Alex@xelA
Universal Root fuer alle Xoom und alle Android Updates !
Alex@xelA
Universal Root fuer Xoom alle Versionen und alle Android Updates !
die Jungs von XDA haben wohl fuer alles eine Loesung parat :respekt:, da hab ich diese Anleitung gefunden.
Quelle XDA: https://forum.xda-developers.com/showthread.php?t=1242241
leider ist diese auf Englisch - wird sich einer bereit erklaeren uebersetzte Version posten?
Note: Unlike the similar method floating around on here, this also gives you an unsecured boot image.
-- Please Note: this thread is still a work in process and has been sped up by the arrival of the 4g Xooms --
Current requirements: adb & fastboot have been setup and you have an external sdcard for your xoom.
1. Setting up adb & fastboot
Coming Soon! (If you want to write this section for me and pm me it, thats fine !)
2. Downloading the rooting-update zip file.
Download the zip file from here: https://api.viglink.com/api/click?format=go&drKey=1359&loc=http%3A%2F%2Fforum.xda-developers.com%2Fshowthread.php%3Ft%3D1242241&v=1&libid=1320516325057&out=http%3A%2F%2Fgoo.gl%2FOm9aP&ref=http%3A%2F%2Fwww.handy-faq.de%2Fforum%2Fmotorola_xoom_forum%2F226670-universal_root_fuer_alle_xoom_alle_android_updates.html&title=%5BRoot%5D%20Universal%20Xoom%20Root%20-%20ANY%20XOOM%20ANY%20UPDATE%20-%20xda-developers&txt=here.&jsonp=vglnk_jsonp_13205167407691
Now place this on your external sdcard. - Sorry this is a requirement at the moment, like I said this is a bit rushed.
3. Flashing recovery
1. Download this Recovery image: https://api.viglink.com/api/click?format=go&drKey=1359&loc=http%3A%2F%2Fforum.xda-developers.com%2Fshowthread.php%3Ft%3D1242241&v=1&libid=1320516325057&out=http%3A%2F%2Fbit.ly%2FiLRAIV&ref=http%3A%2F%2Fwww.handy-faq.de%2Fforum%2Fmotorola_xoom_forum%2F226670-universal_root_fuer_alle_xoom_alle_android_updates.html&title=%5BRoot%5D%20Universal%20Xoom%20Root%20-%20ANY%20XOOM%20ANY%20UPDATE%20-%20xda-developers&txt=this&jsonp=vglnk_jsonp_13205169628888
2. If your device is locked, now is a good time to unlock it.
Code:
adb reboot bootloader
fastboot oem unlock
fastboot reboot
3. Flash recovery
Code:
fastboot flash recovery recovery-Tiamat-R4c-100611-1150-cwm.img
Once you have verification on your device that this has been flashed, reboot your device by holding volume up + power.
Then 3 seconds after you see the Motorola logo, hit volume down. You should now see "Android Recovery" in the top left corner. Hit volume up to boot into recovery.
4. Flashing the Xoom-Universal-Root.zip file.
If you're in clockwork mod recovery you can continue (This recovery image will say it is clockwork mod) . If you're not looking at clockwork mod, then you need to repeat step 3 again.
In cwm, go into "install zip from sdcard" -> "Choose zip from sdcard", then select the Xoom-Universal-Root.zip file you downloaded.
Note: use the volume buttons to navigate and the power button to select
Reboot your device and then welcome to your rooted device!
bearbeitet von Alex@xelA
Alex@xelA
leider ist diese auf Englisch - wird sich einer bereit erklaeren uebersetzte Version zu posten?
diphtong
... wie gewünscht hier mal auf deutsch
Universelle Xoom Root Methode: https://api.viglink.com/api/click?format=go&drKey=1359&loc=http%3A%2F%2Fforum.xda-developers.com%2Fshowthread.php%3Ft%3D1242241&v=1&libid=1320516325057&out=http%3A%2F%2Fgoo.gl%2FOm9aP&ref=http%3A%2F%2Fwww.handy-faq.de%2Fforum%2Fmotorola_xoom_forum%2F226670-universal_root_fuer_alle_xoom_alle_android_updates.html&title=%5BRoot%5D%20Universal%20Xoom%20Root%20-%20ANY%20XOOM%20ANY%20UPDATE%20-%20xda-developers&txt=Universal%20Xoom%20root%20-%20version%201.0&jsonp=vglnk_jsonp_13205170819169
Ganz recht, diese Methode funktioniert auf jedem Xoom mit jedem Update - Inklusive zukünftiger Updates!!!
Hinweis: Im Gegensatz zu einer ähnlichen Methode, die sich im Umlauf befindet beinhaltet diese zusätzlichen ein freigeschaltetes boot image.
-- Bitte beachten: Dieser Thread befindet sich in der Bearbeitung --
Derzeitige Voraussetzungen: adb & fastboot müssen eingerichtet sein und du hast eine externe SD-Karte für dein Xoom.
1. Einrichtung adb & fastboot
Siehe z.B. hier: https://www.handy-faq.de/forum/motorola_xoom_forum/197485-motorola_xoom_adb_android_sdk_windows_installieren.html
2. Download des rooting-update zip files.
Lade das zip file von hier: https://api.viglink.com/api/click?format=go&drKey=1359&loc=http%3A%2F%2Fforum.xda-developers.com%2Fshowthread.php%3Ft%3D1242241&v=1&libid=1320516325057&out=http%3A%2F%2Fgoo.gl%2FOm9aP&ref=http%3A%2F%2Fwww.handy-faq.de%2Fforum%2Fmotorola_xoom_forum%2F226670-universal_root_fuer_alle_xoom_alle_android_updates.html&title=%5BRoot%5D%20Universal%20Xoom%20Root%20-%20ANY%20XOOM%20ANY%20UPDATE%20-%20xda-developers&txt=here.&jsonp=vglnk_jsonp_13205167407691
Jetzt kopiere es auf deine externe SD-Karte.
3. Einspielen des Recovery-image
1. Lade dieses Recovery image: https://api.viglink.com/api/click?format=go&drKey=1359&loc=http%3A%2F%2Fforum.xda-developers.com%2Fshowthread.php%3Ft%3D1242241&v=1&libid=1320516325057&out=http%3A%2F%2Fbit.ly%2FiLRAIV&ref=http%3A%2F%2Fwww.handy-faq.de%2Fforum%2Fmotorola_xoom_forum%2F226670-universal_root_fuer_alle_xoom_alle_android_updates.html&title=%5BRoot%5D%20Universal%20Xoom%20Root%20-%20ANY%20XOOM%20ANY%20UPDATE%20-%20xda-developers&txt=this&jsonp=vglnk_jsonp_13205169628888
2. Wenn dein Gerät noch gesperrt ist, ist jetzt ein guter Zeitpunkt es zu entsperren.
Code:
fastboot oem unlock
fastboot reboot
Code:
Nachdem du die Bestätigung hast, dass das Image eingespielt wurde, starte dein Gerät neu durch gleichzeitiges Drücken von volume up (lauter) + power (Einschaltknopf).
Nun drücke drei Sekunden nachdem das Motorola-Logo erscheint, den volume down (leiser) Knopf. Du solltest nun die Anzeige "Android Recovery" in der linken oberen Ecke sehen. Drücke den volume up (lauter) Knopf um in den Recovery-Modus zu booten.
4. Einspielen des Xoom-Universal-Root.zip files.
Wenn du jetzt im clockwork mod recovery (Wiederherstellungsmodus) bist, kannst du fortfahren. (Der Clockwork-Recovery-Modus gibt sich als solcher zu erkennen ). Wenn du nicht angezeigt bekommst, dass du dich nicht im „Clockwork mod recovery“ befindest, musst du Schritt 3 wiederholen.
Im cwm (Clockwork mod Wiederherstellungs-Modus), gehe zu "install zip from sdcard" -> "Choose zip from sdcard", dann wähle das Xoom-Universal-Root.zip file das du heruntergeladen hast.
Beachte: Die Lautstärkeknöpfe werden zur Navigation hoch und runter verwendet, der Einschaltknopf zur Auswahl des Menüpunktes.
Starte dein Gerät neu und du hast ein gerootetes Xoom!
Ich habe den oben von Alex@xelA zitierten Thread nur auf die Schnelle frei übersetzt – Er stammt nicht von mir - Ich bin nicht für eventuelle Fehler verantwortlich – es ist euer Xoom !
diphtong
Edesch
ab Punkt 3 versteh ich das nicht mehr
Wo soll ich denn diese Codes eintragen ?
Code:
fastboot oem unlock
fastboot reboot
und
Code:
Diese Image-Datei läßt weder öffnen noch brennen - was soll ich damit machen ?
Kann es sein das ich diese Anleitung irgentwie nicht begreife ?
diphtong
Ergänzend zur Übersetzung hatte ich extra diesen Link https://www.handy-faq.de/forum/motorola_xoom_forum/197485-motorola_xoom_adb_android_sdk_windows_installieren.html
aus dem Anleitungsbereich hinzugefügt.
Hier ist die Benutzung über die Kommandozeile gut erklärt:
"ADB wird komplett über die Eingabeaufforderung bedient. Öffnet diese (Start -> Ausführen -> cmd [Enter] bzw. Start -> Programme/Dateien durchsuchen -> cmd [Enter]) und wechselt in das Verzeichnis, in dass ihr die Android SDK entpackt habt." ...
Viel Erfolg
diph
Edesch
So ich habe es jetzt so gemacht wie beschrieben-aber es geht einfach nicht
Bis hier geht es ja noch alles - siehe Bild
Das Motorola Xoom ist auch auf dem Computer zu sehen mit der Bezeichnung MZ604
Auf dem Tablet steht "Starting Fastboot protocol support"
wenn ich den befehl "fastboot oem unlock" eingebe bekomme ich die Fehlermeldung
Auf diesen Bild sieht man das das MZ604 auf dem Computer nicht mehr zu sehen ist
Was mache ich falsch ?
diphtong
@Edesch
fastboot.exe ist unter C:\android\tools\
adb ist unter C:\android\platform-tools\
Entweder mit cd immer zwischen den Pfaden hin und her switchen, oder den Inhalt des jeweiligen Ordners auch in den anderen kopieren.
diph
Edesch
So,erledigt - aber erst nach dem die Fastboot aus dem Internet runtergeladen habe und in den C:\android\platform-tools\eingefügt hatte.Fastboot war in keinen Ordner drin von Android.Dann ist natürlich logisch das es nicht geht.
Hat alles bestens geklappt
JoeBlackX
hi,
danke für die anleitungen, aber da ich ein skeptischer mensch bin und mein xoom nicht schrotten will mal die frage, hat das schon jemand mit einem motorola xoom wifi only mit android 3.2.1 (kein us model) ausprobiert (erfolgreich?!)
ansonsten, wie gehts mit dem root zugriff bei dem genannten model??
gruss JB
Edesch
hi,
gruss JB
Ja meins ist ein wifi only mit android 3.2 -deutsche version - und es geht wunderbar - vom root zugriff ist so nicht viel zu bemerken - außer das superuser drauf ist
Dusty-Peter
Guten Tag,
ich würde gern das Universal Xoom Root vornehmen, habe aber Bedenken ob es danach noch möglich ist das Update auf Android 3.2, welchen mittlerweile angekündigt ist, durchzuführen. Ein Backup ist mir, so wie ich es hier nach längerer Recherche verstanden habe, warscheinlich vorher ohne das Gerät zu Rooten, nicht möglich. Beim Rooten wird das 3.1 gegen das 3.01 Android ersetzt.
Deshalb meine Frage: Gibt es schon ein stock Rom vom Xoom mit Android 3.1 EU ?, damit ich notfalls den Orginalinhalt wieder zurückspielen kann.
Im Motorola-Forum befinden sich nur die 3.01 er Rom´s
Hoffe, dass mir jemand helfen kann.
Dusty-Peter
H@ns
das würde mich ebenfalls interessieren.
Kann da bitte jemand etwas dazu sagen?
Hans
Dusty-Peter
Danke Bernhard, wäre ja auch zu schön, wenn es so gehen würde wie man es möchte. Dann werde ich mal auf die 3.2 warten und erst dann wieder rooten.
D-P
H@ns
auf meinem XOOM habe ich die Bild Nr.: H.6.3-25-9.
Dieses ist bei MZ601 - XOOM with Wi-Fi + UMTS nicht als Device Software Image aufgeführt.
Ich habe Android Version 3.1 drauf.
Kann ich gefahrlos ein anderes nehmen? Welches käme infrage?
-- Build H.6.1-38-5 for T-Mobile Germany ?
Hans
babfe
Hans
Spiel Dir das Eu Retaill drauf. Das von t-online würde ich nicht nehmen.
