was ich bisher leider mit CM9 noch nicht geschafft habe, ist eine Verbindung mit Bluetooth.
Funktioniert das bei Euch?
Stelle gerade fest: Verbindung zum PC funktioniert. Autoradio=Freisprecheinrichtung mit diesem ROM keine Chance. Stock topogigi ohne Problem.
bearbeitet von harry2612
Bismarck105
Bei Freispechen über KFZ FSE (Audi FSE Mit RNS-E MMI)habe ich auch probleme das aber auch schon mit CM7 und MIUI. Entweder wird garnicht verbunden oder geht trotz verbindung in Standby und trennt.
Das scheint aber ein genereller Bug zu sein.
Aber bei mir gab es seit ich getril benutzt habe kien Probleme mehr mit der verbindung.
Und Sprachqualli ist auch ok.
