Guest herbertzzz
Samsung Galaxy Note 2 - PhoeniX Rom [S5 Features]
andreas02
Update :icon_wink
CHANGELOG:
v6.5:
Fixed:
Minor bugs have been fixed
Fixed OS Monitor
Removed:
Notification bar icons(The gaurd and the task manager icon) - as you requested.
Gallery rotation icon - was anoying for everyone.
Updated:
Simplistic Framework to 3.5 and configured it to PhoeniX rom
Updated all mods in the Aroma - All mods are available to install!
Updated Apps to their latest version:
- Google Plus
- DropBox
- Google Voice
Aroma Changes:
Fixed:
Fixed flash player problem
Updated:
Flash player to 11.1.115.47
Fixed modems problem, now you have these modems only:
-DDDLK6
-XXDLK7
-UBDLL3
Added:
Now you can install recovery using Aroma:
- PhilZ 4.35
- TWRP 2.4.1.0
And more that i must have forgotten
Post ergänzt
Andreas
andreas02
Update :icon_bigg
Changelog:
v6.7:
New in v6.7:
PhoeniX OTA Center - now you can update the rom without plugin into the computer!
The OTA Center can be found in PhoeniX Settings.
The downloads will be save on the internel SD card(if you use my memory script so it will be saved in the externel sd card) undr the folder OTA updates.
Fixed:
Minor system bugs have been fixed
Fixed bootloops caused by Simplistic Framework
Updated:
Simplistic Framework to 3.5.1 and configured it to PhoeniX rom
- Facebook
Aroma Changes:
Pay Attention!
Due to the new Simplistic Framework, If you choose to install Simplistic Framework you can not choose these mods:
- Stock Phone
- Pull Down Bar Transparency(Choose 0%!)
- Notification Bar Transparency(Choose 0%!)
- TW Mod - Choose only the compatible mod to simplistic framework!
If you don't do as i said, you will get FCs and bootloops - Do Not Come here and report if you didn't do that!
You are still able to use FullS ystem transparency.
Post 1 ergänzt
Andreas
andreas02
Update :wave:
Changelog:
v7.0:
New in v7.0:
Rebased to the latest firmware- Android 4.1.2 XXDMB4 (build date: 12/02/2013)
Updated Kernel to XXDMB4
Fixed:
Adobe flash player is finally fixed!
Fixed no Internet Sync when you don't choose google chrome
Updated:
Updated APN List
Updated CSC Version to: N7100OLBDMA4 With 135 CSCs!
- Google Plus
- Samsung Apps
- Super Su to 1.05 + New SU Binary
- Facebook
- Google Earth
- And more
Added to Addition section(post 3)(will be added later this week) :
Stock Secured Kernel XXDMB4 - This is only for people who know what to do with it!.
This kernel, will let you use TriangleAway to reset counter+binary. The default kernel in this rom is insecured and a good kernel! Use the Secured only if you know what you are doing!
Post 3:
https://forum.xda-developers.com/show...16&postcount=3
Aroma Changes:
Added to Aroma Apps Section:
- Maps is now available to remove/install from Aroma
- Added LG Weather & Clock Widget!(Amazing!) thx to devilex94 his thread
Picture:
Updated PhilZ recovery to 4.63
Option to choose between 4 modems:
-XXDLK6
-XXDLK7
-UBDLL3
-DXDLK5
Removed:
Removed Simplistic TW 4X4 Rotation mod since you can rotate your TW with paid simplistic app, and it won't work in aroma anymore.
Post 1 ergänzt
Andreas
andreas02
Update :wave:
CHANGELOG:
v7.77:
Well, this is your lucky version
New in v7.77:
Kernel Tweaks - thanks to mike1986.
Added more Built.prop tweaks
Zipaligned with the latest SDK
Fixed:
Some FCs caused by missing libs
Fixed ZipAlign script and updated it to run it each 2 days
Updated:
- Facebook
- SuperSU v1.25
- DropBox
- Youtube
- Chrome
- Samsung Apps
- Play Store
- SPPPush
- GMSCore
- Flipboard
- CPU Spy Plus
Aroma Changes:
Updated:
- YouTube Mod to v3b
- Perseus kernel to alpha33.4
- PhilZ recovery to 4.87
- TWRP recovery to 2.4.3.0
Attention everyone!
To get a good battery performance, you have to make Battery Calibration. To make that, search Battery Calibration at Play Store.
Extra!
Use PhoeniX Kitchen to get full options!
Play store link: >>>HIER<<<
Full wipe is recommended, but you can do only Wipe Cache&Davlik
Post 1 ergänzt
Andreas
andreas02
Update
Changelog:
v8.0:
New in v8.0:
Rebased to the latest firmware- Android 4.1.2 XXDMB5 (build date: 21/02/2013)
Updated Kernel to XXDMB5
Added PhoeniX 7.77 Wallpaper to Wallpaper Chooser
Fixed:
System Lags - Should be hell faster and good performance
OTA Updater problem
Battery drain should be fixed now.(New base.. Do not forget Battery Calibration)
Updated:
Updated CSC Version to: N7100OJVDMB1 With 135 CSCs! If you want to change CSC:
First, install Stock Android Recovery
Second, select your CSC and install.
Third, Install PhilZ/TWRP recovery
Enjoy
Update MultiWindow Manager
- Google Plus
- Samsung Apps
- GroupCast
- And more
Added to Addition section:
Stock Secured Kernel XXDMB5 - This is only for people who know what to do with it!.
Link:
https://revolutionrom.com/index.php/s...om/extra-items
Aroma Changes:
Available to delete/install from Aroma:
- Spen Board Switcher
Updated PhilZ recovery to 4.87.6
Extra!
Post 1 ergänzt
Andreas
andreas02
Update
CHANGELOG:
New in v9.0:
Rebased to the latest firmware- Android 4.1.2 XXDMB6 (build date: 26/02/2013)
Updated Kernel to XXDMB6
Added more tweaks
Option for custom bootanimation. put it in data/local/
Fixed:
Some APP's FCs
Updated:
Added 4 CSC: BTU, DBT CPW ITV. If you want to change CSC:
Enjoy
- Google Plus
- Samsung Apps Services
- Adobe Flash Player
- DropBox
- Facebook
- Chrome
- ChatON
- sCloudStarter
- Play Store
- And more
Updated BusyBox to 1.21
Stock Secured Kernel XXDMB6 - This is only for people who know what to do with it!.
Link:
Aroma Changes:
- GroupCast
Awesome Beats Reaplaced With Mega Beats Bass. thx to DeHuMaNiZeD his thread
New Aroma Menu - Phone Mod:
You are able to choose between 4 mods:
- Custom Phone Mod - No increasing Ringtone, With Call Recording. Won't work with simplistic!
- Simplistic Phone Mod - Phone Mod For simplistic framework.
- Poppuri Mod Full Screen Caller HD Photo - Won't work with simplistic! - thx to poppuri his thread
- Stock Phone Mod - No call recording, with increasing ringtone. Won't work with simplistic!
Updated TWRP to 2.4.4.0
Changed More memory script to ExtSd2InternalSd v6 by mattiadj his thread
New ROM features available in the aroma:
240 DPI Mod! From now you can use your phone in the correct DPI! Special thx to: bala_gamer, Xposed Team and me
Be careful! After installation you must to do this:
https://forum.xda-developers.com/show...45&postcount=6
In order to prevent FC or small TouchWix!!
HTC Sense theme!
After alot of working hours, i have finished to work on the HTC Sense theme.
Thx to: bala_gamer(for some icons), shnizelon(for some bug fixes), mrlove6(for some icons) , me(for making this theme) Andy Wong & droid27(For widgets) .
Some icons have been taken from my old loved rom RevlotuioN ROM for HTC Desire.
It includes HTC Sense icons,battery, toggels ,backgrounds and some widgets:
- Photo Grid Widget by Andy Wong
- HTC Sense v2 Flip Clock by droid27
In the aroma, choose one of this:
- Sense theme for stock users
- Sense theme for simplistic users
Post 1 ergänzt
Andreas
andreas02
Update
CHANGELOG:
New in v10.0:
Rebased to the latest firmware- Android 4.1.2 XXDMC3 (build date: 27/03/2013)
Updated Kernel to XXDMC3
Added all S4 Wallpapers
Added option for Logcat in PhoeniX Settings
Updated:
135 CSCs. CSC Version: N7100OXXDMC2. How to change CSC?
Enjoy
- Google Plus
- Gmail
- Youtube + Youtube mod to v4b(aroma)
- Chrome
- GMS Core
- Play Store to the new version v4.0.25
- Google Search
- Samsung Push Service
- And more
Stock Secured Kernel XXDMC3 - This is only for people who know what to do with it!.
Link: https://revolutionrom.com/index.php/s...om/extra-items
Aroma Changes:
Added option to install Awesome Note. Thx to jujuburi his thread
Updated Noozxoide to his latest version
New Aroma Menu - Zerowakeuplag!
Remove wakeup lag by disabling deep sleep. Thx to mikeyxda his thread
Updated TWRP to 2.5.0.0
Updated Philz to 4.92.8
Updated Perseus to alpha 35
Update RedPill to 1.47
Added Modem to modem's selction:
- UBDMB1
Added option to install S4 Accuweather Clock
Added S4 theme!
thanks to Eric-Mod his thread
Extra!
Post 1 ergänzt
Andreas
Eric-Mod
Update PhoeniX Rom V16 (V16.7)
Based on the lastest stock firmware: Android 4.3 XXUEML5 (build date: 09/12/2013)
Modem: XXUEMJ5 Or DDEMJ9 Or XXUEMI6 Or XXUEMJ2 Or XXUEMK1(Choose in the aroma)
Stock XXUEML3 customized kernel by me:
- SELinux set to permissive!!
- Insecured boot.img for full Root Access
- Init.d Support
- ExFat Support
This ROM is 200% Knox Free - You can say "Cya Knox!"
Multi CSC(136 CSC) Set to EUR. If you want to change CSC:
Enjoy
Fully Deodexed
Added latest BusyBox
Added latest SuperSU+Bin files
Added GenieWidget
Added Flashplayer support
Added ES File Explorer
Added Facebook
Updated all stock apps to their latest version(Gmail, Google search, Google Maps, Google Earth, Chrome,Play store etc.)
Mods:
Call Recorder
Phone with no increasing ringtone
All supported languages enabled
All supported languages for Samsung Keyboard enabled
Enabled init.d scripts
Hacked camera: Able to take photoes at 0%. - thx indie
Shutter Sound menu Enabled to stock camera
Big APN list
Call Delay After call End Reduced to 0ms
Enable sub Symbols on Stock Samsung keyboard
Added exit menu to stock web browser
Dialer search matches numbers in contacts and call logs along with contacts
data/app enabled
Added Xposed framework with alot of modules and options:
- Xposed installer - thanks to rovo89 his thread
- Wanam Xposed - thanks to wanam his thread
- Nottach Xposed - thanks to Nottach his thread
- DPI Settings - thanks to rovo89
- MultiWindow Manager New Edition - thanks to BJB, Inc.
Enable call button in contact list
Disabled Converting Effect Between SMS MMS
Extended Power menu
Full Note 3 experience made by tamirda, dr.ketan and wesamothman:
- Note 3 Launcher
- Note 3 Accuweather Widget
- Note 3 Multiwindow
- Note 3 Fully Working Aircommand
- Note 3 One Handed Option Fot all screens
- Note 3 Keyboard - Thanks avivalder
- Note 3 SNote
- Note 3 My Files
- Note 3 Contacts and Phone (with option for popup incoming notifications)
- Note 3 Browser
- Note 3 S Planner
- Note 3 Sounds
- Note 3 S Finder, Pen Window, Scrapbooker
- Note 3 Apps like SketchBook, Evernote and more
- Note 3 Gallery
- Note 3 Writing Buddy
- Note 3 My Magazine
- Note 3 Installation Wizard(First setup)
- New Note 3 Wether & Calendar widget when pulling down the clock on lockscreen
- Note 3 Widgets (Like alarm widget)
- And much more!
Added Pen Window Manager - thank you Xperiacle!
New SMS app Mods:
- Folder View Option
- Backup/Restore SMS Option
- Split view option
- Change text size using volume keys option
- Screen On/Off for notification alerts option
- and more!!
Added PullUp Control(Selecet which app to pull up in TouchWiz) - Thank you very much fake_japanese_guy
Enabled IP Call for SIP users
Allowed some hidden settings:
- Display -> Open Editor after taking picture
- Air Command
- One Hand for all screens
- SPen -> Display input(Writing buddy)
- Display -> Torchlight
- Handwrite language selector for Action memo and Air Command
- And More!
Exclusive! Only to PhoeniX ROM!:
* RTL Menus when you select Arabic/Hebrew as your default language. (Pictures at post 4)
* New Amazing Wallpapers in Wallpaper Chooser Wallpapers! Beautiful Wallpapers! How to use? Click on Menu-> Set Wallpaper-> Home/Lock/Both-> Wallpaper Picker/chooser-> Select your Wallpaper! (Picture at post 4)
* New Settings app: Now will be only 1 shortcut in the Settings, to PhoeniX Settings App with the following fetures:
Samsung Secret Codes
Fast Dormancy
Faster Fix GPS
CSC Select
CPU Spy Plus
Battery Chooser
Terminal Emulator
Xposed +Modules
Idle Wifi Time Manager
Logcat
OS Monitor
And more coming soon
Post 4:
https://forum.xda-developers.com/show...31&postcount=4
Added Better GPS Config
TouchWIz Rotation available(landscape mode available) - thx to Rotry83
Extended speed dials to 100
A New superb & amazing Wallpaper pack including Note 3 & S4 wallpapers + alot of my collection - 61 wallpapers!
Added TB Restore Fixer Stub by -viperboy- his thread
Added Official OmegaDroid Android News app - I am reporter and editor there, so if you want to read the best news about android, use this!
Added OGBatteryMod with 39 different styles from my collection! thanks for OsamaGhareeb his thread
Tweaks:
Built.prop tweaks
zipalign
Kernel Tweaks
Removed from the rom:
- ReadersHub
Download : Hier
grafpyx
Hi!
Wie bekomme ich bei dieser ROM den Homebutton wieder dazu das zu tun, wofür er ursprünglich gebaut wurde? Finde nirgendwo eine Einstellungsmöglichkeit...
Eric-Mod
Phoenix Rom v18.5
Startpost erneuert!
hardy012
Hi habe die Rom 18.5 installiert lief auch alles prima .nur habe ich jetz das Problem das wenn ich das Note2 im ausgeschalteten zustand laden möchte gehts nicht so wie ich das Netzteil anschließe fährt das gerät hoch.habe ich da was verkert gemacht bei Rom instalation.wie kann ich das wieder hinbekommen das ich das gerät auch im ausgeschalteten zu stand wieder laden kann.
Danke für eure Tips und Hilfe.
Eric-Mod
Hallo!
Hast du den neuen KitKat Bootloader geflasht?
Gesendet von meinem GT-N7100 mit Tapatalk
hardy012
wie jetz brauche ich denn fürs note2 da stand aber nichts in der beschreibung von geschrieben.wo bekomme ich den den herr. und wie installiere ich den dann.und heißt das dann das ich die rom noch mahl dann neu flashen muss.
Eric-Mod
Ja ich würde den Bootloader mal flashen. Da ich aber keine einzelne Bootloader Datei finden kann, müsstest du eine komplette KitKat Firmware flashen und dann wieder die Rom.
Zurück auf Android 4.3 ist dann halt nicht mehr.
