weissnixifx
medion p9514 TOT.. wird nach APX Treiber verlangt
daddle
added tot the Medion P9514 BackUp Drive
and changed filename to recovery.txt___DO_NOT_USE & recovery.zip___DO_NOT_USE
Hi dj4n90,
Why this? The name should be changed to recover-ics-bootloader only, because that is what this recovery.zip does! The name is disguising, that`s all. You can use it, but not for recovering "recovery", but recovering the ics-bootloader!
1.First: The "recovery.sh" seems to boot temporarily a kernel and recovery, then it flashes the ics-bootloader only! (This applies for Linux User!)
2.Second: You can extract out of the recovery.zip the kernel- and recovery.img (both ICS) and flash them in fastboot-mode. (same with sos.zip possible, also the HC3.2-img`s!) (For Linux and Windows-User)
3.Third for Windows-User: Therefore type at a windows command-prompt following commands, your Tab booted in Android and connected per USB to a Windows-PC, your Medion-ADB drivers installed: (Not for the deodexed rom!)
1. adb devices               ------  wait for Serial-number, then
2. adb reboot-bootloader     ------  wait for an almost dark screen, not APK but "bootloader"!, then
3. fastboot devices          ------  wait for the line: ´?.......fastboot`
If this line does not appear, but instead <waiting for device>, leave the command-prompt-window open, go to device-manager and tab > AndroidPhone > Drivers > Install drivers > Search on this computer for Drivers > Choose from a list of drivers on this Computer > In left little window choose "Medion" > In the right little window "Android Bootloader Interface" > Install, and you have additionally to your previously installed Medion-ADB drivers the fastboot-driver successfully installed. Then repeating in command-window at the prompt, or eventually open a new command prompt:
3:  fastboot devices      ----  wait for the line:  "?.......fastboot"    and now:
4:  fastboot -i 0x0408 flash recovery recovery.img  .... takes 1-2 seconds, or
4a: fastboot -i 0x0408 flash boot boot.img) ... take boot.img from [URL="https://drive.google.com/folderview?id=0BxHszU6N6GtlY1JtSkZFSkExblE&usp=drive_web&tid=0BxHszU6N6GtlR2pNOVVIQi1hbHM#list"]last MD_LIFETAB_P9514.20120719.2-ICS-signed-ota-update.zip[/URL]
5: fastboot continue       .... and your Tab will reboot into Android with the
 original recovery (or kernel) replaced!
Follow little Root-Tut with cydia-impactor, it works definitely and precisely on your P9514!
daddle
bearbeitet von daddle
Link-Ergänzung
daddle
Hi dj4n90,
did you manage to get your tab running smoothly with the sos.zip ?
After deinstalling and derooting deodexed rom and CWM, I fiddled too much with permissions while testing my gps- config´s,
tested in HC 3.2 (worked fine with the original config´s!), in deodexed rom GPS made a lot of problems!, then copied different
drivers and radio from HC to ICS (did not work properly), so flashed with the sos, reflashed ota and rooted with
Cydia-Impactor again, and from then on everything works fine! regards daddle
daddle
and changed filename to recovery-ics-bootloader_stock.txt & recovery-ics-bootloader_stock.zip
Hi dj4n90,
I found a minor error in the recovery-ics-bootloader_stock.zip; the included boot.img is outdated, it is from the first or second update release for ICS 4.03. But, to get hasselfree WLan, we need the boot.img from ICS Update Release 3 (Last Version).
The older boot.img caused a faulty WLan, thats why you have to reflash the last Lifetab_p9514.20120719.2-ICS-signed-ota-update.zip to get Wlan working, everytime after making use of the recovery-function, and to root again!
This is not needed anymore, if you correct your download-file with this corrected Version. I replaced the older boot.img with the last one, and no more WLan-error anymore after using the corrected recovery.zip.
Please be so kind and update your download with the corrected version. Download-Link:
https://drive.google.com/file/d/0B0lQtpsqLGsYaXRSRE51Ql9GcG8/view?usp=sharing
Second, may I advise you to remove the older Lifetab_p9514.20120703.8-ICS-signed-ota-update.zip in the Rom_ICS_Ota-section.
These one is not necessary anymore, it is still a bit buggy, and the latest Lifetab_p9514.20120719.2-ICS-signed-ota-update.zip is complete incl. blob, and also allows the update from HC3.2 --> ICS4.03!
regards, en prettige kerstdagen daddle
DonSchubi
Hallo ich greife mal diesen Thread auf.
Folgendes Problem nachdem mein Schwiedervater das Tab aus Android zurücksetzten wollte hat es sich aufgehangen... dann hat er es nach etwas googeln in den APX modus versetzt. Ich will das Tablet wieder zum Starten bringen ohne eine Custom ROM aufzuspielen oder das Gerät rooten. Dafür benötige ich eure hilfe.:) Ich habe von Sattnek die Anleitung  aus dem Drive Archiv befolgt. Raus gekommen ist folgende ptable.txt
Spoiler
PartitionId=2
Name=BCT
DeviceId=18
StartSector=0
NumSectors=1024
BytesPerSector=4096
PartitionId=3
Name=PT
DeviceId=18
StartSector=1024
NumSectors=512
BytesPerSector=4096
PartitionId=4
Name=EBT
DeviceId=18
StartSector=1536
NumSectors=512
BytesPerSector=4096
PartitionId=5
Name=GP1
DeviceId=18
StartSector=2048
NumSectors=512
BytesPerSector=4096
PartitionId=6
Name=SOS
DeviceId=18
StartSector=2560
NumSectors=2048
BytesPerSector=4096
PartitionId=7
Name=LNX
DeviceId=18
StartSector=4608
NumSectors=2048
BytesPerSector=4096
PartitionId=8
Name=MFG
DeviceId=18
StartSector=6656
NumSectors=2560
BytesPerSector=4096
PartitionId=9
Name=APP
DeviceId=18
StartSector=9216
NumSectors=131072
BytesPerSector=4096
PartitionId=10
Name=CAC
DeviceId=18
StartSector=140288
NumSectors=131072
BytesPerSector=4096
PartitionId=11
Name=MSC
DeviceId=18
StartSector=271360
NumSectors=512
BytesPerSector=4096
PartitionId=12
Name=USP
DeviceId=18
StartSector=271872
NumSectors=35840
BytesPerSector=4096
PartitionId=13
Name=UDA
DeviceId=18
StartSector=307712
NumSectors=7451648
BytesPerSector=4096
PartitionId=14
Name=GPT
DeviceId=18
StartSector=7759360
NumSectors=512
BytesPerSector=4096
daddle
@DonSchubi
<<<<<<du kannst dein Lifetab hiernach recovern:
Link entfernt!  ( von einem übereifrigen Mod!)
OK kein direkter Link, welch ein Blödsinn. Dieses P9514-Forum hier lebte vor 5 Jahren von der Interaktion zwischen Teilnehmern in Android-Hilfe und in handy-faq!
In Android-Hilfe im Medion Forum im Thread "lifetab-startet-nicht-mehr-nur-noch enter-ota-recovery", Post 34 auf Seite 2!
( www.android-hilfe.de/thema/lifetab-startet-nicht-mehr-nur-noch-enter-ota-recovery.261787/page-2)
Hier kannst Du die Datei LTrecHCtar,gz im Verzeichnis Rom_HC_apx runterladen. https://drive.google.com/drive/folders/0BxHszU6N6GtlR2pNOVVIQi1hbHM
Vielleicht hilft es dir noch, gruss, daddle
Link entfernt!
Join the conversation
Auf dieses Thema antworten...
  Only 75 emoji are allowed.
