LG Optimus Speed P990 - WGSpoelstra's GB Edition | v10.8.0 [CM7] [Custom-Rom]Dieses Thema wurde im LG Optimus Speed P990 Forum geschrieben. Solltest Du auch Probleme oder Lösungen zu diesem Thema haben, so nimm doch einfach an der Diskussion teil. |
#1 | |||
Hier einmal die Informationen, die WGSpoelstra uns darüber gibt: Code:
Welcome to WGSpoelstra's Gingerbread Edition ROM! Hey all! This ROM is currently based on CyanogenMod7 nightly build 1.08 and RC1. I will update it as CyanogenMod7 gets updated, and some other updates inbetween. As I said, it's based on CyanogenMod7, but has been thoroughly modded by me. It probably holds the same bugs as the official CyanogenMod7, but I will do what I can when you find any. Any requests for applications, widgets or anything to be put in the ROM can be posted here! I will review any requests and see if I put them in. The ROM currently holds: - Latest VorkKernel by Benee & Kiljacken - Libsqlite.so patch by Benee - Quicker GPS fix in Europe - Updated BusyBox (1.19) - Customized framework (icons, battery percentage, notifications tab) - The following apps: Terminal Emulator, Browser, Calculator, Calendar, Camera, Contacts, Desk Clock, Email, File Manager, Gallery 3D, Google Sync, Gingerbread Keyboard, ADW Launcher, MIUI Music, MMS, Pimp My CPU 2.8, Rom Manager, Sound Recorder, Spare Parts, SuperUser, Market, VoiceDialer, Google Talk, Volume+. Screenshots: At the bottom of this post! Installation instructions: 0. Boot into recovery 1. Wipe Data/Factory Reset when coming from stock/another custom ROM! not needed when coming from an earlier version of this ROM 2. Install zip from SDcard >> Choose zip from SDcard >> select the ROM.zip file 3. Let it install, when done, reboot! Inhalt der ROM:
Screenshots: Bootanimation:Installation: Ladet die "WGSpoelstra_GBE_v10.8.0.zip" oder "WGSpoelstra_GBE_vRC1.zip" unter Download und kopiert diese auf eure SD-Karte (/sdcard/_ExternalSD) - Es muss auf eine SD-Karte geladen werden nicht auf den Internen Speicher! Führt dort folgende Schritte hintereinander aus:
Update Installation: Ladet die "WGSpoelstra_GBE_v10.8.0.zip" unter Download und kopiert diese auf eure SD-Karte (/sdcard/_ExternalSD) - Wichtig es muss auf eine externe SD-Karte geladen werden nicht auf den Internen Speicher! - Starten euer Gerät im Recovery-Modus (VOLUME DOWN + POWER ON gedrückt halten) Navigiert wird mit den Hardware-Tasten: Wie bekomme ich "Pimp my CPU" ans laufen?
Download: ROM: v10.8.0 @ MultiUpload vRC1 @ MultiUpload Live Wallpapers & Theme Chooser + themes Changelog: Code:
Official CyanogenMod7 changelog v10.8.0: - Based on latest CM7 nightly 1.08 v7.8.2: - Based on latest CM7 nightly .78 - Updated VorkKernel to 20110712, discarded ramhack and [hopefully] fixed reboot issues - Updated Volume+ to v1.7.2 v7.4.0: - Based on latest CM7 nightly .74 v6.9.0: - Based on latest CM7 nightly .69 v6.6.0: - Based on latest CM7 nightly .66 v6.2.2: - Based on latest CM7 nightly .62 - Updated VorkKernel to v20110627 - Updated PimpMyCPU to v3.0 and Chainfire 3D to v2.0 v6.0.0: - Based on latest CM7 nightly .60 vRC1: - Based on latest CM7 release candidate 1 v5.8.0: - Based on latest CM7 nightly .58 v5.5.1: - Based on latest CM7 nightly .55 - Fixed root bug v5.4.2: - Based on latest CM7 nightly .54 - Updated framework - Updated SuperUser v5.2.0: - Based on latest CM7 nightly .52 v4.9.0: - Based on latest CM7 nightly .49 v4.6.1: - Based on latest CM7 nightly .46 - Updated framework v4.3.1: - Based on latest CM7 nightly .43 - Updated VorkKernel to 080611 & added -boost flag v3.7.2: - Based on latest CM7 nightly .37 - Updated VorkKernel to 030611 - Switched battery mod v3.5.0: - Based on latest CM7 nightly .35 v3.1.2: - Updated VorkKernel to 310511 v3.1.1: - Based on latest CM7 nightly .31 - Added Chainfire3D v3.0.1: - Based on latest CM7 nightly .30 - Updated VorkKernel to 240511 v2.9.2: - Updated VorkKernel to 230511 (OC up to 1500 MHz!) - Updated Pimp My CPU to 2.8 v2.9.0: - Based on latest CM7 nightly .29 v2.8.1: - Based on latest CM7 nightly .28 - Included BitrateMod for better quality film v2.7.0: - Based on latest CM7 nightly .27 v2.6.0: - Based on latest CM7 nightly .26 v2.4.5: - Deleted Live Wallpapers - Deleted Theme Chooser + themes v2.4.3: - Updated VorkKernel to 190511 - Added Google Talk - Deleted LauncherPro v2.4.0: - Based on latest CM7 nightly .24 - Updated VorkKernel to 170511 v2.2.0: - Based on latest CM7 nightly .22 v2.1.4: - Updated VorkKernel to 150511 - Re-added Theme Chooser + themes, ADWLauncher, Live Wallpapers - Deleted XDA Developers Forum App - Switched bootanimation to CyanogenMod bootanimation v2.1.0: - Based on latest CM7 nightly .21 v2.0.4: - Changed battery icon mod - Added XDA Developers Forum App - Updated RomManager v2.0.1: - Based on latest CM7 nightly .20 - Changed font back to default font v1.9.1: - Updated VorkKernel to 120511 v1.9.0: - Based on latest CM7 nightly .19 v1.8.1: - Based on latest CM7 nightly .18 - Applied Benee's tweaked libsqlite.so-patch v1.7.5: - Based on latest CM7 nightly .17 - Updated VorkKernel to 080511 - Deleted CircleLauncher, CMWallpapers, Live Wallpapers v1.6.0: - Based on latest CM7 nightly .16 v1.5.6: - Updated VorkKernel to 070511 - Changed default wallpaper - Customized notifications tab - Updated statusbar icons - Added Pimp My CPU 2.7 v1.5.1: - Based on latest CM7 nightly .15 - Deleted a few apps v1.3.7: - Based on latest CM7 nightly .13 - Updated BusyBox to 1.19 - Switched kernel to Benee's latest VorkKernel 030511 - Some adjustments to framework - Changed font - Quicker GPS fix in Europe - Deleted a few apps - Added a few apps ! ! ! Weder ich, noch handy-faq, noch sonst irgendwer übernimmt eine Haftung für irgendwelche Schäden die durch das befolgen dieser Anleitung/ROM geschehen. ! ! ! Quelle Geändert von Xendaren (16.08.2011 um 00:54 Uhr) Grund: Update auf v10.8.0/vRC1 |
#2 |
bin mal auf die screenshots gespannt :)
#3 |
So Screenshots von WGSpoelstra hinzugefügt
#4 |
Gibts ein Video/Screenshot zur Bootanimation
#5 |
stp402 war so nett und hat heute Nacht die Bootanimation als Screenshot eingefügt.
Update auf WGSpoelstra's Gingerbread Edition v1.4.2 (CM7) Changelog: Code:
v1.4.2: - Based on latest CM7 nightly .17 - Updated VorkKernel - Deleted CircleLauncher, CMWallpapers, Live Wallpapers |
#6 |
HF-Neuling
hi leutz beim VOLUME DOWN + POWER ON geht bei mir nix komm nicht in den Recovery-Modus ??
#7 |
sehr aktives Mitglied
kennsch clockwork mod installieren :D?
#8 | |
hast du die ClockworkMod installiert? MfG Xen |
#9 |
HF-Neuling
hi hab gerade nach geschaut und gesehen das ich es machen muß aaaaaaaber is ja total die action
#10 |
Hallo lgjosh,
bevor du die Rom installieren kannst, mußt du dir erst, wie Xendaren schon gesagt hat, den ClockWorkMod auf dein Telefon aufspielen. Achte darauf, daß du bei dieser Rom die neue 3.0.2.8-Version des CWM benötigst. Du findest sie hier: http://www.handy-faq.de/forum/lg_opt...ml#post1495355 Gruß stp402 |
| 16, cm7, edition, gb, gingerbread, lg, optimus, p990, speed, v vrc1, v1 3, v1 6, v1 8, v4 0, v6 rc1, wgspoelstra |
| [Custom-Rom] LG Optimus Speed P990 - FrYful Edition v1.7 & FINAL [CM7] | fry92 | LG Optimus Speed P990 Forum | 217 | 17.02.2012 10:38 |
| [Custom-Rom] LG Optimus Speed P990 - krteddy Blue Edition v1.4.1 | krteddy | LG Optimus Speed P990 Forum | 499 | 18.11.2011 21:43 |
| [Custom-Rom] LG Optimus Speed P990 - BlazingDragon v0.1 - Gingerbread Edition [CM7] | Shurkien | LG Optimus Speed P990 - Custom Roms | 17 | 09.06.2011 15:10 |
| [Custom-Rom] LG Optimus Speed P990 - WGSpoelstra's SuperSlim Edition v1.6a & v1.6b | krteddy | LG Optimus Speed P990 Forum | 31 | 12.05.2011 13:16 |
