timo82
OverTheAir funktioniert auf jeden Fall problemlos.
Bei mir (Win7, 64bit) ist es mit der PC Software katastrophal. Verbindungsfehler, Abstürze...
Spalato
Hi. Ich schreibe Deutsch nicht so gut aber kan lesen und verstehn so ich schreibe in Englisch. Sorry :)
I have followed the flashing manual for P880 from the first post of thos topic and I'm stuck in download mode now...
I get this error all the time:
Can you help me and explain how to fix this error. Flashing allways stops
You can write in German or English.
Thank you in advance for an answer
gotchaa
i got the same error, when i followed the instructions on the first page...
dont remove the battery before setting the phone in upgrade mode, this worked for me.
bye
Spalato
I have spent yesterday all afternoon and almost all day today but I keep getting the same error on 20% flashing :(
Phone was working before flashing and now is always in download mode...
gotchaa
can u do a factory reset? Press Vol- and Power together to turn on the phone, then u get into menu to do so.
mine was always fine after aborted flashing, started without problems.
an other user wrote that he had to keep the phone running und activate USB Debug Mode to succesfully flash it (while running), maybe this method works for you?! (if u can do the factory reset)
Spalato
thanks for your answer but I can't because after I flashed the phone first time, it stopped first time at 20% and since than it does not go more than 20% and now if I turn on the phone, it starts automaticly in SW Upgrade mode.. also, volume down button and ON button make the same, SW Upgrade mode... whatever I do, it starts in SW Upgrade more :(
timo82
Dieser LG Updater hat bei meinem P990 nie funktioniert, deshalb die Frage. Da hat LG noch Arbeit vor sich.
Der funktionierte auch schon beim LG arena vor zig Jahren nicht!
@ Spalato: do you have a second computer? I got problems with the drivers and some errors on my computer, too.
My system is a 64bit version of windows seven.
On a 32bit system it worked better. Not without problems, but it worked.
Spalato
thx... i work here in a gsm repair store and we have more computers and i tried on all of them and same problem... i will try at home over the weekend on my two computers which don't have zillion drivers and other stuff for mobile phones installed...
last week flashed a P990 without problems :)
andreas90
Bei wird das B2C Programm nicht installiert, was kann ich machen?
Das Programm B2C startet jetzt.
Jetzt bleibt das Update bei 5% stehen und geht einfach nicht weiter
Jetzt versuche ich es mit einem Vista Rechner und es bleibt bei 10% stehen
bearbeitet von chimalia
Spalato
Hello again...
I'm getting slightly crazy with this phone. Here is the log:
[R&D Test Tools Log File]
11:49:04 : Start fn_StartUpgrade
11:49:04 : Extract kdz file
11:49:59 : kdz decrypt Success
11:50:18 : Extract file Success.
11:50:18 : LGMobileDL Load.
11:50:29 : Port = 0
11:50:39 : Connection check start.
11:50:53 : Check Phone mode = 2
11:50:53 : Phone type check.......
11:50:59 : LGMobileDL.DLL Loading....
11:51:00 : _SetAuthMark Fail
11:51:00 : _SetAuthMark Ok : wAuthMark(65535)
11:51:00 : _DetachDLL Call
11:51:00 : _DetachDLL Call End
11:51:00 : Param : Path = C:\Documents and Settings\All Users\Application Data\LGMOBILEAX\Phone\LGP880AT-00-V10d-EUR-XXX-JUL-16-2012+0.dz
11:51:00 : Param : moduleDir =
11:51:00 : Param : waitTime = 1701672291
11:51:00 : Param : UsbHighSpeed = 1
11:51:00 : Param : PhoneMode = 2
11:51:00 : Param : BinVersion = V10D_00
11:51:00 : Param : AuthMark = 65535
11:51:00 : Call fn_StartUpgrade
11:51:00 : 3GQCT : wParam = 2005, lParam = 0
11:51:00 : 3GQCT : wParam = 2005, lParam = 4
11:51:00 : 3GQCT : wParam = 2005, lParam = 5
11:51:00 : 3GQCT : wParam = 2003, lParam = 5
11:51:10 : 3GQCT : wParam = 2005, lParam = 6
11:51:10 : 3GQCT : wParam = 2005, lParam = 7
11:51:10 : 3GQCT : wParam = 2003, lParam = 3015
11:51:10 : 3GQCT : wParam = 2003, lParam = 1
11:51:11 : 3GQCT : wParam = 2005, lParam = 8
11:51:11 : 3GQCT : wParam = 2005, lParam = 9
11:51:11 : 3GQCT : wParam = 2003, lParam = 3
11:51:11 : 3GQCT : wParam = 2005, lParam = 10
11:51:11 : 3GQCT : wParam = 2007, lParam = 0
11:51:11 : 3GQCT : wParam = 2003, lParam = 201
11:51:11 : 3GQCT : wParam = 2003, lParam = 401
11:51:11 : 3GQCT : wParam = 2003, lParam = 200
11:51:11 : 3GQCT : wParam = 2003, lParam = 202
11:51:11 : 3GQCT : wParam = 2003, lParam = 203
11:51:15 : 3GQCT : wParam = 2003, lParam = 204
11:51:15 : 3GQCT : wParam = 2005, lParam = 10
11:51:28 : 3GQCT : wParam = 2003, lParam = 205
11:51:28 : 3GQCT : wParam = 2005, lParam = 10
11:51:28 : 3GQCT : wParam = 2003, lParam = 206
11:51:28 : 3GQCT : wParam = 2003, lParam = 207
11:51:29 : 3GQCT : wParam = 2003, lParam = 208
11:51:29 : 3GQCT : wParam = 2005, lParam = 10
11:51:29 : 3GQCT : wParam = 2003, lParam = 210
11:51:29 : 3GQCT : wParam = 2003, lParam = 230
11:51:29 : 3GQCT : wParam = 2003, lParam = 250
11:51:29 : 3GQCT : wParam = 2003, lParam = 270
11:51:29 : 3GQCT : wParam = 2003, lParam = 290
11:51:29 : 3GQCT : wParam = 2003, lParam = 310
11:51:29 : 3GQCT : wParam = 2003, lParam = 211
11:51:29 : 3GQCT : wParam = 2003, lParam = 231
11:51:30 : 3GQCT : wParam = 2003, lParam = 251
11:51:30 : 3GQCT : wParam = 2005, lParam = 10
11:51:30 : 3GQCT : wParam = 2003, lParam = 271
11:51:30 : 3GQCT : wParam = 2003, lParam = 291
11:51:31 : 3GQCT : wParam = 2003, lParam = 311
11:51:31 : 3GQCT : wParam = 2005, lParam = 10
11:51:32 : 3GQCT : wParam = 2003, lParam = 212
11:51:32 : 3GQCT : wParam = 2005, lParam = 10
11:51:32 : 3GQCT : wParam = 2003, lParam = 232
11:51:32 : 3GQCT : wParam = 2003, lParam = 252
11:51:32 : 3GQCT : wParam = 2003, lParam = 272
11:51:32 : 3GQCT : wParam = 2003, lParam = 292
11:51:34 : 3GQCT : wParam = 2005, lParam = 11
11:51:36 : 3GQCT : wParam = 2003, lParam = 312
11:51:36 : 3GQCT : wParam = 2005, lParam = 11
11:51:36 : 3GQCT : wParam = 2003, lParam = 213
11:51:36 : 3GQCT : wParam = 2003, lParam = 233
11:51:36 : 3GQCT : wParam = 2003, lParam = 253
11:51:36 : 3GQCT : wParam = 2003, lParam = 273
11:51:36 : 3GQCT : wParam = 2003, lParam = 293
11:51:39 : 3GQCT : wParam = 2003, lParam = 313
11:51:39 : 3GQCT : wParam = 2005, lParam = 11
11:51:39 : 3GQCT : wParam = 2003, lParam = 214
11:51:39 : 3GQCT : wParam = 2003, lParam = 234
11:51:39 : 3GQCT : wParam = 2003, lParam = 254
11:51:39 : 3GQCT : wParam = 2003, lParam = 274
11:51:39 : 3GQCT : wParam = 2003, lParam = 294
11:51:39 : 3GQCT : wParam = 2005, lParam = 12
11:51:44 : 3GQCT : wParam = 2005, lParam = 13
11:51:48 : 3GQCT : wParam = 2005, lParam = 14
11:51:53 : 3GQCT : wParam = 2005, lParam = 15
11:51:58 : 3GQCT : wParam = 2005, lParam = 16
11:52:02 : 3GQCT : wParam = 2005, lParam = 17
11:52:06 : 3GQCT : wParam = 2005, lParam = 18
11:52:11 : 3GQCT : wParam = 2005, lParam = 19
11:52:16 : 3GQCT : wParam = 2005, lParam = 20
11:52:20 : 3GQCT : wParam = 2005, lParam = 21
11:52:24 : 3GQCT : wParam = 2005, lParam = 22
11:52:25 : 3GQCT : wParam = 2003, lParam = 314
11:52:25 : 3GQCT : wParam = 2005, lParam = 22
11:52:25 : 3GQCT : wParam = 2003, lParam = 399
11:52:25 : 3GQCT : wParam = 2003, lParam = 400
11:52:25 : 3GQCT : wParam = 2003, lParam = 403
11:52:25 : 3GQCT : wParam = 2003, lParam = 1
11:52:25 : 3GQCT : wParam = 2010, lParam = 18
And it stops here every time :(
@Spalato
Your LOG looks normal.
Just wait until your phone is restarted.
Regards
andreas90
So wie es in der Anleitung unter Punkt 8 beschrieben steht funktioniert es nicht
Nun muss das P880 in den S/W Upgrade-Modus setzen (Akku entnehmen, Lautstärke nach unten Taste drücken und das USB-Kabel mit dem PC verbinden)
Ich habe meinen Akku in dem Gerät lassen müssen, jetzt funktioniert es
So die Software ist jetzt installiert
Danke für den Hinweis!
Habe es grade selbst mal getestet und die Anleitung entsprechend abgeändert.
andreas90
Aber wo finde ich um das Handy in den Werkzustand zu versetzen. Ich finde den Punkt " Datenschutz" nicht
Den Punkt findest du hier:
Anwendungen --> Einstellungen --> Sicherung und Zurücksetzen --> Speicher zurücksetzen
Muss man das machen?
Ja, du solltest es tun.
Nur so ist dein Smartphone wieder im vorgegeben "Standard-Zustand" der Firmware.
aiinc
So ich muss jetzt nochmal nachfragen ...
Darf ich davon ausgehen, dass das (siehe Anhang)
der Upgrade Modus ist ?
Falls ja, dann habe ich die USB-Treiber korrekt installiert jedoch findet das Updateprogramm das Telefon einfach nicht.
Wie es in Deiner Beschreibung steht ist im Logfile des Updateprogrammes eine Verbindung erfolgreich
10:07:56 : _IsConnectedPhone Call
10:07:56 : _IsConnectedPhone(1)
10:07:56 : 0 - NotConnected.
10:07:56 : 1 - Normal connect success
10:07:56 : 2 - Emergency connect success
Bei mir verbindet er sich einfach nicht mit dem Telefon, trotz installierter Treiber.
Habe Windows 7 64-Bit mit SP1. Habe auch die 32-Bit Version von Windows 7 ausprobiert. Gleiches Problem. :icon_eek:
Das einzige was funktioniert ist, dass wenn ich das Telefon ganz im normalen Betrieb connecte findet er es mit
Das bringt mir ja aber in einem Notfall garnichts, wenn er im S/W-Upgrade Modus das Telefon nicht mehr findet :icon_chee
Hast DU vielleicht noch einen Tip ? Oder kannst Du mir sagen, was bei Dir das Programm in der Zeile
10:07:56 : LGE USB Driver Version :
auswirft ? :icon_smil
Vielleicht hab ich auch was Konkretes übersehen.
Danke im Voraus,
Gruß aiinc
[B]LOG Auszug[/B]
10:07:55 : [C:\LGMobileUpgrade] Try to delete folder
10:07:55 : RemoveDirectory1 Error(2):C:\LGMobileUpgrade
10:07:55 : Start Date : 2012-08-11 10:07:55
10:07:55 : ---------- QM Testmode ---------
10:07:56 : ***** Check Tool Version *****
10:07:56 : Tool version : 1.5.4.8
10:07:56 : UpgradeDLL version : 1.2.6.7
10:07:56 : Current Dir : C:\ProgramData\LGMOBILEAX\B2C_Client
10:07:56 : Android PDLV Version :
10:07:56 : Android NDLV Version :
10:07:56 : ******************************************
10:07:56 : [C:\ProgramData\LGMOBILEAX\Phone] Try to delete folder
10:07:56 : RemoveDirectory1 Error(2):C:\ProgramData\LGMOBILEAX\Phone
10:07:56 : SetEmerModeAT()
10:07:56 : _IsConnectedPhone(0)
10:07:56 : *****CheckOS Start********
10:07:56 : Microsoft_Windows7_Professional_Service Pack 1
10:07:56 : *****CheckPCSyncPrograms Start*****
10:07:56 : PCSyncPrograms Not Found - OK and ready to upgrade
10:07:56 : Checking the connection with the cell phone...
10:07:56 : dwWaitResetTime(40000 ms)
10:07:57 : _IsConnectedPhone Call
10:07:57 : _IsConnectedPhone(0)
10:07:57 : 0 - NotConnected.
10:07:57 : 1 - Normal connect success
10:07:57 : 2 - Emergency connect success
10:07:58 : _IsConnectedPhone Call
10:07:58 : _IsConnectedPhone(0)
10:07:58 : 0 - NotConnected.
10:07:58 : 1 - Normal connect success
10:07:58 : 2 - Emergency connect success
10:07:59 : _IsConnectedPhone Call
10:07:59 : _IsConnectedPhone(0)
10:07:59 : 0 - NotConnected.
10:07:59 : 1 - Normal connect success
10:07:59 : 2 - Emergency connect success
10:07:59 : [009,400,102,102,102]The USB cable and your cellphone are not connected.\nPlease connect your phone and wait for connecting \nthe USB port for a while and press the [009,700,147,062,092]'Restart'[009,400,102,102,102] button.
10:08:04 : Check Cancel button active..
10:08:04 : !pUpgrade->StartProcessing ... PostMsg STEP_TYPE_ENV_ERROR
10:08:04 : Page_Error ºÎºÐÀÔ´Ï´Ù
10:08:04 : [011,700,147,062,092]LG Mobile Phone Software  Update was canceled\n\n[009,400,102,102,102]To quit LG Mobile Phone Software  Update, please press the [009,700,147,062,092]Exit[009,400,102,102,102] button below.
10:08:04 : OnStepMsg STEP_TYPE_ENV_ERROR delete m_pLGCyonUpdate
bearbeitet von Horst77
