freedroid
Galaxy Nexus - Android 4.1.2 - Infos / Fragen / Probleme
freedroid
Google hat damit begonnen Android 4.1.2 (Build JZO54K) zu verteilen.
Das Update beinhaltet kleinere Änderungen und Performanceverbesserungen.
Hier der komplette
Changelog:
JRO03R (4.1.1_r6) to JZO54K (4.1.2_r1) AOSP changelog
** Project : build
25454bc JZO54K
0d6a91e JZO54J
ba7bed7 JZO54I
b097af8 JZO54H
a5b7347 JZO54G
e859020 JZO54F
dbf1b57 JZO54E
f33d47b JZO54D
3c47c4e JZO54C
ef6f4f6 Add make_ext4fs to all builds
bdfc1bb JZO54B
0bd5415 JZO54
0e29ca9 JZO47
f508984 docs: combine all possible js files into one to reduce the number of requests Also make change to doc template and css to fix footer layout bug introduced by change 9edfa6db8c53ef9515aaeed734bea02c5d65e1e5
9edfa6d docs: move home.css into default.css to reduce number of requests
951f93e JZO40
0e71cee docs: make landing pages w/o image span the full page width
97adb79 JZO38
9332a45 docs: comment-out unused style (the png currently does not resolve)
393830e Improve print stylesheet for d.a.c.
2ccbd3f change "nolist" style to be simply remove bullets and indent; leave the rest alone.
4f587c5 JZO31
b505ca6 add script to create links on topic landing page for first doc that use the doc's title
e2b8f86 JZO26
54d2a9b add bottom-margin to div-based notes
91f6799 JZO24
06cb5c7 Set the min height and width for images in carousel, set height of tabs so the selected indicator aligns with horizontal rule
28437aa Add LOCAL_SOURCE_FILES_ALL_GENERATED support
b9ae92b docs: further specify design docs' list styles to fix uls appearing like ols
bdd2ce0 JZO18
7f527b3 docs: add check in hash-change callback to be sure we're only dealing with hash-tags that are search queries. bug: 6843654
55163c8 Doc change: add links to the More menu.
1d62fa8 docs: bring back min-height for nav-x for proper height of secondary tabs
c14ec30 JZO17
a214d84 docs: upgrades to search. Fix history navigation functionality. Faster ajax requery while typing. Ignore ENTER key when performing requery to avoid reload. Improve results reveal with minimum height for proper div.
220c344 docs: adjust spacing for collapsible sections (release notes)
2f16ba5 Android 4.1.2 version bump
b71a27b JZO11
40d7329 JZO10
ef1335e use default shell (mksh) in emulator
1b3db11 docs: fix search suggestions and other script bugs for offline docs
952f55e 4.1.1
** Project : cts
2022429 Test nfc driver owner permissions
442d4f7 change default log level to error
bc87868 change DUT speaker volume to 1000 to 8000
eba07af FileSystemPermissionTest: Add directories
3fc9165 add 4.1.2 to version list
8e5695e remove bluetooth ConnectionAccess tests
296f1d2 remove camera analyzer
e96a622 Load a web page prior to calling key events on it.
fb4046d Enforce that the image is visible prior to poking it.
8cbf69d Flakiness in the accessibility CTS tests.
51a36fa remove possible race condition
2b9c83b fix build 2
1ca0866 fix build
f442636 add cts_audio_quality.zip build
6eab462 add xml report
9d204c2 Increase timeouts in ReceiveUriActivity.
968abf1 Ignore case on network info name
513faea Improve error reporting for AppSecurityTests#testPermissionDiffCert
9b2befe FileSystemPermissionTest: Add /data/img
282188d remove sending menu key at the beginning
93d87ab fix synchronization
1c62431 Fix NPE in CTS test
e65e437 construct MediaRecorder in setup
c1f7785 Watch for explicit download IDs instead of count.
0a83759 Fix build error due to bad import
22847d0 fix android.text.format.cts.TimeTest#testSetToNow0
69489e8 Fix NPE. Ensure favicon behaves consistently with other tests.
e6bbb62 FileSystemPermissionTest: Add /data/preinstall_md5
c323c37 send Home key after each package
c89984a trial to fix long click tests
8875398 refactor MediaPlayerTest
bf7d35f Fixing some flakiness in the CTS accessibility tests.
a8e4d0e Give a size for image so test doesn't have to wait for the load.
2c152b1 Remove external storage enforcement test.
0f9d299 close file stuffs  before deleted in teardown
3b2bc1d DO NOT MERGE Fix assertion to use complete load check rather than one flag.
89332ad DO NOT MERGE Fix LocationManagerTest#testExitProximity
d51563b DO NOT MERGE CTS Holo: Enlarge the threshold from 1 to 2
7579fed Handle devices with no telephony. DO NOT MERGE
391e1b4 Use a longer test string DO NOT MERGE
68cef19 Skip MIFARE Ultralight test for an unsupported device DO NOT MERGE
** Project : development
d80ee02 Retroactively add EffectiveNavigation and TabCompat sample code.
020d4ab Establish the dependency on the uiautomator stubs.
611c676 Add uiautomator.jar to SDK package.
1815b80 docs: New redirect rule for all /downloads/... paths, pointing to https://commondatastorage.googleapis.com/androiddevelopers/ Using this redirect allows us to use a simple URL in our docs for downloads and allows us change the storage location of the download assets in the future (such as when we're on devsite).
826be7b remove all zip files for training class samples. They're now at frameworks/base/docs/downloads/
f4ac8bb docs: quotes in comments apparently crash the server
2a7c34a Update support lib to r10.
d0f75a5 docs: move all ZIP files for training classes here, originally from the html/shareables/ directory to save space on the developer site.
cdfe5cc docs: add redirect for l10n tutorial and fix a couple others
cfa5aac Update the SDK platform tools package to revision 14.
** Project : device/asus/grouper
505d795 bootloader: nakasi: subject bootloader version to 3.41. DO NOT MERGE
a671ea0 take 6c1dc2eaffd380710917ec8a61ebfb3da340aff5
7762423 Add "discard" mount option for data and cache partition.
919c351 grouper: update prebuilt kernel
f602547 grouper: update prebuilt kernel
bfc3d96 grouper: update prebuilt kernel
84182a7 update bootloader to 3.39
3da55e8 grouper: update prebuilt kernel DO NOT MERGE
5331ff8 grouper: update prebuilt kernel
43f3728 bootloader: nakasi: subject bootloader version to 3.38.
83b5813 New prebuilt kernel DO NOT MERGE
e56eff8 Move grouper specific vars into BoardConfig.
a057d5d Follow the established pattern for the vendor/ entry points.
0d7c8ea grouper: update prebuilt kernel
4176f49 auto-generated blob list
285cef9 grouper: Add libdumpstate.grouper
a309131 bootloader: nakasi: subject bootloader version to 3.37.
** Project : device/common
f76cc4b Update jb-dev blob-listing script.
** Project : device/moto/stingray
9659000 New tty2ttyd binary for JB line
39a523f LTE RIL binary update - LTEDC_U_07.23.00
** Project : device/moto/wingray
773bfed stingray: Kernel prebuilt
53438a8 stingray: kernel prebuilt
3e1f297 New prebuilt kernel:
243088a Stingray: kernel prebuilt
** Project : device/sample
bcd21a3 Change apns-full-conf.xml
a5c1fcb Fixup tethering APNs
de5e5b4 [maguro/crespo][sample] change apns-full-conf.xml
** Project : device/samsung/crespo
c181cc1 crespo: Kernel prebuilt (DO NOT MERGE)
6b570ce prebuilt kernel
ab3b3fa prebuilt kernel (fixes for panics: usb gadget, i2c)
fba603e Strip board-info.txt for AOSP
d92333f prebuilt kernel (DDK 1.8@2112805 version change)
c39e9c7 prebuilt kernel (GPU dump active PT)
a8605fa prebuilt kernel (GPU dump active PT, wifi fixes)
41b49ae Update board-info.txt
a1df5ad prebuilt kernel (GPU, flush CPU cache workaround)
** Project : device/samsung/crespo4g
eee4676 Strip board-info.txt for AOSP
8e6d798 Update board-info.txt
** Project : device/samsung/maguro
8194bb9 Strip board-info.txt for AOSP
708ac51 Update board-info.txt
** Project : device/samsung/toro
e6eb055 SMS isn't converted to MMS even after 7 segments of messages
1cc0286 Strip board-info.txt for AOSP
bd30a89 Update board-info.txt
** Project : device/samsung/tuna
d59ae3b tuna: Kernel prebuilt
5fa370b tuna: prebuilt kernel (USB audio use after free) -- DO NOT MERGE
6b6fdeb tuna: prebuilt kernel (HSMMC1 suspend fix)
b69d5d1 tuna: kernel prebuilt DO NOT MERGE
32c13ca tuna: kernel prebuilt
** Project : external/bouncycastle
806ca81 Fix cert blacklisting by public key
ffa4874 Added patch to the README and android.patches.
** Project : external/emma
77b9074 Backport from master.
** Project : external/openssl
9b4b062 Use OPENSSL_NO_HEARTBEATS for better wpa_supplicant interoperability
** Project : external/skia
1d6fa96 Reduce embolden effect. DO NOT MERGE
** Project : external/webkit
465864a DO NOT MERGE Null check
28c43cf DO NOT MERGE Fix memory leak
0e8bb60 Null check to fix crash
** Project : external/wpa_supplicant_6
617450f Use SSL_OP_NO_TLSv1_1 SSL_OP_NO_TLSv1_2 SSL_OP_NO_TICKET for better wpa_supplicant_6 interoperability
** Project : external/wpa_supplicant_8
e488da3 Fix 'restore STA reconnection behavior' cherry-pick
6b24b49 Restore STA reconnection behavior
27bf107 Use SSL_OP_NO_TLSv1_1 SSL_OP_NO_TLSv1_2 SSL_OP_NO_TICKET for better wpa_supplicant_8 interoperability
** Project : frameworks/base
4873a48 DO NOT MERGE - Full (local) restore security changes
199bc56 Show plmn in emergency call allowed mode.
a9d7d85 Get your own cursor Drawables, WebViewClassic!
de3debd Fix notification gestures.
40c6ae4 Single finger notification expansion.
2370126 DO NOT MERGE - Make WebView track focal points more accurately
9d9fe3d DO NOT MERGE - Delay starting scale gesture events until a touch slop threshold
77bf72a Revert "Update Back softkey icon Bug: 6020915"
c104d16 DO NOT MERGE GestureDetector - Mask action when checking POINTER_UP
21ee2ca DO NOT MERGE Remove dead code
8be03ac DO NOT MERGE - Use focal point for scrolling in GestureDetector
48c7c6c DO NOT MERGE - New implementation for ScaleGestureDetector
dba8a81 Fix CDMA decoding of multipart UTF-16 SMS messages.
c44ba47 Doc update: client javadoc fix for @value.
5a45dd9 Update TabCompat training sample code download.
b44b13a Empty DC's apnList when the DC is free.
962daf9 Update Back softkey icon Bug: 6020915
a18cfcc Doc change: Remove japanese localized index page.
bf3bf7c Fix system server restart
8631701 Allow enabled accessibility service to toggle tocuh exploration after an upgrade to JellyBean.
2d9063b docs: Add a few links and small edits to a couple layout guides
02d74a2 docs: fix markup bug; remove extra </div>
911711f revise info on Search button availability... behavior not guaranteed either bug: 6966922
d632b43 docs: change download URLs for design assets. These new URLs are dummies that are handled by a redirect rule for all /downloads/... paths, that points to https://commondatastorage.googleapis.com/androiddevelopers/ Using this redirect allows us to change the storage location of the download assets in the future.
5333400 show 3G icon for CDMA/1xRTT
183bf11 docs: misc bug fixes from external issues
0212363 Multiple design styleguide fixes -Changing extras to videos -new bullet item in swipeviews -new in 4.0 removal -Ui overview notification info -reppling typo fixed
438a0ef Do not eject internal ASECs when storage unmounted
cb0b2df fix misc doc bugs from external issues
0099d67 Fix typo in UsbManager javadoc.
607079d docs: SDK r20.0.3, Support Library r10 Release Notes plus some OCD cleanup to the ADT install steps
2f8cc17 cherrypick from ics-mr1 docs: source for nw app Change-Id: If50f407a0e56fa802fe9beedaa650e3a131872b2
ed12067 updated downloads for styleguide -new illustrator stencil
252d23d Revert "Group revert of the following commits for design docs:"
b111b57 docs: fix hdef variable
40eee61 docs: fix broken links and update sitemap text file
53b0fda misc doc bugs. Fix sdk samples path Fix method signature in fragment doc code snippet Fix typo in a11y javadoc  code snippet Fix markup error in brands page Fix markup error on content providers doc Fix typo on about>start page
41508f0 Fix a logging NPE problem
73b9c29 Notification panel on tablet does not handle back and home key events.
5baafab Doc change: add trademarks attribution.
a18e0b4 fix markup for gl pie
a65d0e7 Doc change: 4K -> 4kb
ec4ec27 cherrypick from master docs: Battery class C2DM -> GCM Change-Id: If5fe0034ae0bb72c321b591f84e79acbaf2e36f1
c950641 Group revert of the following commits for design docs:
dd983ad cherrypick from master docs: GCM changes Change-Id: Id5454e70455bae14ab4605021a6c1bcab0292ae9
613d0b1 Doc update: Misc minor GCM updates.
2b1584c new confirming page and updates to progress and iconography
0bd664d Add missing docs to notification style rebuilder functions.
45c159e dashboard update for 8/1
37eecc7 docs: Add Device Art Generator for Nexus devices to d.a.c/distribute.
f05e34a fix more broken links
353474c moving accessibility image to callouts
6a681af new extras section linking to design talks
f284d49 docs: fix broken links
d5a3fe7 docs: add downloads directory with initial set of current files. This directory is not included in the final docs output, but is merely here as a "master" source for the downloadable bits that we upload and serve from elsewhere, such as from Google Cloud Storage.
ae652cc Fix AccountManagerServiceTest
969c243 Initial commit of wireless connectivity/discovery class.
be13fa0 removing recents icon in tabs ss
5b1f037 Change KeyStore to use Modified UTF-8 to match NativeCrypto
1edd4ae help image updates
5ac5a32 new accessibility section
27855ac Doc change: fix title and API level reference.
6443ca4 actionbar and tabs image updates
bdd8d0f dialog example update
26ff662 Delay AccountManagerService initialization
8874ab0 help, notificaion page updates and typos -changed copy to remove instances of eg
515087d Explicitly set lib dir permissions during unlink
48c5eb0 DO NOT MERGE. Add package-name-prefix blacklist for location updates.
36e055b Doc change: fix typo.
4a9df8d No longer parceling FixedSizeRemoteViewsCaches
dd4ef49 Persistent 'emergency calls' banner in the notification panel.
cdd0c59 docs: add links to new Settings dev guide
bfd070c Use correct layout style for Theme.Holo.Light.
591ff97 Fixing cache pruning to avoid pruning those in the visible range
baecca6 Delete everything from the shareables/ directory to save space on dac. All of the training ZIPs are now located in development/samples/training/zips/ Added a readme file to explain this change toward using cloud storage instead.
bbb3f41 docs: add Settings dev guide; a few changes to javadocs
c5e128c fix broken links bug 6879771
a45746e Fix several cases of broken droiddoc syntax external issue 35214
9af376e Fix NPE on some phones at startup.
cb1aec3 Remove old unused DreamsDockLauncher.
335c3b6 Caching the FixedSizeRemoteViewsCaches across rotation
fe3b1cb misc doc bug fixes
4c359b7 docs: fix a bunch of links from javadocs to api guides and add some attributes to Spinner and Switch
375d72b docs: Added docs for lint tool. Change-Id: I06192262b56e0333bcfbcac223395788f7b0d072 Bug: 5942358
0ae2927 Fix 6804479: "Emergency calls only" in notification shade
e38a6c5 Initial commit of GCM lesson for Cloudsync class.
7b661fb Implement CMAS service category program results.
8e49278 Fix tethering APNs
0804b6d docs: specify that adt v20 or higher is required for class
82f9196 Fix 5608959: Make keyguard follow user setting for orientation
cb58e6b docs: ADT r20.0.2 Release Notes, bug fixes - reprise of reverted: Change-Id: I66cfcb46c5f8a4825f1a12640dacc3c2c42ff348
eb48884 typo fix
9f061e2 fix information about layout overrides bug: 6852515
39871b7 docs: update Building Your First App class to reflect changes to New Project setup in eclipse
eef8340 doc: fix for NDK r8b release notes
7e5cb84 Revert "docs: ADT r20.0.2 Release Notes, bug fixes"
67922bb docs: add new IO videos playlist and update blog posts to show N7 post and Tools 20
15c257e Fix detection of CDMA cell broadcast messages.
4d5f968 Fix issue #6860828 Non-root shell can't grant permissions
b235bf6 docs: remove link that points to empty page
a5a0687 Prevent crash in AppWidgetHost that can be triggered by an AppWidget
aeffc93 Don't send terminal response without cmd details.
04364be docs: ADT r20.0.2 Release Notes, bug fixes
ce470e1 copy and image updates to patterns and building blocks
b949d41 update Google IO announcement on homepage
095cd2e Fix aapt -G to properly support class attr in fragment.
eebabd6 Import translations. DO NOT MERGE
12a5475 docs: update hw accel attribute's default behavior and fix link to l10n tutorial
f4019af Improve test key names to reproduce public issue
ed930e5 Fix stuck status bars.
3409e72 Correctly pre-clip paths when recording display lists Bug #6836448 External bug: https://code.google.com/p/android/issues/detail?id=34946
cd940ef docs: Updating <uses-sdk> docs, bug fix: b/6836256
0e9a5a7 Doc change: add button link to developer console.
67e6e0e docs: SDK/ADT r20.0.1, NDK r8b, Platform 4.1.1 Release Notes
65bc1c2 docs: fix broken links
7d55136 Fix our interpretation of apn setting's bearer.
28a3897 docs: re-add download.jd file to support archived SDK downloads
7b38133 Import translations. DO NOT MERGE
d0e84d3 docs: Add link to action bar design pattern.
65363a8 docs: adjustments to correct text alignment
60c8f99 Doc update: GCM doc cleanup, continued.
e582746 Fixing issue where you couldn't set null RemoteViews for a widget
6b7b9b4 Import translations. DO NOT MERGE
7b756e6 Doc change: API diffs for 16.
77cfe91 Doc change: Fixes to IAB purchase state docs.
a07ea5d Fixed the problem where getEntityAndIncrementCursor would always return "0" for attendeeIdentity & attendeeIdNamespace instead of the actual string.
0a386ff Text shadow alpha handling incorrect DO NOT MERGE
3b1ca78 Import translations. DO NOT MERGE
bcf21e9 Properly switch MediaRouter to wired audio over a2dp.
0f8e402 Force invalidates on non-visible views. DO NOT MERGE
d792ef7 Import translations. DO NOT MERGE
23edefc Import translations. DO NOT MERGE
3458009 Handle keyguard visibility states separately. DO NOT MERGE
d2d6c09 docs: ADK 2012 IDE for Windows download link update, plus minor content fixes/updates
f333f5f Handle keyguard visibility states separately. DO NOT MERGE
2ba2815 Import translations. DO NOT MERGE
507c312 Doc change: New TTL error code.
514bdc3 Replace AndroidEmoji.ttf for UI optimization
25a916d Remove gradients from navbar glow highlights.
e60393a Remove the unnecssary intent call.
8e136f8 Fix for bug 6716343. Use correct offset for mPos reset. DO NOT MERGE
7cd6dcd Doc update: GCM doc cleanup.
9075248 Properly resize paletted bitmaps when adjusting for density
54a18ef Replace LruCache implementation for layoutlib. do not merge.
40a4ab1 Import translations. DO NOT MERGE
333c099 Changed to obtain a parcel in each notify() call in jni.
e469e74 docs: new sitemap text file
01e1b83 docs: add largeHeap attribute to app manifest doc external issue 33967
fd51698 docs: misc bugs from external tracker
099fd80 docs: add throws notice for isPlaying per external issue 33610
fd29e8a DOC CHANGE: AOSP33968 Typo
67970e8 DOC CHANGE: AOSP 33831 - Typo
88eee99 docs: fix urls on homepage for offline docs
68e6649 Preserve retryCount when retrying.
1157e1a When reconnecting disassociate dc and apnContext.
74d762a Fix bug in parsing attributes for MediaRouteButton
** Project : frameworks/support
b41a213 Add missing docs to notification style rebuilder functions.
** Project : frameworks/testing
f612e6a more tweaks to visibility of methods, variables
ddc1008 UI Automator public API cleanup
50f012f Allow "click" logging to appear in logcat
2045d7d resolved conflicts for merge of 9858df8b to jb-dev-plus-aosp
467cca7 Noticed some clicks are fired but going ignored during tests
d367349 add API to get screen size in dp, and a skeleton test
bc0f493 Generate api stubs for uiautomator library.
3d50587 Clean up of code comments and fixed UiSelector clone
** Project : libcore
0bcfe10 Tracking DSA Signature.verify behavioral change
5e1acf9 Tracking DSA Signature.verify behavioral change
1f9fe21 Increment OpenSSLKey EVP_PKEY reference when it is selected for use with SSL_use_PrivateKey
6012ba8 Add test for isPubkeyBlacklisted
f9ace73 Tests for the CertBlacklist.
281be77 Fix even more CipherTest flakiness due to implicit random IV values
02e0e9b Make ZipFileTest#testHugeZipFile faster, and reduce ZipFile memory usage.
f19b9c4 Address more CipherTest flakiness due to random IV values
d3298cd Fix URLConnectionTest#test_getAllowUserInteraction.
3ff7a80 Signature.verify should not throw if called twice
4f81a06 TLS + SNI + proxy => bug : the SNI at the TLS layer is the hostname of the proxy instead of the hostname in the URL
2ac3f4d Address flakiness of doFinal and unwrap CipherTests
** Project : packages/apps/Calendar
02fd982 Modify doScroll to move based on the average of the touch points
298f397 Import translations. DO NOT MERGE
08e839e Change loading background of widget items to match event background, so there is less flashing when rotating the screen.
e10180f Import translations. DO NOT MERGE
** Project : packages/apps/Camera
16687a1 Import translations. DO NOT MERGE
d97a4ef Fix the crash when choosing pick your video in effects recording.
a4d59d4 Import translations. DO NOT MERGE
** Project : packages/apps/CellBroadcastReceiver
d716ca0 Add message ID cache to detect duplicate broadcasts.
21f2b9a Implement CMAS service category program results.
eef14be Fix CellBroadcastReceiver to ignore duplicate broadcasts.
** Project : packages/apps/Contacts
2dd9917 Removing code to handle "call" action from QSB suggestion
** Project : packages/apps/Email
48f9758 Don't set DPM password expiration unless it has changed
** Project : packages/apps/Exchange
f9ee00f DO NOT MERGE Fix calendar availability
09dff53 DO NOT MERGE Fix EAS backoff behavior
** Project : packages/apps/Gallery
d734c20 Import translations. DO NOT MERGE
** Project : packages/apps/Gallery2
ae04537 Do not accept fling gesture after we changed from/to filmstrip mode.
** Project : packages/apps/Launcher2
2efda95 Fixing landscape delete drop target padding.
fa4086d Fixing issue where selected tab did not match AllApps page upon rotation.
8ed3752 Fix issue where widget resize frame overlaps widget (issue 6493388)
c93e5ae Binding AllApps synchronously. (Bug 6855061)
1462de3 Ensuring that restoreInstanceState is being called promptly for synchronously bound page
a13a2f2 Fixing issue where defered unbind was running after synchronous bind. (Bug 6858398, Bug 6863181)
36e6c5b Disabling synchronous binding when returning home from another app while orientation has changed. (Bug 6792288)
** Project : packages/apps/Mms
364d926 SMS isn't converted to MMS even after 7 segments of messages
e2955da Import translations. DO NOT MERGE
e9023ad Import translations. DO NOT MERGE
1e1be6f Widget returning view type count of 1, uses 2
** Project : packages/apps/Nfc
43f2263 Fix type of collision resolution record.
327d0e7 Implement connection handover LLCP service.
** Project : packages/apps/Phone
36255b7 Adding contextual "Voice Mail" text to in-call dialpad.
12c60e4 Using SystemVibrator in the cases other than Ringer.java
** Project : packages/apps/Settings
ba60a45 Import translations. DO NOT MERGE
c5acc13 Import translations. DO NOT MERGE
059b123 Import translations. DO NOT MERGE
3eee86b Import translations. DO NOT MERGE
ca511a8 Fix appwidget bind dialog
d7ae05d Import translations. DO NOT MERGE
723bdf1 Import translations. DO NOT MERGE
eaeb8b6 Import translations. DO NOT MERGE
4e53a0c Import translations. DO NOT MERGE
8442db2 Move Google-apps specific location settings to a Google package
c31f6b2 Import translations. DO NOT MERGE
5419954 Import translations. DO NOT MERGE
4635ec6 Strings for upcoming location settings changes.
13be546 Import translations. DO NOT MERGE
509cfa1 Import translations. DO NOT MERGE
35e404c Import translations. DO NOT MERGE
** Project : packages/apps/VideoEditor
0aa129b Use focal point for scrolling.
863925d Use a local copy of HorizontalScrolllView.
** Project : packages/inputmethods/LatinIME
c565eeb DO NOT MERGE: Clear cache of the user dictionary when a word is added
** Project : packages/providers/CalendarProvider
485a184 Fix event color query (which fixes the failing CTS test).
f98ed2e Fixed the problem where updating event colors would cause exceptions
** Project : packages/providers/ContactsProvider
ff91ec3 Tolerate crashes during re-aggregation.
084a9d5 Don't sort contacts supplied to global search app.
** Project : sdk
5afd994 DO NOT MERGE: moving uiautomatorviewer into sdk
** Project : system/core
5dc5bfe Mount/unmount filesystems before running e2fsck
55b763f Grant sdcard_r to ril-daemon.
** Project : system/vold
eacf7e0 Only cleanup ASECs in external storage DO NOT MERGE
425524d Unmount all asec apps before encrypting
Factory Image:
[TABLE=head]Modell|Factory Image
takju|JZO54K
yakju|JZO54K[/TABLE]
Fragen und Probleme könnt ihr hier posten.
bearbeitet von freedroid
daniela.win
das meinte ich nicht :winknkiss hätte mich wohl anders ausdrücken sollen. also auf normalen wege
freedroid
Das Update wird seit heute OTA für das GN verteilt.
Es sollte also nicht mehr lange dauern bis dein GN ein Update meldet.
Wenn man es gar nicht erwarten kann soll es helfen wenn man bei Google-Dienste-Framework die Daten und den Cache löscht. ;)
Ich persönlich halte das aber für einen Placebo. :icon_smil
Eron
Hab es OTA bekommen und wird gerade installiert :)
Wieso hältst du es denn für einen Placebo? :D
Beim Update auf Jelly Bean habe ich auch die Google-Dienste-Framework gelöscht und es hat funktioniert. Mein Bruder hatte es noch nicht auf seinem GN, hab es auch gemacht und hat auch funktioniert :)
Mit freundlichen Grüßen
Eron
daniela.win
bei mir ist es jetzt auch da mit dem löschen des framework
Eron
Android hat halt Gefühle und sucht sich auch manchmal aus, wen er mag und wen nicht, diese bekommen dann schneller oder langsamer Updates.. :huh:
flat1941
Bei mir funktioniert das nie...:madman:
Haste auch einen reboot nach dem Löschen gemacht?
Ich habe eben gelöscht und reboot. Jetzt lädt er 4.1.2 (15.1mb) runter:icon_bigg
salasar
musst paar mal löschen und probieren. bei mir hat es geklappt aber ka ob wegen dem löschen oder auf den normalen weg ^^
Tobey6789
Hallo Zusammen,
seit heute habe ich auch per OTA das neue Update für Android erhalten. Seit dem ist mir aufgefallen, dass in meiner Kalender-App alle Geburtstage doppelt angezeigt werden. Wenn ich mich jedoch am Rechner auf mein Google-Konto einlogge sind die Daten nur einmal verzeichnet und auch unter den Kontakten habe ich nur ein Datum aufgelistet.
Mir ist das zwar erst jetzt aufgefallen aber gab es das Problem eventuell schon vorher?
Falls ja, ist euch eine Lösung bekannt? ich schon mal versucht die Sync auszustellen, die Kalenderdaten zu löschen und die Sync dann wieder zu aktivieren. Dieses Prozedere hat jedoch auch keine Besserung gebracht.
Vielen Dank
freedroid
Na klar. Aber das ging bei mir trotzdem nie. Weder mit dem GN noch mit dem Nexus S.
Naja ist ja auch nicht so dramatisch. Mein privates GN flashe ich eh von Hand und das Arbeits-Nexus kann auch warten. :icon_mrgr
ThorSchwar
Könnte mir einer die SystemUI.apk aus dem Stock-Image (4.1.2) schicken? Beim Versuch die prozentuale Akku-Anzeige da wieder reinzubekommen habe ich was verbockt und sehe jetzt nur noch die Batterie-Anzeige, wenn das Gerät ladet, hüstel...
bearbeitet von ThorSchwar
zusätzliche Infos
Woguo
Hab ein problem mit dem Installieren des Updates. Habe heute das Update OTA bekommen und natürlich gleich installieren wollen. Beim rebooeten kam dann allerdings folgender Screen:
Allerdings ohne den Recovery mode Kram(hab bei google nur kein besseres bild gefunden). Halt nur die Android Figur mit dem roten Ausrufszeichen. Habe auch schon die Batterie rausgenommen und neu gebootet, Google Framework Services gelöscht, neu gestartet und wieder das Update runtergeladen und versucht zu installieren aber hat nicht geklappt.
Mein GNexus ist unlocked und gerootet falls das wichtig ist. Danke für die Hilfe schonmal.
/update: nachdem nun auch ein zweites Mal der Fehler kam udn ich den Akku kurz rausnehmen musste, kann ich jetzt gar nicht mehr updaten da ich kein OTA update mehr bekomme, selbst wenn ich erst den Cache von Google Framework Services lösche, dann force stop mache und reboote.
bearbeitet von Woguo
flatflo
Bei Unlock und Root funktioniert ein OTA Update i. d. R. nicht.
Gesendet von meinem Galaxy Nexus
