LG Optimus Speed P990 - DjangoManouche 1.7 - Junkie ROM! [Custom-Rom]
Like Tree126Danke
Alt 22.02.2012, 16:59   #1
Benutzerbild von burningfight
Daumen hoch LG Optimus Speed P990 - DjangoManouche 1.7 - Junkie ROM!
[FINAL][ROM] DjangoManouche 1.7 - Last goodbye - Thanks to everybody
BASED ON ITALIAN 20S
4 EDITIONS:
- STOCK + 92 Mb CC ACTIVATED - EXT3 - FULL WIPE
- SPICA HP SR4 OC and No OC + 92 Mb CC ACTIVATED - EXT4 - NO WIPE + TrymOTF Tool by TrymHansen
- GUESTEKERNEL 2.1 with aroma installer + 96 Mb ZRAM ACTIVATED - EXT 4 NO WIPE + GuesteOC Tool by TrymHansen
Changelog
- 4 versions: Stock, Gueste 2.1 with Aroma Installer, Spica SR4OC and Spica SR4NoOC
- Added TW Launcher to default launchers
- Updated Play Store and Play Music with 4.2 leaked release
- Stability improvement
- Cron Jobs re-added
- Solved problems with sqlite3 at startup
- DjangoManouche Customizer with Aroma Installer updated with latest tweaks
- DjangoManouche Transformation Pack Deluxe with Aroma Installer updated wit latest theme by RobYyY "A touch of 3.0" (Credit to him!!!)
CUSTOMIZER FEATURES
- Stock or CM APNs
- Activate or Deactivate Compcache (for Stock and Spica's edition. For Gueste's one use GuesteOC tool)
- 20q or 20s NVRM Daemon
- Activate or Deactivate Pdroid and Activate or Deactivate FD (if you activate Pdroid please download the app from Play Store)
- Acending or Non-Ascending Ringtone
- 20s, 20q or 20c RIL
- Screenshot app with or without Sound
- Stock or Grouped (ICS Like) Settings.apk
- 20s, 20q, patched 20q and CM Sqlite Libs
- Stock or HD-in-3G Youtube app
- Audio Mods: Bets audio, DSP Manager and Volume+
TRANSFORMATION PACK EXTENDED FEATURES
9 Launchers:
- LG UI1 Launcher
- LG UI2 Launcher
- LG Prada Launcher
- Nemus Launcher
- 360 Launcher
- Go Launcher
- Holo Launcher
- TW Launcher
- Xperia S Launcher
12 Wonderful Transformation Packs:
- SU660 ICS Theme by MMarkkk
- Paint It Black Theme by Memhis
- LG by ICS by Gabriesu With transparent Notification Curtain
- iOSExtreme TP by Gabriesu
- Prada TP by Marsou77 and Gabriesu
- Night And Dawn TP by Superskill
- ICS TP by Gabriesu and me
- ICS TP with circular Battery Icon by Gabriesu and me
- Beauty Colored Theme by Yann73 - Updated
- HoneyFuture TP By Gabriesu
- Swish TP by Gabriesu
- LG TP - Including OSP, PCsync, OmadClient, Smartshare, LgMusic, LgEmail, Lg weather.
- Back to DjangoManouche stock - To go back from another TP (and suggested if you want to try another TP)
- Back to DjangoManouche stock with Circular battery icon - To go back from another TP (and suggested if you want to try another TP)
After choosing your favourite TP you can customize with 13 Bootanimation, 3 Unlock type, 10 Unlock style, 7 Fonts and 5 Camera app (with ICS icon), so you can mix some parts of TPs (for example ICS with ubuntu font and Swish bootanimation)
Hier könnt ihr die Rom, Transformationspack und Customizer für das Optimus Speed P990 downloaden.
Installationsanleitung für DjangoManouche hier klicken
!!Vielen Dank an carburano, der diese Rom erstellt hat!!!
Screenshot:
ANLEITUNG ZUM ÄNDERN DER ZEITZONE FÜR CRON JOB
- Gehe auf die Seite: http://wiki.openwrt.org/doc/uci/system zur Zeitzonen Tabelle
- Kopiere dann die TZ-Zeichenfolge für deine Zone (nur den erster Teil vor dem Komma, ie. PST8PDT)
- Füge diesen Wert in system/xbin/startcron.sh ein, (CET-1CEST Zeitzone für Italien und Westeuropa) ersetze in der Zeile: TZ = CET-1CEST.
- Speichern, Berechtigung wird überprüft und Neustart
Also Thanks to:
Topogigi
Gueste
Hell97
Spica1234
Dr4go
Flix132
Gabriesu
Mjuksel
Vadonka
jaspi72
Owain
whole XDA community
Italian forum for support (HDBlog, Androidiani, IpMart, Facebook group "LGDual"
Das passende Baseband findet ihr HIER
Weiter Infos zur ROM findet ihr HIER
Geändert von Horst77 (05.11.2012 um 07:38 Uhr) Grund: DjangoManouche 1.7 hinzugefügt
burningfight ist offline   Mit Zitat antworten
Alt 22.02.2012, 17:00   #2
Threadstarter
Installation für DjangoManouche:
Erst-/ Neuinstallation:
Voraussetzung zur Installation der ROM ist ClockworkMod.
Ladet die gewünschte Version, z.B. "DjangoManouche1.5beta2.zip" und kopiert diese auf eure SD-Karte (/sdcard/_ExternalSD)
Führt nun folgende Schritte hintereinander aus:
Startet euer Gerät im Recovery-Modus (VOLUME DOWN + POWER ON gedrückt halten bis erstes LG Logo verschwindet)
wählt => Backup and restore > Backup (Hiermit legt Ihr eine Sicherung des System an)
wählt => install zip from sdcard
wählt => choose zip from sdcard
wählt => die gerade gespeicherte Version, z.B. "DjangoManouche1.5beta2.zip" aus
bestätigt die Auswahl mit "***YES***" und die Installation über den AromaInstaller beginnt
wählt => eure persönliche (Fullwipe) Konfiguration im AromaInstaller aus
Update/ Änderungen (Apps/Kernel):
wählt => die gespeicherte Version, z.B. "DjangoManouche1.5beta2.zip" aus
wählt => eure persönliche (Nonwipe) Konfiguration im AromaInstaller aus
Bolle6881, Toppas83 und Mati007 haben sich bedankt.
Geändert von Horst77 (14.06.2012 um 17:10 Uhr)
Alt 22.02.2012, 17:01   #3
Threadstarter
Add-on:
Packages to enable and disable swap on FPS Version (only for FPS version!!):
Klick mich
Roboto Font:
Klick mich
AndiCP Camera MOD:
Klick mich
Bolle6881 und Mati007 haben sich bedankt.
Geändert von burningfight (08.03.2012 um 20:01 Uhr)
Alt 23.02.2012, 07:06   #4
Power-Mitglied
Benutzerbild von Stefan Gündhör
Die Django sollte dem Threadersteller definitiv ein paar THX einbringen. Definitiv mehr als die Thanatos oder die Alpha ICS, denn Django Manouche ist wirklich eine gute ROM. Worth a try
Mati007 hat sich bedankt.
Stefan Gündhör ist offline   Mit Zitat antworten
Alt 24.02.2012, 13:05   #5
Threadstarter
DJANGO MANOUCHE 1.1 jetzt auch hier Verfügbar!
Skullmonkey und Mati007 haben sich bedankt.
Alt 24.02.2012, 14:39   #6
Wie installiert man die transformation packs :) ?
jayk ist offline   Mit Zitat antworten
Alt 24.02.2012, 14:49   #7
Threadstarter
Einfach vor den Installieren Dalvik Cache Wipen.
ceza14, jayk und Mati007 haben sich bedankt.
Alt 24.02.2012, 15:06   #8
Woah ne, nach 10Minuten wieder gelöscht selten eine so hässliche Rom gesehen, alles andere scheint OK zu sein aber allein mit der Notification Bar kann ich mich nicht anfreunden :)
Shurkien ist offline   Mit Zitat antworten
Alt 24.02.2012, 16:55   #9
Threadstarter
bitte vorher überlegen dann was schreiben,denn deine Äußerungen stimmen vollkommen nicht!
mfg burningfight
Alt 24.02.2012, 17:46   #10
Benutzerbild von Horst77
Denke ich auch, da auch die Quellenangabe und der THX an den ROM Cooker carburano fehlt im Post#1.
Horst77 ist offline   Mit Zitat antworten
0 8, 1 0, 1 1, 1 2, 1 5, 20q, 2x, against, beta, crisis, django, djangomanouche, dr4go, global, guest, lg, manouche, no oc, oc, on, optimus, p990, rc12, renaissance, rom, speed, spica, thanksgiving, v20q, with
LG Optimus Speed P990 - Austausch gegen Optimus 3D Chris_262 LG Optimus Speed P990 Forum 641 19.03.2012 10:33
[Sammelthread] LG Optimus Speed P990 > Tausch in Optimus 3D => Die Ergebnisse!! stp402 LG Optimus Speed P990 Forum 49 16.11.2011 21:16
LG Optimus P990 Speed P990 - Akku u. Sim Probleme Isabella0908 LG Optimus Speed P990 Forum 2 12.10.2011 17:57
Unterschied zwischen Optimus Speed P990 und dem Optimus 2X P993 ste.reiss LG Optimus Speed P990 Forum 14 28.07.2011 11:48
[Custom-Rom] LG Optimus Speed P990 - WGSpoelstra's Speed Edition v1.1 Xendaren LG Optimus Speed P990 Forum 82 07.07.2011 14:47
Alle Zeitangaben in WEZ +2. Es ist jetzt 15:44 Uhr.
