[ROM] Viper10 ◦ Tweaks | HUB | OTA | Sidebar und mehr
adröidler
die habe ich geflasht (wieder im .txt in der .zip die MID angepasst).
fw ist drauf aber das tool bringt immer noch den gleichen fehler egal ob aus dem DL oder aus dem RUU-Mode
Warum hast du die mid angepasst?
Du hattest deine mid doch bereits geändert.
Was stand vorher in der zip?
Gesendet von meinem HTC 10 mit Tapatalk
adröidler
weils nicht gepasst hat
modelid: 2PS650000
" das stand original im .txt in der .zip
"C:\Android\com>fastboot flash zip PMEWL_2.28.617.8_FullStock.zip
target reported max download size of 1579200000 bytes
sending 'zip' (148355 KB)...
OKAY [  5.768s]
writing 'zip'...
(bootloader) HOSD CL#831921
(bootloader) ERR Model ID not matched
(bootloader) ERR [SD_UPDATE_ERR] MODEL ID NOT ALLOWED
(bootloader) ERR [SD_UPDATE_ERR] sddownload failed: 10
(bootloader) ERR Update zip file failed.
(bootloader) Update zip file OK
(bootloader) ERR ZIP ERROR CODE, 10
(bootloader) end@Done
FAILED (remote: 10 RU_MODELID_FAIL modelid in android-info mismatched )
finished. total time: 8.362s
C:\Android\com>fastboot oem readmid
(bootloader) mid: 2PS65000
OKAY [  0.099s]
finished. total time: 0.100s"
OKAY [  5.737s]
writing 'zip'...
(bootloader) GPT (gpt_main_32g.img) is up-to-dated. [17408]
(bootloader) Perform pre-update
(bootloader) WARN Skip partition_info due to unmatched partition name
(bootloader) get 39 images from zip(zip_type=3)
(bootloader) start@39
(bootloader) aboot_signed.img@100%
(bootloader) adsp.img@BYPASS
(bootloader) apdp-8996-1.img@BYPASS
(bootloader) apppreload.img@BYPASS
(bootloader) boot.img@BYPASS
(bootloader) cache.img@BYPASS
(bootloader) cmnlib32.img@100%
(bootloader) cmnlib64.img@100%
(bootloader) cota.img@BYPASS
(bootloader) cradio.img@BYPASS
(bootloader) cs_CY8C.img@BYPASS
(bootloader) devcfg-8996-1.img@100%
(bootloader) dsp.img@BYPASS
(bootloader) dzdata_32g.img@BYPASS
(bootloader) fsc.img@BYPASS
(bootloader) hosd_signed.img@100%
(bootloader) hyp-8996-1.img@100%
(bootloader) keymaster.img@100%
(bootloader) lksecapp.img@100%
(bootloader) modemst1.img@BYPASS
(bootloader) modemst2.img@BYPASS
(bootloader) pg2fs_ship_signkey.img@100%
(bootloader) pmic-8996-1.img@100%
(bootloader) rcdata.img@BYPASS
(bootloader) recovery.img@BYPASS
(bootloader) rfg_2.img@BYPASS
(bootloader) rfg_3.img@BYPASS
(bootloader) rpm-8996-1.img@100%
(bootloader) sensor_hub.img@BYPASS
(bootloader) slpi.img@BYPASS
(bootloader) splash1.nb0@BYPASS
(bootloader) tp_SYN3708.img@BYPASS
(bootloader) tz-8996-1.img@100%
(bootloader) usb_typec.img@BYPASS
(bootloader) usb_typec_otp.img@BYPASS
(bootloader) usb_typec_otp_ad.img@BYPASS
(bootloader) venus.img@BYPASS
(bootloader) xbl-8996-1.img@100%
(bootloader) radio.img@BYPASS
FAILED (remote: 90 hboot pre-update! please flush image again immediately )
finished. total time: 8.210s"
< waiting for device >
OKAY [  6.688s]
writing 'zip'...
(bootloader) adsp.img@100%
(bootloader) apdp-8996-1.img@100%
(bootloader) apppreload.img@100%
(bootloader) boot.img@100%
(bootloader) cache.img@100%
(bootloader) cota.img@100%
(bootloader) cradio.img@100%
(bootloader) dsp.img@100%
(bootloader) dzdata_32g.img@100%
(bootloader) fsc.img@100%
(bootloader) modemst1.img@100%
(bootloader) modemst2.img@100%
(bootloader) rcdata.img@100%
(bootloader) recovery.img@100%
(bootloader) rfg_2.img@100%
(bootloader) rfg_3.img@100%
(bootloader) slpi.img@100%
(bootloader) splash1.nb0@100%
(bootloader) venus.img@100%
(bootloader) radio.img@100%
OKAY [ 22.922s]
finished. total time: 29.611s"
edit:
C:\Android\com>fastboot oem writemid 2PS65000
OKAY [  0.185s]
finished. total time: 0.187s
OKAY [  0.004s]
finished. total time: 0.006s
FW erneut mit original .txt in .zip geflasht
mache jetzt erneut den RUU vorgang
bearbeitet von adröidler
Fuck... die mid die ich dir genannt hatte, hat am Ende eine Null zu wenig.
Daher gehts mit der RUU nicht.
Sorry...
Bitte also deine mid nochmal neu schreiben.
fastboot oem writemid 2PS650000
Edit:
Habe es in meinen ersten Beitrag korrigiert, damit nicht noch jemand anderes die falsche mid benutzt.
Sorry nochmals, dass da eine Null gefehlt hat.
adröidler
also MID angepasst " 2PS650000"
FW erneut geflasht
jetzt das RUU laufen lassen - done (hell-yeah!!!)
wie weiter?
stock rom booten - check
recovery flashen - check
rom mit full-wipe flashen - check (ohne haken bei disable force encryption)
Nachdem das Stock ROM, mit Android N hoffentlich bootet.
Nun wieder in den Download Mode booten und dort twrp flashen:
https://forum.xda-developers.com/devdb/project/dl/?id=22034
fastboot flash recovery Name_der_Recovery.img
Diese Version, kann den internen Speicher entschlüsseln.
Daher ist ein formatieren von Data nicht mehr nötig.
Nach dem flashen der Recovery, kannst du die ROM dann mit Full wipe flashen.
Hoffentlich war es das dann und du kannst endlich die Viper nutzen. :D
adröidler
TWRP hat nun read&write Rechte.
beim flashen des Roms kann ich ja nun den Haken bei "disable force encryption" rausnehmen oder?
hatte die rom bereits so geflasht, aber nach dem booten war ich auf stock Android N
habs jetzt grad nochmals so geflasht und teste nun nochmals...dasselbe Ergebnis.
bekomme im TWRP eben auch den Fehler "failed to unmount /system (Device or resource busy) & dasselbe mit "failed to mount /system)
Geh mal in twrp auf "Mount" und mach den Haken bei "System" mal weg.
Und versuche es dann nochmal.
adröidler
ok hab ich gemacht. haken war zwar nicht drin. konnte ihn aber rein machen und wieder raus nehmen.
habe aber auch jetzt nach dem flashen der rom wieder das stock boot logo...
edit: jope ist immer noch stock
adröidler
ok andere version von twrp geflasht
data formated
rom mit full wipe geflasht (mit haken bei "disable force enc")
vom Logo her siehts bis jetzt gut aus :D hoffe die bootet nun mal endlich durch ^^
Daumen drück [emoji3]
Wie viele Dinge hier doch so zusammengekommen sind.
Klasse, dass du durchgehalten hast.
adröidler
Besten Dank Stefan
die ROM ist nun erfolgreich installiert. :-)
nun gehts ans einrichten  :~)
Yeah... ging ja fix. :)) und total einfach :D
Viel Spaß mit dem ROM.
Balha1977
Hi @Black-FR, ist der bug im neuen TWRP (was du zuvor dem User angeboten hast) behoben, so das man die neue FW zusammen mit dem neuen  TWRP nutzen kann?
Wollte wenn dann alles sauber und ohne bigs flashen.
adröidler
Kommt wohl auf die Version an. Bei der einen konnte ich die rom nicht flashen, müsste jedoch die data nicht formaten; bei der die ich jetzt nutze ist es umgekehrt.
Aktuell funktioniert nur die 3.0.2-7_debug Version, von twrp, mit der neuen Firmware.
Diese Version, kann den internen Speicher nicht entschlüsseln, wenn dieser verschlüsselt ist.
Balha1977
Moin moin,  danke an euch beide für das Feedback.
Wie schon mal erwähnt, habe ich momentan (alte FW +TWRP und Rom) alles perfekt am laufen,  mit den Einstellungen die haben möchte und würde zu ungern alles resetten bzw. formatieren, daher warte ich noch ab bis alles so verfügbar ist das man ohne wipe alles aktualisieren kann und vor allem das TWRP komplett alles unterstützt.
bearbeitet von balha1977
Andy123438
kurze Frage, bei mir funktioniert das NFC mit der Version 4.2.0 nicht mehr. Kann das jemand bestätigen?
Habe die Firmware 2.28.401.9 mit TWRP 3.0.2-7_debug und Viper 4.2.0 am Laufen.
Vielen Dank für Eure Hilfe.
LG Andy123438
