andreas02
Samsung Galaxy Note II - Omega Rom
andreas02
Omega v27
Omega v29 based on 4.4.2:
Based on firmware XXUFNE1 Android 4.4.2 (Date: 06/05/2014)
Kernel Stock
Modem XXUFND3
csc multi set to BTU
Busybox
Aroma Installer
Installation is fully customizable by user and there is options to install everything or remove all Bloatware
aroma installer now has the option to remove more then 620 mb of almost 80 bloatware apps, widgets and services
Option to full wipe from aroma installer
Option to Remove all Bloatware from aroma installer
Option to install or not all Omega addon apps from aroma installer
Wipe cache partition automatic before roms installation
Wipe Dalvik Cache automatic during installation
Wipe preload partition automatic before roms installation
Wipe System automatic before roms installation
efs Backup (added the option to create efs backup during installation)
Omegadroid Walk Bootanimation by Jorq1H and anbech
Omegas Emblem Shutdown Animation by anbech
OmegaDroid Kit Kat Wallpapers by our artist Jorq1H
Omegadroid wallpapers added in default wallpapers
Mods:
Call Recording
Phone with no increasing ringtone
4-way reboot menu
Battery % mod
Hide sms from call logs
No sms to mms conversion
Unlimited contacts to sms - mms
sms/mms Backup - Restore
Increased sms hour limit to 1000
Disable scrolling cache
Email with Exchange Security Disabled
All supported languages enabled
All supported languages for Samsung Keyboard enabled
Exit button to stock browser
Join more unlimited contacts in the contacts
Enable sub Symbols on Stock Samsung keyboard
Task manager shortcut app by indie
Installation:
Download der ROM und speichern auf eurem Note II.
Root und CWM Recovery mit Odin wie hier beschrieben installieren.
Danach in den CWM Recovery booten (Volume up - Powerknopf - Homebutton gleichzeitig drücken).
Ein Backup des aktuellen ROMs machen und dieses wenn möglich (zur Sicherheit) auf dem PC speichern.
Solltet ihr nicht von einer vorherigen Version von Omega kommen, dann einen
Wipe data / factory reset durchführen.
Danach Omega von eurem Note II installieren und den Anweisung des Aroma Installers folgen.
(Ein Wipe cache wird automatisch während der Installation durchgeführt)
Rebooten
DOWNLOAD OMEGA v29
Originalthread XDA
ACHTUNG: Diese Anleitung soll euch lediglich als Hilfestellung dienen. Jeder Systemeingriff am Gerät, wie zB durch Flashen oder Rooten birgt Gefahren in sich. Es wird in diesem Zusammenhang ausdrücklich darauf hingewiesen, dass weder handy-faq noch ich Verantwortung für Schäden, die durch Flashen nach dieser Anleitung entstanden sind, übernehmen. Jeder muss selber wissen was er tut und sich zutraut. Weiters wird darauf hingewiesen, dass durch Flashen oder Rooten Garantieansprüche gegenüber dem Hersteller oder Anbieter erlöschen oder sich auch ein Vertragsbruch mit dem Provider ergeben könnte. Daher werden Systemeingriffe immer in eurer Eigenverantwortung durchgeführt.
Andreas
bearbeitet von Eric-Mod
Update V27
  • Like 3
robby57
Würde mal besser die Finger von Customs lassen da S Beam
dann nicht mehr geht.
optimus~prime
Das darf jeder für sich selber entscheiden. Es wird hier niemand gezwungen irgendeine Custom Rom zu flashen. Wir bieten dieses hier lediglich an.
Gesendet von meinem GT-N7000 mit Tapatalk 2
bullwei04
Das stimmt nicht.Es gibt eine Rom wo es funktioniert.
Edit: Mit der Omega klappt es auch.
Gruß:winknkiss
bearbeitet von bullwei04
andreas02
Update auf Omega v4.0 ist draussen.
Changelog:
Based on firmware XXALJ3 Android 4.1.1 (Date: 10/10/2012)
New:
Kernel XXALJ3
Modem XXALJ1
efs Backup option in Aroma installer
Full Wipe option in Aroma installer
New Omega Bootanimation by Jorq1H and anbech Omegas artists
ZArchiver
Updated:
Gmail v4.2
Play Store v3.9.16
Dropbox
Flipboard
Google+
YouTube
Hosts
Mods:
Call Recorder credits to wanam
Phone with no increasing ringtone credits to wanam
15 Toggle Buttons Mod credits to lidroid + wanam
4 way reboot menu
All mods and updates from previous Omega JB versions added
Rom is Deodexed + Rooted + Zipaligned
Rom is no Full Wipe
Omega N7100 XXALJ3* v4.0
Post 1 ergänze ich, wenn ich wieder zu Hause bin....:hiding:
Andreas
andreas02
@robby57
In einem gewissen Alter (wie wir) sollte man auch auf das Datum schauen. Am 20.10.12 war es noch die v4.0
Seit heute, 22.10.2012, ist die v4.1 nach langem Upload endlich erschienen.
Somit ist hier der Downloadlink zur v4.1
Und hier der Changelog dazu:
Kernel XXALJ3
Modem XXALJ1
Multi CSC: LJ3 set to EUR
Aroma installer
Installation is fully customizable by user and there is options to install everything and remove Bloatware
Read here for more info.
With custom Installation you take control of what is installed in your device.
init.d support without the need of a kernel that supports init.d
Added:
Busybox
SuperSU
OmegaDroid wallpaper
Omegadroid Bootanimation by Jorq1H and anbech Omegas artists!
GenieWidget
Live Wallpapers
Flashplayer support
Updated (to latest version):
Gmail
Google Maps
Play Store
Google Search
Mods:
15 Toggle Buttons Mod credits to lidroid for the mod + wanam for porting to Note 2
4 way reboot menu
Disable Scrolling Cache
TouchWiz with wallpaper scrolling
Battery % mod
Disabled advertisements
Faster GPS lock
Enable custom bootanimations
Enable init.d scripts
Contacts with Greek index
Shutter Sound menu Enabled to stock camera
Remove Blocking Mode Icon
APNs list from cm10
200 contacts can be added to mms app - available in Omega Files
Tweaks:
build.prop tweaks
Stock Theme Changes:
Dithered Holo Background added by Zabalba
Blue % battery icons
Blue Toggle Buttons
Omegas addon applications:
Es File Explorer (with great Root Explorer)
Hide It Pro
ZArchiver
Theme:
Black Status bar
Blue circle battery icons
Removed:
Boot sound
Charger Connection Sound
Shutdown Animation
Removed Bloatware:
Learning hub
Reading hub
ChocoEUKor.apk
DeepSea.apk
Andreas
KingOfNV
Hab noch das Stock Rom drauf gerootet ist aber schon.
Auf meinem S3 hatte ich auch das Omega Rom sowie das Omega Files App, in dem man ein anderes Touchwiz installieren konnte mit 4x6 Icons.
Gibt es das fürs Note 2 auch ?
Brauche eigentlich nur die zu ersetzende File.
andreas02
Update der Omega auf v5
Changelog:
Based on firmware ZSALJ7 Android 4.1.1 (Date: 16/10/2012)
Kernel ZSALJ7
Modem XXALJ2
Aroma installer
Added:
Busybox
SuperSU
OmegaDroid Walk Bootanimation by Jorq1H
GenieWidget
Live Wallpapers
Flashplayer support
Gmail
Google Maps
Play Store
Google Search
Mods:
4 way reboot menu
Battery % mod
Faster GPS lock
APNs list from cm10
Join more unlimited contacts in the contact app
Tweaks:
build.prop tweaks
Blue Toggle Buttons
Hide It Pro
ZArchiver
Theme:
Black Status bar
Removed:
Boot sound
Shutdown Animation
Removed Bloatware:
Learning hub
Reading hub
ChocoEUKor.apk
DeepSea.apk
Post 1 ist ergänzt.
Andreas
andreas02
Update der Omega auf v6:
Changelog:
Based on firmware ZSALJA Android 4.1.1 (Date: 24/10/2012)
Kernel ZSALJA
Modem XXALJ2
Aroma installer
Added:
Busybox
SuperSU
GenieWidget
Live Wallpapers
Flashplayer support
Gmail
Google Maps
Play Store
Google Search
Mods:
4 way reboot menu
Battery % mod
Faster GPS lock
APNs list from cm10
Tweaks:
build.prop tweaks
Blue Toggle Buttons
Hide It Pro
ZArchiver
Theme:
Black Status bar
Removed:
Boot sound
Shutdown Animation
Removed Bloatware:
Learning hub
Reading hub
ChocoEUKor.apk
DeepSea.apk
Post 1 wurde ergänzt
Andreas
LordSimal
Eine Frage, bekomme zwar mein GN2 erst am Freitag aber habe gehört dass es bei den Custom-Roms noch das Problem gibt dass S-Beam nicht funktionert... stimmt das?
bzw. alle anderen Features wie die extra Funktionen des Stiftes (z.b. Sofortnotiz machen) oder Air-View, gehen die alle bei der Omega-Rom?
Danke für eure Hilfe
Mfg
LordSimal
andreas02
Hast du den Post 4 hier in diesem Thread gelesen ?
Dort steht doch etwas dazu.
Andreas
LordSimal
Tut mir Leid, habe das irgendwie voll übersehen.
Mfg LordSimal
Gesendet von meinem GT-I9100 mit Tapatalk 2
andreas02
Quark....kann ja mal passieren....:)
Andreas
Gesendet von meinem GT-N8000 mit Tapatalk 2
Schrammel
Moin moin,
habe gerade die Omega installiert, wie ich es von meinem SGS3 gewohnt bin über CWM. Hat auch alles funktioniert, nur jetzt habe ich keine Basisbandversion mehr. Beim SGS3 habe ich einfach eine runtergeladen und installiert. Habe jetzt zwei mal geflasht, immer das gleiche.Warum wird kein Modem mit geflasht ??
Schrammel
Moin moin,
EDIT: Ich habe die LTE Version, kann es daran liegen ?
BMWpokerAce
Kann ich mir sehr gut vorstellen.
Schau mal bei XDA nach, da haben sie für das N7105 eine extra Android Developement Kategorie.
Ist zwar sehr spartanisch aber du kannst versuchen die Stock zu flashen für das N7105.
Hier der Link:
https://forum.xda-developers.com/forumdisplay.php?f=1960
Wenn du danach wieder eine Baseband hast, dann weisst du wo der Wurm drin steckt :)
Schrammel
Ähmm.. welchen Link wähle ich denn genau für die Stock Rom ? Ich habe jetzt irgendwie den Link mit EmptyStock genommen und geflasht. Also das Modem ist jetzt wieder da. Schade, dass ich auf meinem LTE so keine Omega Rom installieren kann.
BMWpokerAce
Ja hast schon richtig geflasht.
Das Angebot ist wie gesagt - eher spartanisch :icon_neut
Jetzt weißt du woran es liegt, auch wenn du damit nicht ganz so glücklich wirst :huh:
andreas02
Leider etwas spät,aber Problem ist ja gelöst.
Grundsätzlich bitte die OP´s genau lesen. Sollten CustomRoms auf dem 7100 und 7105 laufen, werde ich es dazu schreiben.
Daher auch bitte die Installationsanleitung genau lesen:
"Ein Backup des aktuellen ROMs machen und dieses wenn möglich (zur Sicherheit) auf dem PC speichern."
Und schon wäre vieles unproblematischer geworden.
Ausgehend von deiner Sig nehme ich an, dass Du eine Vodafone Stock drauf hattest.
Hier noch einmal der Link zur Vodafone N7105XXALIJ
Andreas
