LG Optimus Speed P990 - DjangoManouche 30A/30B - Stock ICS [Custom-Rom]
Like Tree260Danke
Alt 11.12.2012, 17:39   #1
Benutzerbild von chimalia
mit dem Einverständis von "carburano", dem Ersteller dieser ROM, werde ich hier eine Anleitung zum Flashen folgender ROM erstellen:
DJANGOMANOUCHE X 1.4
- OffTopicBringsSilenceEdition -
ROM Features:
- No wipe
- Based on ICS 30a/30b
- Deodexed but odexable with Modaco Odex-me
- Supercharged (with custom values by me for better memory management )(Thanks Zeppelinrox for the inspiration)
- Patched Service.jar to optimize Home app management, to avoid redraws (Thanks Zeppelinrox for the inspiration)
- Scrolling Cache disabled and more Volume steps in multimedia apps (Thanks AndroidON)
- Fully tweaked
- No Ota update in settings
- No OSP in settings and fully removed
- Enabled ADB
- Optimized host to remove spam and ads
- 4.2 Gmail with pinch to zoom
- Zipaligned
- Init.d support
- Optimized SU binary
- Battery Tweaks
- Removed many LG apps
- Cron Jobs to free ram every 3 hours and update gps lto.dat every week
- Removed LGStartupWizard
- SD card and Kernel Sceduler Speed tweaks
- Adobe flash
- Youtube HD also in 3g
- Updated many apps (included PlayStore)
- Every partition in EXT4
- Widget from SU660 (calendar, Memory Management, etc...)
Preinstalled apps:
- Super user (with modded SU binary)
- LG UI 3 weather widget
- Polaris Office
- ES file manager
- Terminal Emulator
- Quickboot
- Faceunlock
- Modaco Odex-me
Es gibt zwei Versionen mit Aroma-Installer: v30a und v30b!
In jeder Version kann folgendes ausgewählt werden:
  • CRT-Effekt oder Stock (Screen-Off Animation)
  • Statusleiste 30% transparent oder Stock
  • LG Apps:
- LG app manager, useful for LG UI themes
- LG SU660 RAM Widget
- LG Email + Widget
- LG OSP
- LG Smartshare
- LG Pcsync
- LG Music
- LG setup wizard
  • 3 Launcher
- Lg Home ported from JB ROMs ATT: this will install as system app and it needs 25 MB of your system partition (reduced because I removed some wallpapers)... be sure you have enough free space (you cannot install this togheter with stock one)
- LG Weather from JB Roms ATT: this will install as system app and it needs 50 MB of your system partition... be sure you have enough free space (you cannot install this togheter with stock one)
- LG Home
- Lg Home ported from 4x (you cannot install this together with stock one)
- Xperia Launcher (FC fixed)
  • 3 Boot-Animationen
- DjangoManouche Guitar
- DjangoManoucheX by IcyEye
- LG 4x
  • 2 RAM Einstellungen
- Stock
- DjangoManouche (for more free RAM)
  • 3 Led Helligkeitseinstellungen
- Superdimmed (2)
- Half Dimmed (10)
- Stock (20)
  • MMS app
- Stock
- OptimusG
  • Gallery app
Code:
- Stock
- OptimusG
  • Rils
- 30A
- 30B
- 28G
  • Adblock
- Active
- Inactive
Es stehen vier Kernel zur Auswahl
  • Stock Kernel - Features:
- noop scheduler as default
- 96 Mb Swap
  • 2 - KingOfBirds Kernel 0.5 OC (rebuilded on 30b sources) - Features:
- Compiled with Google 4.4.3 Toolchain
- Solved bug with LED brightness always on
- Default Scheduler: ROW
- Default Governor: Interactive
- Hotplug, SmartassV2 and Savagedzen Governors Available
- Added BFQ5 Scheduler and ROW by Qualcomm (both Thanks to Pengus77)
- 1.456 Ghz Max OC available with CPU Master and with OV/UV functionality (Thanks WKPark for the patch and Thanks Civato for your UV/OV and Freq table).
In this version i fixed the scaling error after first boot and UV lower frequencies (-25)
- 96 Mb Zram available and 32 Mb Ramhack
- LowMemoryKiller Optimizations
- BSOD Fixed by Nvidia
  • 3 - KingOfBirds Kernel 0.5 NoOC (rebuilded on 30b sources) - Features:
- Stock Frequencies and Voltages
  • 4 - Kowalski Kernel 011p3 by Pengus77 - DEFAULT CHOICE IN AROMA INSTALLER - Features:
Really amazing kernel by a great developer (I think he's really one of the most competent person I ever seen on this forum and a very helpful man!)
For changelog of this awesome beast see HERE...
In DjangoManouche (and other stock-based rom) we have only one (not important IMHO) bug: LCD brightness regulation doesn't work but auto brightness works very well!! BTW I applied auto brightness by default in my rom so... don't worry!
Other default choice in DMX:
Vorraussetzungen:
  • Ihr MÜSST eine ICS-Version von LG drauf haben (ob v28 oder v30 - egal!)
  • Ihr MÜSST ClockworkMod (CWM) installiert haben
Download:
--> DOWNLOAD der ROM und Kernel
Installation (Aroma-Installer):
• zuerst die ROM auf die SD Karte kopieren! (nicht entpacken)
• Handy auschalten und im CWM Recovery-Modus starten (VOLUME DOWN + POWER ON gedrückt halten bis das 2. LG Logo verschwindet)
• Backup and restore > Backup (Hiermit legt Ihr eine Sicherung des bestehendem System an) [optional/empfohlen]
• install zip from sdcard
• choose zip from sdcard
• Wähle die neue ROM aus z.B. "django......zip" und bestätige (Aroma-Installer wird gestartet)
• wähle "Next>" und danach die gewünschten Settings (Kernel, Apps etc)
• full wipe toggle: Auswahl full wipe
• YES - alle Daten und Einstellungen werden gelöscht [Neuinstallation]
• NO - alle Daten und Einstellungen bleiben erhalten [Update]
• nach der Installation wird das LGOS neu gestartet [Neustart dauert länger als gewöhnlich]
• Fertig
Auswahl im CWM mit den Lautstärke Tasten, Auswahl bestätigen mit der Power Taste/im Aroma-Installer über Touchscreen
Changelog:
- Rebuilded rom with AROMA installer (do you remember DjangoManouche 1.3? First Stock based Rom for LG2X with Aroma installer? so... 1.3 again)
- Modaco Odex-me installed to easy odex DjangoManouche!!
- Few Updates and fixes
Screenshots:
Thanks a lot carburano!!
Peacock, bravovictor, Seven of Nine und 29 andere haben sich bedankt.
Geändert von Horst77 (04.02.2013 um 16:17 Uhr) Grund: aktualisiert
Alt 11.12.2012, 17:47   #2
sehr aktives Mitglied
Benutzerbild von MetaIIica
also auch wenn ich Stockbasierte Roms nicht so mag, scheint diese Version sehr gut zu laufen
kann ich empfehlen
op1983 hat sich bedankt.
MetaIIica ist offline   Mit Zitat antworten
Alt 11.12.2012, 17:52   #3
Version 1 oder 2 ? welche hast Du installiert ist das BB mit dabei oder muß das extra geflasht werden, ich hab die v28g mit dem älteren BB vom 7.11 drauf
Mfg
pronto1971 ist offline   Mit Zitat antworten
Alt 11.12.2012, 18:01   #4
Rennt wie hulle, hatte ICS drauf, King of Birds dann einfach per cwm installiert, war echt überrascht wie schnell meine Diva sein kann.
BB 3011
biggeorgi und mactonno haben sich bedankt.
Snake69 ist offline   Mit Zitat antworten
Alt 11.12.2012, 18:06   #5
komme von der stock v30a muss ich meine kontakte und apps jetzt nochmal sichern bevor ich mir die django per cwm flashe?
#kLe ist offline   Mit Zitat antworten
Alt 11.12.2012, 18:08   #6
Threadstarter
Ja, unbedingt!
Alt 11.12.2012, 18:10   #7
Sollte man einen Full-wipe machen, oder ist es nicht nötig?
Gruß Tobi
HP2210 hat sich bedankt.
Tobald ist offline   Mit Zitat antworten
Alt 11.12.2012, 18:11   #8
Bei mir ist alles geblieben wie es war. Hab vorher auch ein Backup gemacht, war aber nicht nötig, aber wie heißt es so schön: Vorsicht ist die .....
korea hat sich bedankt.
Alt 11.12.2012, 18:14   #9
Ich hab nix gemacht, außer installiert, läuft wie hulle, wie gesagt, aber probierts aus.
Alt 11.12.2012, 18:16   #10
Ok dann wer ich die auch einfach mal drüberbügeln! :)
30a, 30a 30b, djangomanouche, ics, lg, optimus, p990, speed, stock
[Custom-Rom] LG Optimus Speed P990 - DjangoManouche 1.7 - Junkie ROM! burningfight LG Optimus Speed P990 - Custom Roms 693 29.12.2012 00:15
[Custom-Rom] LG Optimus Speed P990 - Stock ROM mod by topogigi GB 2.3 banker31 LG Optimus Speed P990 - Custom Roms 2684 03.04.2012 20:38
[Diskussionsthread] LG Optimus Speed P990 - Stock ROM Optimierungen krteddy LG Optimus Speed P990 Forum 74 25.12.2011 11:44
[Gelöst] LG Optimus Speed P990 - MIUI Lockscreen auf Stock ROM ? kallooor LG Optimus Speed P990 Forum 2 27.09.2011 09:05
[Anleitung] LG Optimus Speed P990 - Stock ROM Optimierungen krteddy LG Optimus Speed P990 Forum 0 14.04.2011 19:26
Alle Zeitangaben in WEZ +2. Es ist jetzt 17:08 Uhr.
