[Rom] ViperOneM9 - Tweaks | HUB | Sidebar | OTA
Klo-Sa3uf3r
vor 19 Stunden, Black-FR said:
Download Link, findest du hier:
https://venomroms.com/htc-one-m9/
Und ein Full wipe ist zwingend erforderlich.
Gesendet von meinem HTC 10
Hat mich bissel verwirrt, wegen " Latest HTC10 based Rom: "
fw passt auch?
Update auf v5.1.0 ist als Full ROM verfügbar:
ViperOneM9 5.1.0
(24th September)
Additions & Updates
  • Rebased on 1.95.401.3
  • Visual theming - Tap item to change its color
    • Notification area: Header, Horizontal Quicksettings, Notifications, Weather
    • Native Quicksettings
    • Volume Dialog
      OUuAQX55V9o
    [*] Temperature Infoline
    • Battery
    • CPU
    • GPU
    • Thanks for the extra work you sons of murricans. Supports Fahrenheit - Setting is pulled from the HTC Weather app.
    [*] Theme Brigthness Slider
    • Slider
    • Thumb
    • Autobrightness button
    [*] Additional animations scales in Settings->Developer Options->Advanced
    [*] Collapse Statusbar when pressing a quicksettings tile
    [*] Color background of brightness slider mirror
    [*] Color brightness slider thumb
    [*] Option to hide labels in the appdrawer
    [*] Infinite scrolling on homescreen
    [*] Increased default power doublepress interval to 300ms, so you slow old guys can trigger the camera action more easily
    [*] Add additional option to add shortcuts into the Homescreen menu. Shortcuts = direct call, bookmarks etc.
    [*] Configure update interval of traffic icon
    [*] Option to disable Notification LED (useful if you use button light notifications)
    [*] Option to disable LED's when on DND (Notification LED and Button Lights Notification LED's)
    [*] Option to disable Charging LED on DND
    [*] Toggle to prevent camera acquiring maximum screen brightness when opening it
    [*] Signal strength icon for statusbar
    • dBm or ASU level option
    • Custom color
    [*] Added CM ScreenRecorder App
    [*] ScreenRecorder Tile to start/stop screen cast
Fixes & Cleanups
  • Fixed some shortcuts not working for the Sense Home Menu
  • Fixed notification background color not applying
  • Fixed "Add to home" FC on Sense Home Menu
  • Fixed custom autobrightness "Normal" Profile not applying in VenomTweaks
  • Fixed hidden app labels on homescreen appearing again after reboot
  • Fixed crash when enabling "Hide Navbar on press" option without setting keys to hide it
  • Some minor fixes in VenomTweaks
Since its a new base (again) with quite some changes there won't be an OTA Update.
Fullroms:
AndroidFileHost
German Mirror
adröidler
Komische Sache, habe bei meinem one m9 gestern die 5.1.0 geflasht und nun fehlen mir die 3 buttons unten am Display. Was ist da falsch gelaufen?
Gesendet von meinem HTC 10 mit Tapatalk
Venom tweaks -> navigation bar -> navigation bar type
Aktivier dort die Stock-navbar.
adröidler
nice. läuft :-)
Es gibt ein neues Update :
ViperOneM9 5.2.0
(17th October)
Additions & Updates
Special Thanks [MENTION=4165809]thicklizard[/MENTION] for his work on carriers support
  • VenomHUB Update:
    • Venom HUB Web Store: Download apps, themes and addons to your desktop
    • Install apps, themes and addons from your desktop browser directly on your device(like it works with the play.google.com)
    • Addons, themes and other items can show linked items(f.e. you will see if some addons are compatiable with theme)
    • Minor UI improvemnets in WEB HUB and in HUB App
    [*] Add "Clear recents apps" mapping to button actions and three finger gesture
    [*] Add doubletap statusbar action to scroll content to the top
    DdyQmDPc9qc
    [*] Disable Vibration system wide
    [*] Allow haptic feedback during powersaver
    [*] Set media volume as default when using the volume rocker
    [*] Updated SuperSU to v2.78 SR1 (full ROM only) Credits to [MENTION=631273]
    Chainfire
    [/MENTION]
Fixes & Cleanups
  • Fixed HTC Music FC when using HTC car app (full rom only)
Available as OTA:
via Settings->About->Software update / VenomTweaks->Advanced->OTA Update.
Information regarding the VenomHUB Store:
Ensure you open VenomHUB once before, to resync the account (If it doesn't work, go to Settings->Sync & Accounts->Venom press the 3 dots on the top right and sync)
You can access the Web store on https://hub.venomroms.com. ensure you relogin after syncing the VenomHub on your device.
If you don't see the store on the Web Hub, it cached the old version. Press ctrl+f5 to hardreload the page.
To remote install, you simply hit install on the items you want to install and then on the bottom right theres a circle with down arrow you need to click, to start the installation.
After pressing it, you'll get a popup on your HTC One M9 to install the requested items
Es gibt ein Update:
ViperOneM9 5.3.0
(14th November)
Additions & Updates
  • Merged with 1.95.401.4 base
  • Custom apm backgrounds
  • Color 'No Notifications' text
  • Color Clear text and button
  • Themes can now use a theme.prop in /system/customize/ (again) to preset colors values
  • Caffeine tile now shows a toast message when the labels are hidden for neqs
  • Theme the advanced power menu
    • Background
    • Item title color
    • Item summary color
    • Icon color
    [*] New Venom Package Installer(Replaced system package installer)
    • Install apps in background(progress in notification)
    • Install multiple apps at the same time.
    • Show proper reason, when some app is not installed
    • Button to ignore overlay detection
    [*] Optimized caching in VenomHUB, loading will be faster now
    [*] Option to show battery temperature in battery percentage info line
    [*] Disable bugreport getting created when pressing both volume buttons at the same time
    [*] Contextual wallpaper
    • Changes your wallpaper based on the time (morning, afternoon, evening, night)
    • Default images are available, custom images can be set
    • Backups old wallpaper and restores it when you decide to disable contextual wallpaper again
    [*] Reverted HTCs changes to the recents apps view
    [*] Allow to add system apps to the hide notification on lockscreen setting in VenomTweaks
    [*] Option to ignore fingerprint restrictions
    [*] Show SSID below wifi quicksetting when "Wi-Fi/Bluetooth Tile Size" tweak is enabled
    [*] Option to tint battery icon
    [*] Option to show current brightness percentage for the brightness slider (The one in VenomTweaks->Statusbar->Header)
    [*] PackageInstaller
    • Removed Install Flow Analytics - was used by Google to analyse what apps you install, every button press, swipe and lots of other stuff got logged
    • Added option to remove apk file on successful installation
    • Added option to disable vibration when intalltion finished
    [*] Made static quicksettings tiles like tweaks, hub, calulator using the "active" state. Stock behavior is that they appear in disabled state.
Fixes & Cleanups
  • Fixed brightness slider auto brightness mode disappearing with a custom color set
  • Fixed VenomHUB Remote install FC when installing bootanimation
  • Fixed stuck progress bar on remote install
  • Fixed VenomHUB apk update
  • Fixed ImmobilienScout24 Fcing, caused by scroll to top mod. Probably affects other apps that are bad coded.
  • Removed plenty of venom debugging info cluttering the logcat
  • Fixed weather widget icons not applying when a sense theme is installed
  • Changed traffic info line to show just KiloBytes and MegaBytes
  • Fixed "No Notifications" color not applying after a statusbar restart
  • Cleaned items in VenomTweaks
Available as OTA:
Fullroms:
AndroidFileHost
G-Drive
Klo-Sa3uf3r
ab wann ist denn as M9 + Viper-One mir Android 7 zu rechnen?
TTU1972
Hallo, habe seit kurzem ein M9 mit der neuesten Viper. Vorher war ich mit einem M7 mit Viper unterwegs. Die Icons aus der Statusbar habe ich nach meinen Bedürfnissen angepasst. Es werden allerdings nicht alle modifiziert (Silent, Gps,? ). Woran könnte das liegen? Habe mehrere aus dem Hub getestet. Es wird immer das originale Icon angezeigt [emoji17]. Ich hatte dies auch schon mal bei einer früheren Viper, habe da manuell nachgeholfen. Kann man da was machen oder ist es ein Bug. Vielen Dank ttu
Gesendet von meinem HTC One M9
Ach ja, mein Gerät ist s-on.
adröidler
vor einer Stunde, TTU1972 said:
Hallo, habe seit kurzem ein M9 mit der neuesten Viper. Vorher war ich mit einem M7 mit Viper unterwegs. Die Icons aus der Statusbar habe ich nach meinen Bedürfnissen angepasst. Es werden allerdings nicht alle modifiziert (Silent, Gps,? ). Woran könnte das liegen? Habe mehrere aus dem Hub getestet. Es wird immer das originale Icon angezeigt emoji17.png. Ich hatte dies auch schon mal bei einer früheren Viper, habe da manuell nachgeholfen. Kann man da was machen oder ist es ein Bug. Vielen Dank ttu
Hallo erstmal @TTU1972
Sind die Icons die noch "stock" sind in den Icon Packs vorhanden, sprich existiert darin eine angepasste Version der gewünschten Icons?
Wenn nicht liegts daran & dann könntest du dich direkt an den jeweiligen Autor des Packs wenden damit er das anpassen kann.
Von einem Bug ist mir nichts bekannt; normalerweise lassen sich die Icons in den Tweaks einzeln einstellen oder eben via Hub mit einem Paket komplett ändern.
Sonst ev. zwischendurch auch mal das Gerät rebooten und dann erneut versuchen einzustellen. Mehrere Icon Packs auf einmal aktiv zu haben führt manchmal zu Problemen.
TTU1972
Dank dir für die schnelle Antwort, hatte wie gesagt mehrere Packs einzeln (komplett und separat ) getestet. Werden auch in den Tweaks angezeigt nur eben nicht in der Statusbar.
Hier mal das Silent Icon, Vibration passt
Screenshot_20161220-010605.thumb.png.ed8
Hatte das gleiche bei Viper für M7, da war alles ok.
Die "dnd / priority" Mode Icons, können nicht gethemed werden.
Aber du kannst die in den tweaks verstecken.
Venom tweaks -> status bar -> hide specific notification icon
Wenn ich mich recht erinnere, werden dir dann auch die "alten" Symbole, für lautlos angezeigt, welche per Theme auch geändert werden können.
TTU1972
@Black-FR
das habe ich fast befürchtet, das alte Silent Icon wird ja gar nicht mehr angezeigt nur noch das DND und beim GPS ist es das Standort Icon. Das ausblenden habe ich versucht, da wird kein Icon mehr angezeigt. Dank nochmals für die schnellen Antworten. Gruß TTU
Es gibt ein größeres Update:
VipeOneM9 6.0.0
(01st February)
Special Thanks and Credits
  • [MENTION=4165809]thicklizard[/MENTION] for adding carriers support.
  • All developers and testers who helped me!!!
Additions & Updates
  • Rebased to 4.14.401.7 Android N base
  • Full carriers support, thanks a lot to [MENTION=4165809]thicklizard[/MENTION] (Verizon wasn't tested)
    • Magisk support, thx [MENTION=4470081]topjohnwu[/MENTION]
    • Rooted with phh superuser by [MENTION=1915408]phhusson[/MENTION] (SuperSu didn't let the rom boot)
    • Some additions to customize the new quicksettings
    [*] InCall Headsup notification - Replaces the fullscreen caller
    [*] Option to make InCall Headsup notification clearable (you can swipe it away without dimissing the call)
    [*] Region Screenshot
    ST2KyOSgar4
    [*] Enabled Systemui tuner
    • Added Navbar Tuner
    • Added Nightmode/Color filter option
OTA:
NO OTA this time, since its a new base with a lot of changes.
FULLROMS:
AndroidFileHost
GDrive
Viel Spaß beim flashen und mit Android N.
Firmware + TWRP, solltet ihr direkt auf aktuellen Stand bringen, vor der Installation des N ROM.
djwiese
Supi. Habe es gleich drüber gebügelt. Läuft sehr flüssig. Einziges Manko es saugt am Akku wie eine Güllepumpe. ?
Direkt nach der Installation, ist ein höherer Akkuverbrauch, nicht verwunderlich.
Mediascanner und X andere Dienste, laufen da erstmal auf Hochtouren.
