MetaIIica
chris264
Das wäre cool wenn das ginge, weil die Icons sehen so lieblos aus und das passt einfach nicht zur Rom. Lg
Sent from my GT-I9505 using Tapatalk 4
MetaIIica
Updates von 29.8.2013 -01.09.2013
Frameworks/base
SystemUI: CA translations
InputDevices: PT-BR update translations
InputDevices: DE translations
fix double-underscore derp
clean up double imports
Merge "core: SK translations" into cm-10.2
Merge "Core/InputDevices: EL translations" into cm-10.2
Merge "Base: SV translations" into cm-10.2
Bluetooth: Add trust device feature.
Remove possible leak when exception occurred.
JWR bits and pieces
JWR changes
Add BAMF theme engine
Ping on unlock changes
Bug Fixes
Fix MDPI Bluetooth statusbar icon
SystemUI: TabletUI - disable search light in lockscreen & fix systembar ...
FW - Restore Padding in NavBar Buttons.
Revert "JWR bits and pieces"
Quick Access Ribbon (Part 1 of 2)
Camera Tile : Close on flip/switch
SystemUI: Fix potential NPE Does already cause issues on some Halo ports to ...
Dynamic glowScale adjustment and spacing of NavBar.
User select Tablet Mode - NAVIGATION_BAR_WIDTH [2/2]
Merge "InputDevices: RU translation" into cm-10.2
Merge "Frameworks_base: PT-BR update translations" into cm-10.2
Merge "InputDevices: SK translations" into cm-10.2
fix pac alpha flicker
Add Power button to Pie (1/2)
Remove core/res/assets/images/android-logo-mask.png which was accidentally ...
Settings
PL translations
DE translations
sounds: add extra gain option
Category != Screen
RC - Allow User select Tablet Mode - NAVIGATION_BAR_WIDTH [1/2]
Quick Access Ribbon (Part 2 of 2)
Fixed force close issue when the window is shown without the ...
Fix FC in Settings / About / Status (Status.java) on Tablets.
ES translation
Fix: Blacklist menu buttons (add, prefs) were oddly squeezed when entering ...
Fixed FC issue and removes vibration settings if the ...
Add power button to Pie (2/2)
Show a preview of the selected font size immediately
Revert "Settings: Enable up navigation for Status and legal info"
Remove unneeded 'category_gamma_title'
Trebuchet
Live folder removeAll fix
AppsCustomizePagedView: Update tab from content type when not ...
RocketLauncher to Trebuchet.
System/core
init: define BOARD_CHARGING_CMDLINE parameters
Manifest
Add spongycastle android
Track AOKP vendor_tmobile which support BAMF theme engine android
PacPapers
Add new wallpapers
Added more wallpapers
Phone
PL translations
chris264
Hey,
Wurde in Toogles was geändert bzw gehen die normalen nicht. Sondern sind die gleichen.
Siehe Screenshots.
Lg
MetaIIica
Ja es wurde geändert, nennt sich Quick Access Ribbon. Die kannst in den PAC Settings aber individuell in Benachrichtigungsanzeige unter Quick Access Ribbon verändern oder abschalten und die alte Anzeige herstellen
Ich finde diese Funktion extrem cool
chris264
Ah dachte schon bin doof haha ok werde es testen. Lg
rXenon
@Metallica
Was mir aufgefallen ist das man nach dem flashen die Facebook Neu installieren muss da sonst Facebook nicht startet und im Black Screen hängenbleibt .
bearbeitet von rXenon
nguenal
Bei mir lässt sich Facebook auch nicht öffnen.
Hat jemand auch das Problem das beim Installieren von Apps, der Prozess Aktiv bleibt, Bild schwarz wird, aber er auf Homebildschirm springt. Man kann wieder zum Prozess zurück springen, Bild wieder Schwarz, dann springt er wieder auf Homebildschirm?
Navigon schliesst auch immer wieder obwohl der im Hintergrund läuft?
bearbeitet von nguenal
chris264
Also mit der Nightly vom 1.9 kann ich keine Themes installieren, geht sofort in den Bootloop und hilft nur Backup einspielen. Selbst mit sauberer Installation das gleiche. Lg
rXenon
Das mit Facebook hatte ich auch, wonach mit dem Browser '/System/app/' und dann die Facebook apk drüber installieren dann geht Facebook wieder
Dean36
Das facebookprob.: APP deinstallieren und dann im recovery wipe cache & Dalvik! Reboot und dann normal im playstore laden! Check
rXenon
Leider benutze ich navigon nicht. Habe es mit meinem Sygic Navigation getestet und habe damit keine Probleme. Hast du dein navigon Neu installiert oder ein Backup eingespielt?
nguenal
Navigon hat funktioniert. Hatte leider mit TB nur die ältere Version gesichert, wiederhergestellt und dann neue Version update gemacht. Bis jetzt alles top mit der ROM
MetaIIica
Neues Build und Updates von Heute
Frameworks/base
move custom string in cm_strings.xml file
QS: Unlock screen when tap profile tile
Use boost hints on dexopt
Zygoteinit: match preloading resources with AOSP 4.3
wifi: fixed to keep country code after boot
fix some frameworks cursor leaks
ProcessStats: Handle changes in the scaling frequnency
Nuke says to reconcile this
RECONCILE ALL THE THINGS
batteryservice: privatize a settings observer & only observe LED changes ...
Memory leak in IInputMethodSessionWrapper executeMessage
Selectively restore non-stupid parts of stuff we had before a patented ...
fix cursor leaks in F_B
activity manager tweak-a-roonie
potential GraphRunner leak in camera effects
Fix DataInputStream leaks
ActivityManager: memoize for performance
Low-end devices need help!
ShortCutBar support
SystemUI: Fix missing top task in recent panel.
Email
Add action buttons to new email notifications
Manifest
Track our own Dialer with PIB support
Update to the newest KT4 Kernel
Hoffe es löst einige Probleme.
nguenal
Mir gerade ein Bug aufgefallen. Wenn ich in App nutze, und ein Anruf kommt, merke ich erstmal nichts davon. Der Anrufer wird weg gedrückt und die Meldung "com.android.phone" meldung kommt
chris264
Hab auch ein Bug, ich kann keine Nummer wählen egal ob aus den Telefonbuch oder manuell eingegeben. Gleiche Fehlermeldung wie bei nguenal. Lg
nguenal
Habe gerade auch gestest chris264, man kann wählen, es klingelt auch, aber dann die Meldung ...
MetaIIica
Ja wir haben dies bemerkt. Ich werde gleich eine neue Version hochladen, dies fixt eine ganze Menge und das Problem mit dem Anruf wird auch gefixt
ich sag Bescheid wenn es oben ist
Schaltet PAC in Black ab, das löst das Problem bis dahin
rXenon
ich weis nicht ob der bug bekannt ist aber mir ist auf gefallen wenn ich in der anrufliste eine unbekannt nummer habe sie zu dem telefonbuch hinzufügen will wird die kontakt app geschlossen
