MetaIIica
nguenal
Ein fullwipe und sauberes flashen hat nicht zum Erfolg geführt. Aber bei den Quicksettings war erfolgreich. Zur Info für andere 1&1 Nutzer
Gesendet von meinem GT-I9505 mit Tapatalk 4
Dean36
Wie steht es um Halo2? lässt sich das irgendwie realisieren? ;)
MetaIIica
Neues Build (Nightly) ist verfügbar
Es wurde einiges gefixt, aber neue Features hinzugefügt
Changelog:
CyanogenMod | Project name: android_build
*Jake Weinstein - Build: Use A15 flags on krait
CyanogenMod | Project name: android_hardware_samsung
*Xiao-Long Chen - Samsung: add support for high touch sensitivity
CyanogenMod | Project name: android_packages_apps_CMFileManager
*Dan Pasanen - CMFileManager: Enable symlinks by default
CyanogenMod | Project name: android_packages_apps_LockClock
*metaiiica - Add new Weather Icons with modern Design
PAC-man | Project name: android_packages_apps_Mms
*DelphinPETER - Mms: FR translation
PAC-man | Project name: android_packages_apps_Settings
*Jo De Boeck - Allow other users to modify button settings
*Damandeep Singh - Try to Fix NPE
*andrew.boren - settings: Port lockscreen styles
*kilianvp - Update AOKP Translation Change-Id: I10aaccd416d14530da3aa0a50203d749281b2f0b
*Steve Spear - PAC-Settings: Custom System Animations. Original Work from Steve K. Spear AOKP 2/2
*Juffin Alex Varghese - Bluetooth: Handle BT search while rotate screen
*Bhasker Neti - Bluetooth: Handle pairing Cancel intent.
*Pradeep Panigrahi - Bluetooth: Not allow Blank BT device name.
*Pradeep Panigrahi - Bluetooth: Set isPreferred to true for PanProfile Connections.
*fitsnugly - sounds: add extra gain option
*Xiao-Long Chen - Auto-copied translations for high touch sensitivity
*Xiao-Long Chen - Add preferences for high touch sensitivity
*Xiao-Long Chen - Add app moving setting to development options
*Xiao-Long Chen - Enable moving applications to the external SD card
*Aleksander Ciepiela - Settings/Added ADB over network QuickSettings Tile
CyanogenMod | Project name: android_packages_apps_Torch
*igio90 - Torch: TRDS Icons
PAC-man | Project name: android_packages_apps_Calculator
*Michael Johnson - Fixed base conversion to prevent app crash on tablets
CyanogenMod | Project name: android_packages_apps_Focal
*maxwen - Call updateCapabilities on mode switch and set video-size camera parameter
*p4r4n01d - Focal: Target API 18 (Android 4.3)
*p4r4n01d - Focal: Add missing recycle call (fix lint warning)
Anonymous | Project name: android_kernel_samsung_jf
*Dave Kleikamp - AIO: Don't plug the I/O queue in do_io_submit() Asynchronous I/O latency to a solid-state disk greatly increased between the 2.6.32 and 3.0 kernels. By removing the plug from do_io_submit(), we observed a 34% improvement in the I/O latency.
Anonymous | Project name: ion
*Koushik Dutta - additional context death logging
*Koushik Dutta - add some logging for when a context dies
*Koushik Dutta - Update README.md
*Maurycy Damian Wasilewski - Updated with info about possibility of tracking upload progress
CyanogenMod | Project name: android_frameworks_opt_hardware
*Xiao-Long Chen - Add class for enabling and disabling moving apps to SD
*Xiao-Long Chen - Hardware: Add high touch sensitivity support
Anonymous | Project name: android_frameworks_opt_telephony
*Venkat Ram Prakash Kotni - Telephony: Read IMSI using SIM I/O for CSIM/RUIM
PAC-man | Project name: android_frameworks_base
*Kyrylo Mikos - PhoneWindowManager: Delay setting updates during window animation.
*Danny Baumann - Freeze screen while changing expanded desktop mode.
*Phil Tunstall - Keep ToggleLockscreenTiles in sync between Quick Settings and Ribbon
*andrew.boren - fwbs: Port lockscreen styles
*vwmofo - add external dock battery support
*Steve Spear - frameworks:Custom System Animations ported to PAC. Original work from Steve K. Spear AOKP 1/2
*aways - Edit PlatLOGO:
*Damandeep Singh - Fix Appbar (Phone Mode)
*Xiao-Long Chen - Framework: Check of moving apps to SD is disabled
*Xiao-Long Chen - Framework changes for moving applications to external SD
*Niko Koivu - frameworks/base: FI translations
*Aleksander Ciepiela - SystemUI/Added ADB over network QuickSettings Tile
*Phil Tunstall - Fix status bar brightness control when on secure lock screen
*Phil Tunstall - Fix Quick Settings tiles jerking down while animating to notifications view
*Danny Baumann - Fix up 'launch player on headset connection' option.
*Kyrylo Mikos - SystemUI: do not collapse panels if keyevent was canceled.
PAC-man | Project name: android_frameworks_native
*Xiao-Long Chen - Calculate application sizes correctly
*Ricardo Cerqueira - Unbreak libgui
PAC-man | Project name: android_system_core
*Michael Bestas - init: Fix serial number display for semc msm7x30 devices
*DevSwift - Update audio.h for ste_audio hardware
*Alin Jerpelea - Adding required ST-Ericsson changes to graphics.h
CyanogenMod | Project name: android_system_vold
*philz-cwm6 - vold: Use quick format for NTFS volumes
*Xiao-Long Chen - Vold: Do not mount ASEC containers if moving apps to SD is disabled
*Xiao-Long Chen - vold: Allow ASEC containers on external SD when internal is emulated
Anonymous | Project name: android_device_samsung_jf-common
*Xiao-Long Chen - Set 'externalSd' attribute for the external SD card
PAC-man | Project name: android_vendor_pac
*UtkarshGupta - Persist DPI
*UtkarshGupta - [1/2]Changelog Generator
*Brian Jolly - Update Qcom VZW Motorola Dependencies
*David Eddlemon - Dependency Repository Change
*Joao - Add Nexus Q (steelhead) support
*robt77 - updated kernel and vendor blobs for Atlas40 fixing cm-10.2 in atlas40.adds
*Utkarsh Gupta - Revert "Drop galaxysl support for now"
*Brian Jolly - Update Dependencies
*jeroenqui - add new our new bootlogo, add some new resolutions and cleanup
CyanogenMod | Project name: android_vendor_cm
*Steve Kondik - cm: Build the BluetoothExt package
All named inside a big thanks
More Fixes coming soon, but dont ask for ETA
Freakii
Das nenne ich doch mal eine Riesen Changelog ;)
Aber Metallicca ich muss leider Berichten das ich seit letzten 2-3 Releasen ich massive Akku Einbrüche bekomen habe bin immoment dabei Apps etc erneut zubeobachten bloss bisher ansich Alles im Grünen bereich was Apps angeht :frown:
Ich Spreche hier von einer Akku Leistung von 4-6h mehr nicht mehr manchmal :frown:
Ich will keines wegs damit sagen das es an deiner Rom liegen muss ;)
Ich hoffe nur das mein Akku nicht einen wegbekommen was ansich ja nicht sien dar das Handy noch Sehr Neu ist (min. 1. Monat), wüsste zwar nicht wie aber who knows that :eusa_doh:
Werde jetzt gleich oder noch Heute Abend mein Handy nach einen TB Frisch aufsetzen dann sehe ich weiter.
chris264
Hey,
ist die Akkuleistung unter unterschiedlichen Kerneln gleich schlecht?
Lg
MetaIIica
ich bitte euch dies mal mit Vertigos Build zu testen ob da der Verbrauch auch so hoch ist. Ich habs bei mir auch schon beobachtet...
Freakii
@Das kann ich Dir so nicht Sofort beantworten aber Gute Frage das kann ich dir so nicht sagen weil bis jetzt habe ich die Pac All in One noch drauf ;) Wiegesgat es war manchmal damit Verbunden das leichte System instabilitäten auftraten bzw. Diensten einfach so Beendet wurden. wiegesagt irgendwie spinnt das Sys incl FW rumm ich setzt das SyS+FW gleich mal Frisch auf Chris den so ist mein S4 mir immoment zu Instabil bzw. nicht ganz geheuer ;)
@Metallica oh grade noch so beim Ausloggen gelesen deinen Post Alles klar
Gut zuwissen das ich nicht Paranoid war und du es auch Beobachtet hast bei Dir beruhig mich etwas ;)
MetaIIica
eins von denen...
glaube aber zu wissen an was es liegt... Werd mal Linaro SaberMod GCC Toolchain entfernen und auf Stock zurück gehn
MetaIIica
Es ist tatsächlich so das Linaro für das Akkuproblem verantwortlich war... Ohne ist es bei mir deutlich besser
wann aber eine neue Build kommt weiss ich noch nicht, Server macht Zicken
MetaIIica
das ist jetzt mein Akku nach 10 Stunden
scheflo
Standard Kernel?
nguenal
Akku Laufzeit hat sich auf jedenfalls verbessert
RXBeat
Will auch mal was zum Viper4Android sagen.
Also ich bin sehr lange schon Tontechniker und bin eigentlich ein Nerd im Bereich Musikqualität.
Viele soundmods hab ich bereits getestet aber diesen WOOOW Effekt wie beim "Viper4Android" hatte ich noch nie. Das teil ist schon Klasse!
Beats dagegen ist lächerlich.
Hab deine "Black Power Edition" gerade mal installiert. Mir gefällt es!
Du hast einen Black Theme drauf. Ich mag den nicht so sehr, finde für mich persönlich einen besseren gefunden zu haben. Aber davon mal ganz abgesehen, kann hier jemand erfahrungsberichte zum Kernel machen?
Damit meine ich eher den Akkuverbrauch. Ich lasse alles auf standard. Ist der verbrauch besser? Schlechter?
@MetaIIica : Danke für die Arbeit, mir gefällt es. Du kannst dir ja mal den Theme "ThyrusHolo Black" anschauen. Ich finde diesen theme sehr edel! Vielleicht gefällt der euch ja auch.
Freakii
@Danke für dein tolles Feedback Gut zwissen das mal ein mann vom Fach sich dazu äußert ;)
Tja wer hat Viper zur Blacki gebracht lach Ne Spass ich Arbeite schonlange mit Viper Sound Mod und war seit Anfang an begeistert wenn man Gute Kopfhörer hat dass hat damit wirklich unvergleichbares Bomben Klang erlebniss kann ich nur Bestätigen!! Beste Sound Mod für Android Alles andere ist Müll :icon_smil
Die Rom ansich vom Akku Verbrauch her Sehr Gut auch mit Standart Einstellungen soweit ich gelsen hat Mettallica das Akku Problem von vor ein Paar Tagen beseitigt, somit ist es wieder eineder Betsen Roms auf den CR Markt ;)
@nguenal welche Build hast du drauf?
Liebe Grüße
Sascha
nguenal
@freakii es war mit 921
Bin aber noch nicht zu 100% zufrieden mit dem Verbrauch. Habe gestern 922 drauf gehabt. Etwas mit eingespielt und dann mit Navigon mich kurz navigieren lassen Akku direkt bei 22% Akku sollte schon 1,5 -2 Tage halten. Aber jeden Abend laden mhhhh habe erstmal Backup Gemach und teste mal eine andere Rom. Sieht aber danach aus das wieder zurückkomme
Freakii
Ok verstehe genau das Problem hatte ich dir Tage auch das mein Akku Extrem Leistungs Einbrüche aufeinmal hatte :eusa_snoo
Aber eigentlich sollte das laut Metallica wieder gefixt sein hmm...
Ja wiegesagt ich bin total begeisterter User vom All in One Black
Eien andere Rom zufinden ist für mich immoment fast unmöglich dar mich keine Rom so Richtig überzeugen/begeistern kann immoment :icon_mad:
RXBeat
Könnt ihr mir bitte bie was anderen helfen?
Ich finde die P.A.C Boot-Animation extrem hässlich :-/
Ich würde da sehr gerne die Originale S4 Bootanimation haben.
Wie kann ich vorgehen? Ist es überhaupt möglich ?
Mein Freund Google hilft mir auch nicht so wirklich weiter.
Freakii
Du findest die Hässlich ?:D
Ja ändern ist möglich einfach die PAC Boot Animation Deaktivieren Fertig schon hast du Normales Samsung Boot Animation zumindest wars bei Mir so ;)
Genaues Option Menü müsste ich es schauen dar ich immoment sie nicht drauf habe sry
