andreas02
Samsung Galaxy Note II -TWRP TeamWin Recovery Project
andreas02
Wie im vorherigen Post angesprochen ist jetzt der Changelog zur 2.4.0.1 online
- Revert to using kernel modules for exFAT for performance
Post 1 wurde ergänzt
Andreas
andreas02
Update :biggrin:
Changelog:
2.4.1.0
Fix detection of exfat and vfat
Fix formatting vfat past 2GB
Post 1 ergänzt
Andreas
Guest Don Hugo alt
Das sehe ich genauso. Was besseres gibt es nicht.
Ich bin da durch Zufall mal drauf gestoßen da es in einer Rom mit integriert war. Klasse Idee der Entwickler.
Do, what has to be done..in ANDROID we trust! postet via TapaTalk2
Guest Don Hugo alt
So hin ich auch drauf gestossen. War bei einer S3 Rom integriert. Deshalb brauchte ich beim Note2 nicht lange überlegen.
andreas02
Update :icon_wink
Changelog:
2.4.2.0
Add screen timeout - screen will turn off automatically after 60 seconds, saves battery and prevents screen burn-in especially on AMOLED devices
Add a brightness setting (requires device specific setup and only some devices have been added)
Add a root checker and offer to install SuperSU if the device isn't already rooted
Add a write buffer to libtar backups, significant improvements to speeds when backing up to exFAT target, minor improvements for other file systems
Check and offer to fix root permissions if broken
Add an option for a 24 hour clock display instead of AM/PM (aka military time)
Move stock recovery reflash check to occur during the reboot cycle
Add support for some MTK6xxx devices
Change libtar to vfork to help prevent memory problems
Add a "clicked" effect to most buttons, file selector, and listbox
Improve timezone listbox to be more like file selector (per pixel kinetic scrolling, etc)
Remove some no longer used settings (Forced MD5 sum on zips, size checking on image backups)
Other minor bugfixes and improvements
Post 1 ergänzt
Andreas
andreas02
Update :icon_wink
2.4.3.0
Fixed 2 bugs related to restore, one dealing with mknod failures (by bigbiff) and one dealing with restoring hardlinks (by Dees_Troy)
NOTE: If your backups weren't restoring correctly in earlier 2.4.x versions they should restore correctly now. Hopefully you didn't delete those backups. If you're still having problems, run the restore, go to advanced and copy log, then give us the log. Complaints without logs will be rightfully ignored.
Added a scroll bar to file selectors and listboxes courtesy of Tassadar
Added libblkid for more accurate detection of file systems and can now detect exFAT properly thanks to bigbiff
Added a screen dim effect 2 seconds before screen off on some devices
Finally fixed file selector crash (one of the joys of working with multi-threaded software)
Fixed loading of screen timeout setting during startup
Improvements and bugfixes to screen timeout code
Fix Military Time setting persisting
Post 1 ergänzt
Andreas
Guest Don Hugo alt
So, gleich das Update gezogen und installiert. Was anderes kommt mir nicht mehr auf das Telefon.
andreas02
Es gibt ein Update (ohne Changelog) auf openrecovery-twrp-2.4.3.1
Zur Info :icon_wink
Andreas
drdoulittle
Hi
Läuft perfekt und ein wirklich tolles TWRP Recovery.
Bleibt nun für immer auf meinem Note II drauf, bin wirklich begeistert.
:dankescho
bearbeitet von drdoulittle
andreas02
Update auf v2.4.4.0
Changelog:
2.4.4.0
Added another libtar hardlink workaround to fix restore of some backups (usually related to Ubuntu Touch)
More fixes for the file selector
Switched from using busybox md5sum to a direct C function call
Fixed capturing the exit status of tar based backups/restore - TWRP will display that there was an error if there was one again
Update exFAT to latest commits
Added a build flag to disable using the ioctl for screen blanking
Post 1 ergänzt
Andreas
drdoulittle
@perfekt und läuft einwandfrei.
Bei der Installation mit mobil odin pro (img.tar) nicht erschrecken wenn das Note II nicht sofort bootet. Es dauert ca 1min und dann wird das TWRP installiert (blaues Android Installationsmänchen erscheint) und danach dauert es wieder 1min bis das Note II startet, also Geduld und nicht erschrecken.:icon_bigg
Guest herbertzzz
Im CWM geht es ohne Verzögerung. Läuft bisher genauso wie die Vorgängerversion; also 5-Sterne-verdächtig.
andreas02
Ich installiere seit Beginn der ersten Versionen TWRP mit MobileOdinPro... und auch bei dieser Installation konnte ich jetzt keine Veränderungen gegenüber den anderen erkennen...also bei mir normal und unauffällig. Hängt vielleicht mit dem Kernel und/oder Rom zusammen... aber es läuft...wie immer :)
Andreas
drdoulittle
@herbertzzz über CWM ist es auch ein anderer Prozess und wie du sicherlich bemerkt hast, braucht das Note II von haus aus länger als das S3 um aus dem Boot zu kommen. Wenn ich über das TWRP alt das neue TWRP installiere, dann geht es ohne Verzögerung und bootet direkt ins neue TWRP. Ich habe den Stock Kernel drauf daher weis ich nicht ob der Stock bei mobil odin pro etwas länger benötigt?
scotts
@all
Ich habe TWRP über die App "GooManager" istalliert. Download und Installation von TWRP ohne Probleme.
Nur wie rufe ich TWRP auf?
Wenn ich in GooManager auf "Reboot Recovery" gehe, dann komme ich ins Recovery wo steht:
Android system recovery (3e)
reboot system now
apply update from ADB
apply update from external storage
wipe data/factory reset
wipe cache partition
apply update from cache
Darunter liegt das Androidmännchen....:icon_bigg:icon_bigg:icon_bigg
Wie starte ich jetzt TWRP ???
:dankescho
scotts
drdoulittle
@Du brauchst kein GOOManager
Installiere TWRP via Odin (bei PDA einfügen) oder Mobil Odin Pro (bei Recovery einfügen) und wenn du keine Rom hast mit 4Way Reboot Funktion kommst du nur ins Recovery via Home-Power-Lauststärketaste nach oben (zusammen drücken) bis Galaxy Note 2) zweimal erscheint dann die Tasten loslassen und du bist im TWRP Recovery.
andreas02
Easiest way is to install goo manager from the market. Then press the 3 dots, then Install OpenRecovery Script.
Das Problem ist, dass man die "richtige" Recovery auch flasht bzw. findet.
Gibt -glaube ich- zur Zeit 14 Varianten im Goo-Manager :icon_wink
Daher sind die für mich besten Flash-Methoden im Post 1 erklärt.
Andreas
