[Rom] ViperOneM9 - Tweaks | HUB | Sidebar | OTA
Hier zumindest bereits die wichtigsten Infos,
anpassen kann ich den Thread erst nach der Arbeit:
ViperOneM9 1.3.0
(24th April )
Updates & Additions
  • Updated International base to 1.32.401.17
  • Update AT&T base to 1.32.502.31
  • Updated Sprint base to 1.32.651.30
  • Updated T-Mobile base to 1.32.531.33
  • Updated Verizon kernel to 1.33.605.15
  • Free up 3GB from internal storage for S-OFF users
  • Removed Flashlight and Venom Filemanager removal
  • Added removal to stock HTC Filemanager
  • Added Skype and Skype removal
  • Removed FitBit
  • Removed /preload content
  • Updated all /system and /data apps
  • Updated Venom Apps to use new HTC Sense 7 Theme engine
  • VenomHUB Backend completely rewritten, preparations made for Desktop Hub and User Uploads
  • Added ability to customize status bar and header clocks with custom formatting including HTML
  • Added html presets for statusbar and header lock
  • Added ability to customize carrier label with HTML
  • Added ability to hide clock on lock screen
  • Added SliderBrightness to Notification header
Fixes:
  • Fixed MTP - got broken when you S-OFFed
  • Fixed Centered Clock now displayed on lockscreen
  • Fixed HeadsUp white/black list (for stock behavior, leave list of apps blank)
  • HeadsUp can now be disabled
  • HeadsUp timeout fixed
  • Information Text (CPU usage, frequency and profile) now properly formatted on 1 line
  • Enabling Vibrate mode through HEQS will now vibrate to indicate it's enabled
  • AT&T status bar carrier label now hidden
  • Fixed Always Display Data Icon
  • Fixed signal icon alignment when on left of status bar
  • Reduced size of traffic icon on signal bar
  • Fixed size of system icons (Bluetooth, GPS, Interruptions, etc.) in status bar
  • Fixed bootanimation installations
  • Fixed hiding USB Icon
  • Fixed VoLTE for Verizon and T-Mobile
  • Fixed login FC on boot on Verizon
  • Fixed GPS Selection Dialog not showing in AROMA
Props to [MENTION=1225716]Turge[/MENTION] [MENTION=1792279]ivicask[/MENTION] [MENTION=1930589]shnizlon[/MENTION] and [MENTION=1016148]m0narx[/MENTION] ....I was a bit lazy this time :D
New Base = new Fullrom = No OTA
Rom Download and mirrors as usual on:
Enjoy...I'm out, gn8!
Gesendet von meinem HTC One M9
warci
So...
der ViperOneM9-Deutsch-Mod ist verfügbar.
Alle Informationen dazu findet ihr im unten verlinkten Support-Thread, dort könnt ihr auch gerne Fragen und Anmerkungen posten.
Bitte beachtet dass das Modul an sich nichts mit der ROM zu tun hat und er daher natürlich auch nicht von TeamVenom supported wird.
axanon
sehr schön, danke euch!!
zum 1.3.0: ist ein FullWipe nötig, oder kann man ein dirty-flash wagen?
Wenn du die Viper bereits nutzt, dann kannst du ohne wipe flashen.
axanon
das ist der fall - sehr schön, danke!!
Gestern hatte ich keine Zeit, es zu posten.
Es gibt ein OTA Update, auf Version 1.3.5
Rom updated with small OTA, should bring some camera improvements, and also little better CPU management regarding battery life and heating
  • Improved camera drivers from new 1.37.x base
  • Updated camera from HTC ONE M9 PLUS (Voice capture works better with it)
  • Updated CPU(PnP) and thermal management from new 1.37.x base
Enjoy!
Available via Settings->About->Software Update
or download it directely here: ViperOne 1.3.5 OTA and flash in recovery manually.
There won't be a fullrom. 1.4.0 with OTA and Fullrom with new stuff and fixes should follow on the weekend.
Und am Wochenende sollte es dann die 1.4.0 geben.
Christoph 76
Habe das Problem mit der ™Aufgaben wurden beendet' Nachricht. Es kommt immer wieder., weißt einer wie ich das weg bekomme.?
Gesendet von meinem HTC One M9 mit Tapatalk
Krocko
Hast du mal die Daten der App gelöscht?
Hast du evtl. den Kalender zur Deinstallation ausgewählt?
Zur Not flash die Rom noch einmal ohne wipe drüber.
Christoph 76
Ok. Danke
dafrio83
Hat eigentlich noch wer massive WLAN Probleme, die Benachrichtigungen kommen unter, WLAN garnicht durch und keine WhatsApp Nachrichten kommen an, erst wenn ich von WLAN auf mobiles Internet gehe kommen die Notification an...
Hat wer eine Idee oder Lösungen??!!
Nutzt du zufällig lbe security Master , greenify oder ähnliche Apps?
Ich würde sagen, dein Problem liegt an einer deiner verwendeten Apps.
dafrio83
Habe eig an Virenscanner nur Antivir drauf... Kann es daran liegen... Aber hatte bei der 1.2.0 keine Probleme,erst als ich auf 1.3.0 bzw 1.3.5 upgedatet habe..
Das Update, auf 1.4.0 ist da:
ViperOneM9 1.4.0
(03 May)
Updates & Additions
  • Major battery life and overheating improvements
  • Added real per app navbar color
  • Added coloring Navbar for all apps
  • Added per app statusbar color
  • Added coloring statusbar for all apps
  • Added navbar color matching theme
  • Added hiding lockscreen widget
  • Added Hiding Sunset on Lockscreen
  • Added Showing Alarm on Lockscreen
  • Added different Emergency Call behaviors (Shortpress/Longpress/Hide)
  • Added Hiding Sprint GPS Testicle Icon
  • Added headsups blacklist allow all toggle
  • Added Custom Lockscreen Weather Location (No need to have location in settings enabled)
  • Added Custom Blinkfeed Weather Location (No need to have location in settings enabled)
  • Added Motion Launch custom actions
  • Added ambient notifcations
Fixes:
  • Fixed distorted VZW Advanced Calling Icon
  • Fixed motion launch gestures breaking when restarting statusbar in VenomTweaks
  • Fixed wrong behavior of headsup notification
  • Fixed notification count showing by default
  • Fixed custom autobrightness
  • Fixed weak haptic feedback on recent apps button
  • Fixed haptic feedback not working at all on 4th navbar button
  • Fixed small apps (floating apps)
1.4.0 is available via OTA. Grab it by going to Settings->About->Software Update.
The OTA is offered to be installable from 1.3.0 and 1.3.5 on!
Fullroms as usual downloadable on:
(You might need to ctrl+f5 to clear the cache to see the new links)
For people having issues with the links not showing:
Incremantal OTA:
ViperOneM9 1.3.0/1.3.5-1.4.0
Fullroms:
Main: AFH
Mirror 1: US Sene Host
Mirror 2: NL/EU
Mirror 3: NL/EU
Enjoy! Imo a nice update, there a are even a lot of features I love and use myself! :D
bearbeitet von Black-FR
Viel Spaß, mit der Viper 1.5.0:
ViperOneM9 1.5.0
(09 May)
Additions & Updates
  • Added headsups whitelist ignore score
  • Added fully customizable statusbar header view
  • Added CPU control for 4-7 cores
  • Added statusbar weather widget
  • Added Infoline multiline suppport
  • Added double press recent
  • Added Emulating Back key action to map to any key
  • Added Force Hiding Menu Key (no need for menu button when you got an action mapped to navbar button to trigger menu action)
  • Added option to hide googles searchpanel on longpress home button
  • Added AutostartManager
  • Added disabling google searchpanel when longpressing home
  • Added repositioning of appdrawer icon
  • Refactoring of header, quicksettings, quicklaunch visibility and behavior
  • Refactoring of Venom Button Management
  • Unlimited tether for TMOUS Added (Full ROM only)
  • Updated Russian translation(SystemUI, Tweaks, Framework)
  • Updated and ported Lockscreen and Sense Home to latest
  • Updated all /system and /data apps (Full ROM only)
Fixes:
  • Fixed statubar header buttons position
  • Fixed statubar header height calculation
  • Fixed statubar quick launcher
  • Fixed QS flashlight icon in rearrange list
  • Fixed HTC bug where core 4-7 not disabling after reboot when having powersaver enabled
  • Fixed Haptic Feedback for buttons
  • Fixed Menu Button staying on homescreen or other apps, although they shouldnt appear there.
  • Fixed app drawer icon alignment on custom icon themes
  • Fixed fake IMEI tweak for TMOUS
  • Fixed keyboards and widgets remove restore (Full ROM only)
  • Fixed preload partition removal (Full ROM only)
Some previews:
Weather widget big/small:
Multi Infolines, fully customizable:
Positioning of Appdrawer Button:
Extended CPU Control & Autostart Manager
1.5.0 is available via OTA. Grab it by going to Settings->About->Software Update.
Incremantal OTA:
ViperOneM9 1.4.0-15.0
Fullroms:
Main: AFH
Mirror 1: US Sense Host
Mirror 2: NL/EU
Mirror 3: NL/EU
Mirror 3: NL/EU
Krocko
Weil es so schön war, gleich nochmal einen nachgelegt. :biggrin:
ViperOneM9 1.6.0
(10 May)
Additions
  • Added color control support - Change RGB, saturation, contrast and more to get your desired display color
You can access that settings in VenomTweaks->Misc->Advanced Display Control
video demonstration by @Andromjb:
KCAL Color Calibration! (Nexus 6)
Nexus 6 - Saturation / Contrast Control!
Credits to @savoca for the initial mod. You can find his thread here.
Credits to @flar2 for making an easy module to use it. Use his app to thank and support him.
His app additionally supports creating different color settings profiles, that you can change on the fly.
1.6.0 is available via OTA. Grab it by going to Settings->About->Software Update.
Fullroms will be available tonight on:
Incremantal OTA:
ViperOneM9 1.5.0-1.6.0
[ame=https://youtu.be/dESlxM9izxk]KCAL Color Calibration! (Nexus 6)[/ame]
[ame=https://youtu.be/LYCJ-3OCjZQ]Nexus 6 - Saturation / Contrast Control![/ame]
bearbeitet von Krocko
Andy123438
seit dem Update auf 1.5.0 bzw. 1.6.0 habe ich das Problem, dass ich in meinen angelegten Ordnern auf dem Homescreen nur noch max. 16 Verknüpfungen angezeigt bekomme. Vorher (bis 1.4.0) konnte ich hier im Ornder nach unten scrollen. Die Verknüpfungen sind wohl vorhanden (da diese im AppDrawer nicht mehr auswählbar sind), werden aber nicht mehr angezeigt. Kann mir da jemand weiterhelfen? Vielen Dank.
LG Andy
Krocko
Ja, das ist ein bekanntes Problem.
Als temporäre Lösung könntest du erstmal entsprechend viele Verknüpfungen aus den Ordnern rausziehen.
Nicht mehr lange, bis zum nächsten Update:
ViperOneM9 1.7.0
(16th May)
Additions & Updates
  • Added custom Appdrawer Background image
  • Added custom Appdrawer Color - you will be able to set any transparency too ofc
  • Added custom lockscreen statusbar color
  • Added custom homescreen statusbar color (perfect for people with white/light background)
  • Added 5x5 Folders
  • Added Infinitive Folders
  • Completely rewrite of navbar/statusbar theming behavior
    - works on all apps now that are using the Android Actionbar
    - no overlapping issues.
    - color of navbar even changes when you navigate the different categories in google play and youtube
    - intelligent behavior:
    - apps that use a light colored action bar, like chrome, won't be applied as navbar background,
    since white navigatiobar buttons won't look well on gray background
Fixes:
  • Fixed Custom Appdrawer Shortcut
  • Fixed Custom Appdrawer Image
  • Fixed longpress back firing another back event
  • Fixed Horizontal Quicksettings Indicators not taking theme color
  • Fixed disabling pulldown on lockscreen
  • Fixed volume keys music control
  • Fixed Bugreport Full-Log option
  • Fixed issue with not being able to install apps in playstore
Previews:
Custom Statusbar Color on Homescreen:
Always wanted to use a white background?
..but it would look like on the left picture where you can't see your statusbar icons anymore?
We got the solution: Custom statusbar color on Homescreen
Navbar matching theme color:
Match the color of your navbar with the current theme color of your actionbar.
It will work on all apps implementing the KK/L Actionbar. On 1.7.0 it will even dynamically change when you navigate through categories in google play or youtube.
Screenshot_2015-05-16-21-14-01.pngScreenshot_2015-05-16-21-14-14.pngScreenshot_2015-05-16-21-14-29.png
Custom color in appdrawer:
Bored of the color in your opauqe appdrawer? Add some transparency!
Krocko
Da dürfen wir aber mal wieder gespannt sein!
Gesendet von meinem Be Touch mit Tapatalk
