Stefan Gündhör
Stefan Gündhör
Hallo Leute,
als Abschluss meiner Arbeit für das Optimus 2X hab ich mich nochmal hingesetzt und für die GoodBye ROM eine würdige letzte Version geschaffen, inklusive AROMA Installer und RAMHACK (danke meines neuesten guestekrnL Kernels). :erledigt:
Viel Spaß damit!
Gueste2X "GoodBye" v2.0
... one ROM to please them all ...
based on the best parts of the official LG Gingerbread 2.3.4 Roms v20E & v20M & v20Q & v20S + parts from my CM7 Hybrid Revolution ROM
plus latest guestekrnL kernel which has been initially created for this ROM
Download ROM: https://d-h.st/ZeH
Download Themes: https://www.mediafire.com/?a00njo3oenvvw (don't flash themes directly after the ROM - boot once first)
Download Boot Animations: https://www.mediafire.com/?2my9bx4u57gey
The ROM might be
incompatible
with new Touch-CWM. If it doesn't boot, you should rather use the traditional standard CWM!!!
Personal remarks to release of v2.0:
I decided to revive my GoodBye ROM and make a new version (v2.0) one more time. There are already a couple of very good Stock ROMs out there like Django Manouche, so basically another one is not really necessary.
However, I hate unfinished work and the last version of this ROM was very unstable, so I finally decided to fix it and make it stable again.
I completely re-worked the GoodBye ROM with focus on maximum smoothness, performance while still being stable, hopefully providing good battery and being light-weight.
Many experiences in tweaking and similar stuff I made during the last year have been helpful in creating GoodBye v2.0.
v2.0 is how I personally want a ROM to be, which doesn't mean it will be perfect for everyone, but it should at least be a solid base for good user experience.
Requirements:
The BB/RIL interaction parts of this ROM are from v20M. So use whatever Baseband worked best for you when you were using v20L/M in past. The included RIL (v20C / 0313) might
NOT
be a good choice for good power consumption. Please try yourself which BB + RIL works best. I remember v20J RIL to be good, I believe in combination with v20L Italy BB.
Edit: another good combo seems to be: v20C BB + 0725 v20i RIL
ROM Details:
  • this ROM is a hybrid out of various official LG Stock ROMs and my CM7 hybrid ROM
  • Cyanogenmod APN List
  • light-weight ROM, crap removed
  • Aroma installer with optional full wipe if selected
  • choose between 7 of the latest guestekrnL kernel versions (v2.1, not even officially released yet :cool: ) during installation (if you select the community release Flixedition-Power please be aware that per its default settings it makes nearly permanent use of second core when phone is in use which means higher battery drain. If you don't need that you should stick to the official releases. Currently there are no more differences other than different default settings for GuesteOC app between guestekrnL FlixEdition v2.1 and normal guestekrnL v2.1 - flix123Chain, because some good settings wanted by flix123 have been merged in the official releases as well. Thanks to flix123 for his endless efforts and help in making the guestekrnL kernel always smoother!)
  • Reboot Option in Shutdown Menu
  • incl. latest fabulous GuesteOC tweaking app by TrymHansen
  • removed unnecessary apps
  • Torch app from CM7
  • deodexed
  • ext4 file system (auto conversion)
  • highly optimized for performance
  • zipaligned
  • incredibly fast and stable
  • various themes and boot animations available for download
  • rootet
  • additional Gingerbread keyboard
  • LG UI Home 2 Launcher, modded by me (removed SNS crap)
  • selected tweaks
  • non-increasing ringtone
  • OnScreenPhone removed from settings (credits and thx to Flix123 !)
  • Fast Dormancy Log Spamming Fix and there will also be CMW packages for complete FD deactivation (the ones of 2.2 are compatible but currently down)
  • Scrolling Cache disabled for smoother scrolling
  • modified hosts file for blocking spam
  • init.d functionality
  • current busybox preinstalled
  • silent Start / Shutdown (the silent MP3s are from DjangoManouce - thanks to carburano!)
  • no fast dormancy log spamming
  • much much more ...
ROM Installation
  • Open the ROM in CWM, install via AROMA installer (please consider full-wipe if you come from a different ROM, highly recommended)
  • Boot
  • Shutdown & boot again (because market starts working after second boot)
  • Enjoy :cowboy:
"I remember v20J RIL to be good, I believe in combination with v20L Italy BB"...Stefan.
I think this is going to work for me. I tried my usual v20c BB first and with the v20c ril I had bad signal and gps and I remember from previous goodbye rom that v20m BB is bad for me.
But the 20j/20l combo seems to be ok so far.
The rom and kernel is excellent, smooth, snappy, good idle battery life (6hrs on 100%).
Hi thanks for the good feedback
I found another good BB/RIL combo which is working for me with stable signal and low battery drain:
v20C BB + 0725 v20i RIL (i not j)
So we already know two good working combos for this ROM:
- v20L BB + v20J RIL
- v20C BB + v20i RIL
:good:
can you compare this Goodbye v2.0 ( 2.3.4) and Gueste2X hybrid rom 3.8 (2.3.7) + Symbiosis 1.3.1 ? Can you give me some feedback about it , because I want a stable rom and long battery , 2.3.7 is not good in battery but it is very fast .
Compared to some time ago it is now possible to use Stock ROMs without getting slow very soon and without the disadvantage of not being able to use RamHack. If I have to compare my two ROMs I would say they are equal in performance and stability and in some cases this one here might be better in power consumption. Because there are many people like me who just are not able to get good battery with CM7 no matter which BB/RIL they try.
Matteo Müller
Was los? Willst dich zurückziehen? Wäre echt schade :'(
SMStuff
Gibt's eine Möglichkeit, ein Widget für die Energiesteuerung, so wie es in Deiner Hybrid-Version der Fall ist, in die GoodBye zu integrieren?
Das Widget, das hier mitgeliefert wird, um Wlan, Bluetooth, etc. zu steuern, funktioniert bei mir nicht.
Thyrius
Hej, Stefan. Deine Abschiedsversion gefällt mir bisher ganz prima. Schnell, stockt nicht, alles bisher gut...
Werden Deine Aufgaben bei xda so viele, dass Du nimmer am ROM basteln kannst?
Bleibste uns wenigstens noch erhalten?
tyr75
hat jemand von euch die BB v20l, und die v20c ?
kann die bei basebands net finden.
alex1711
suche die Ril 0725 v20i.
Hab bereits mit der GetRIL app danach gesucht.
Dort finde ich eine leak, Swisscom version.
Bei der Installation kommt dann RIL und Baseband passen nicht zusammen.
Baseband ist 313 20c
bearbeitet von alex1711
Thyrius
Moin moin...
Jetzt, nach einigen Tagen mit dieser ROM, muss ich wirklich sagen: feines Teil... Gut gemacht, Stefan!!!
Kein einziges Problem bisher, Akkulaufzeit derzeit bei WLAN an, WhatsApp, Facebook, SMS, Tapatalk (3 Foren), DB-Navigator und IP-Rechner im ständigen Gebrauch um die 23 Std.
Bin wirklich beeindruckt, wenn man mal wieder von der NovaHD weggeht, auf "Schnickschnak" verzichtet, dann ist dieses Sytsem sicherlich ein prima Tip!!!
Danke Stefan!!!
sarpei
Geht das noch mit dem 0218er BB?
Gesendet von meinem Optimus 2X mit Tapatalk 2
tyr75
Alles supi bis auf ein problem.
wenn ich " mobile daten" aktiviere verbindet es nicht. erst wenn ich zwischen 2g/3g wechsle. das ist mir auch schon bei anderen stocks aufgefallen.
ich komm einfach net drauf an was das liegen könnte.
da brauch ich unbedingt rat oder tips wie ich das beheben kann. denn es nervt ständig in den einstellungen rumzupfuschen.
vielleicht hat jemand einen idee.
House.m.d
Die Rom läuft KLasse, aber die Datenverbindung geht bei mir auch nicht automatisch, muß immer in den Einstellungen umstellen.
Bin wieder zur Hybrid 3.8, Schade der Akku hielt bedeutend länger
Thyrius
Also ich habe diese Probs nicht. Habs extra nochmal versucht. WLAN, 2/3G, alles klappt. Umsachalten klappt. Alles ohne Probs. Akkulaufzeit etwa 23 Std. bin sehr zufrieden damit!!! Das ist auf jeden Fall mein Notfallsystem!!!
Thyrius
So, die Akku-Laufzeit muss ich nun mal korrigieren:
Mit WLAN, WhatsApp, Facebook, 2 oder 3 Kamera-Nutzungen und einigen Telefonaten komme ich jetzt auf sagenhafte 1d 7h 37m 48s. Jetzt Ladegerät angestellt, weil 15%.
Das ist mit Custom Rom die längste Zeit, die ich je hatte... Nochmals: danke Stefan !!!
Stefan Gündhör
Hallo Leute,
schön, dass es einige positive Feedbacks gab. Die beste Akkulaufzeit mit dieser ROM kann man mit BB v20L Italy 0725 erreichen in Kombination mit v20J (J nicht L) RIL.
Falls jemand eine bessere Kombi hat, bitte melden :)
(Übrigens ja, ich werd erst mal etwas Pause machen, wird nicht mehr sehr viel kommen für das O2X meinerseits in nächster Zeit)
Heute hab ich einen neuen Kernel veröffentlicht - guestekrnL v2.2: https://github.com/downloads/StefanGuendhoer/guestekrnL_for_stock_v1.6.2_upwards/guestekrnL-v2.2_ALL_versions_Aroma.zip - ein Upgrade wird empfohlen - wichtigste Neuerung: Dual-Vibrator: Die Vibrationsstufen (in GuesteOC) MIN - 2700 verwenden den schwächeren Phone-Vibrator, von >2700 - MAX wird der starke Vibrator verwendet. Der schwächere kommt einigen Usern "akkurater" vor, deshalb ist es gut, dass man nun die Wahl hat, welchen man verwenden möchte.
Und eins noch - wichtig: Update für den LG Stock Music Player (hat nicht mit der Steuerung im Lockscreen und der Dropdown-Leiste zusammengespielt):
Gueste2X_Goodbye2.0_FIX_Music_BUG.zip
Thyrius
Hallo Stefan, hallo Rest von Welt...
ich fahre mit 1035.21_20110824. V20m, sagt er...
Obwohl mit GetRil sagt, das passt nicht, hab ich prima Verbindung, ob Daten oder Telefon. Fast überall Empfang und wie gesagt, Akku über 30 Std.
Nun werde ich mir mal den Kernel zu Gemüte führen. und Stefan, kann ich die getrost aufziehen, ohne dass ich mich "verschlimmbessere"? :-)
bearbeitet von Thyrius
Thyrius
Boah, der erste Start dauert lange... mein lieber Mann... wollte schon Batterie liften, aber dann kam er... hehe
So, nu schauen wir mal, was das Kernelwechseln gebracht hat...
Feedback folgt... ;-)
Thyrius
So, wie angekündigt mein Feedback:
Ich bin nicht zufrieden. Es laggt, der Speicher ist ständig zu erbersten voll und die Verbindungsabbrüche mehren sich.
Ich habe meine App-Konstellation seit mindestens einem dreiviertel Jahr nicht verändert, d.h., ich habe den direkten Vergleich.
STEFAN: solltest Du zwischendurch mal Zeit haben, nimm Dich bitte dieses Problems nochmal an, vorausgesetzt, es macht im Hinblick auf "das Neue" noch Sinn...
Alles in Allem dennoch danke für Deine Arbeit!
Manu458
Hallo Leute,
Hi gibt es eine Anleitung zum installieren der ROM?
Und wie installiere ich die Updates (Neuer Kernel und das Music Fix)?
Danke Leute
Lg.
Voraussetzung zur Installation der ROM ist ClockworkMod.
Lade dir die ROM und kopiert diese auf die ext SD-Karte
Führe nun folgende Schritte hintereinander aus:
Starte dein Gerät im Recovery-Modus (VOLUME DOWN + POWER ON gedrückt halten bis erstes LG Logo verschwindet)
wähle => Backup and restore > Backup (Hiermit legst du eine Sicherung des System an)
wähle => install zip from sdcard
wähle => choose zip from sdcard
wähle => die gerade gespeicherte ROM aus
bestätige die Auswahl mit "***YES***" und die Installation über den AromaInstaller beginnt.
Starte dein Gerät, danach 1x neustarten. Play Store funktioniert erst nach dem 2. Start.
Am besten wäre ein Fullwipe (beim flashen im Aromainstaller wählbar), da solltest du deine Daten (Kontakte, Fotos etc) vorher sichern. Kernel und Update installierst du genau so.
