TecBoy
[ROM][P75xx][JB][4.2.1] CyanogenMod 10.1 Nightly
TecBoy
At pershoots request, here is the official nightly discussion thread. I will be updating this with information that I find and users posts that are helpful. REMEMBER: THIS IS A WORK IN PROGRESS SO ALWAYS READ THE THREE POST FOR UPDATED INFORMATION
CyanogenMod 10.1 is a free, community built distribution of Android 4.2 (Jelly Bean) which greatly extends the capabilities of your tablet.
New CM Wiki page! https://wiki.cyanogenmod.org/index.php?title=Main_Page
New CM Documention! https://wiki.cyanogenmod.org/index.php?title=Documentation
Usual CM disclaimers:
#include
 * Your warranty is now void.
 * I am not responsible for bricked devices, dead SD cards,
 * thermonuclear war, or you getting fired because the alarm app failed. Please
 * do some research if you have any concerns about features included in this ROM
 * before flashing it! YOU are choosing to make these modifications, and if
 * you point the finger at me for messing up your device, I will laugh at you.
Known Issues (copied from droidbasement):
-A random flicker (it’s faint and fast) can be observed occasionally/infrequently. If this becomes a nuisance to you, you can try to alleviate this by selecting ‘Disable HW overlays’ in Developer Settings. This does not survive a reboot (must be selected on every boot) and impacts swiping motion (it slows it down) in Trebuchet (the Launcher).
-P4*: A 720P recording, when played back, will have artifacts in the upper section of the image. Also when launching the recorded video for the first time, you will encounter a bit of a delay before it launches.
-P4*:If you use the standard GAPPS (from goo), the keyboard will close if typed on for 2 or 3 letters quickly in succession, if you use Google Search, Messaging and/or Gtalk (there could be more). This is a GAPPS library issue. Install a third party keyboard (Swiftkey 3 works ok) and switch to it. This does not affect Browser, System, etc (stock KB works fine there). The GAPPS from wingray don’t appear to exhibit this behavior from brief feedback (make sure your system is cleaned out using the latest recovery (format system), prior to installing the rom and gapps if you had the set from goo installed prior (it has also been reported that data needed to be wiped as well to rid of the residuals)): https://forum.xda-developers.com/showpost.php?p=35825009&postcount=3553
-Wallpaper will be down aligned on the lockscreen.
Things that need work from the community:
Samsung Keyboard Layout
Using stock Clock widget on lockscreen, number cut off (*UPDATE 01/01/13) Chronus is the new clock widget (+cal&weather) I don't have the number issue. (https://plus.google.com/+CyanogenMod/posts/47pNKXSkuG4)
Tell me more
CWM:
Make sure you have the latest (CWM 6.0.2.7)
Download from pershoot website and look for your Tab version:https://droidbasement.com/galaxy/roms/cm10.1/
Download recovery.tar.md5 and flash with ODIN or Mobile ODIN
Links for ODIN 1.85 : MediaFire
Links for Mobile ODIN by Chainfire Play Store and XDA
Bootloaders: Make sure you update your bootloaders to ICS. People who flashed an ICS custom ROM coming from HoneyComb (3.1) do not have the correct bootloaders.
Download Bootloaders from pershoot site: https://droidbasement.com/galaxy/roms/cm10.1/
Locate your variant and flash with ODIN. *NOTE: MOBILE ODIN DOES NOT FLASH BOOTLOADERS. ONLY ODIN WILL
Bootloader Flashing Instructions: (see image attached to post if unclear)
1) Open ODIN, all settings should be at default, if you change anything, hit reset or make it the same as image attached.
2) Select PDA slot and select the bootloader.tar file.
3) Flash
4) If unclear about the instructions, please ask!
Modems:
Download the recommended modem for your device at droidbasement:
Install instructions are in post #3
P4 Variants Downloads: (Please see READ ME in post #2 to avoid and confusions or headaches)
P7510 (Wifi Only)
https://get.cm/?device=p4wifi&type=nightly
Changelog: https://mobile.10.1.cmxlog.com/?device=p4wifi
P7500 (3G+Wifi) (You must be on the ICS modem for best results.)
https://get.cm/?device=p4&type=nightly
Changelog:https://mobile.10.1.cmxlog.com/?device=p4
SCH-I905 (Verizon) (You must be on stock ICS (and it’s modem) before flashing to this build, for LTE functionality)
https://get.cm/?device=p4vzw&type=nightly
Changelog:https://mobile.10.1.cmxlog.com/?device=p4vzw
SGH-T859 (T-Mobile)
https://get.cm/?device=p4tmo&type=nightly
Changelog:https://mobile.10.1.cmxlog.com/?device=p4tmo
gapps: (update 01/21/2013)
P75xx gapps: gapps-jb-20130121-P75xx.zip https://www.mediafire.com/?l76hi3yf2sp1xkr Credit to dreamcwli from his thread on Xoom My Android ROM 4.2.1 for original package (Please thank him for the gapps)
Known Issues if using Goo Inside gapps or other gapp packages:
-Hot word detection for Google Now (caused the Google Now crash when starting)
-Gesture typing (causes random crashes when enabled)
-Photosphere (crashing when selecting camera or after aligning shot)
These features are removed in P75xx gapps.
Removed any Google Apps (e.g. Play Music, Sound Search, Calendar) that can be downloaded in Play Store: https://play.google.com/store/search?q=Google+Inc.&c=apps
Credits:
pershoot for his hard work
Cyanogen for his amazing ROM
CyanogenMOD Team for their awesome work
Follow CyanogenMOD Team:
Google+
Twitter
Quelle --> XDA
TecBoy
READ ME:
# CM 10.1 is based on Android 4.2.1. Any and all proprietary applications that you have installed outside of CM should be updated to their 4.2.1 counterparts. Do not use the 4.1 versions of proprietary applications, else you will experience difficulties.
# Do not use the CyanogenMod Updater to go from 10.0 to 10.1. While you will have a functional rom, due to the 1st bullet point, you will be left without your proprietary applications and their data. We highly suggest performing the initial install manually via recovery (flashing CM and your addons). Once you are on 10.1, you can use the CM Updater as per normal.
# You do not need to wipe when updating to 10.1 if coming from an earlier CM version. However, as we mentioned in the weekend's PSA, users updating (instead of wiping) will experience a conflict in the application data for the Clock app. You are advised to clear this apps data on first boot of 10.1.
# Another item to note is that the support for the 10.0 feature that allowed for an expanded number of targets on the pattern lockscreen is not in 10.1. If you use this lockscreen, disable it before updating from 10.0.
# Finally, we always advise that you create a backup before any update. Do note, however, that due to Android 4.2 changes to support multi-user mode, your backups will automatically be transferred to /sdcard/0/[backup folder]. Remember this when attempting to restore 10.0. Credit to post from CyanogenMOD team (G+ https://plus.google.com/+CyanogenMod/posts/9X561GFMxL5)
Coming from Samsung ICS ROM (custom or not) requires a FULL WIPE (Wipe Data, Cache, and Dalvik Cache) If you do not WIPE you will get a bootloop.
From droidbasement:
GT-P7500 (p4), GT-P7510 (p4wifi), SCH-I905 (p4vzw) and SGH-T859 (p4tmo)
-For P4VZW: You must be on stock ICS (and it’s modem) before flashing to this build, for LTE functionality
-For P4WIFI UK: You must be on the US ICS bootloader (odin .tar.md5 inside the .zip in the folder), otherwise you may incur a rolling screen
-For P4: You must be on the UK ICS bootloader (odin .tar.md5 from AUS inside the folder), otherwise you may incur a rolling screen.
-For P4*: You must be on the ICS modem for best results.
BEFORE REPORTING ANY BUGS, PLEASE DO A FULL WIPE AND FLASH AGAIN TO VERIFY THE BUG! ALSO, NOTHING WILL GET FIXED WITHOUT A LOGCAT (we cannot debug xda posts, need a logcat)
Getting a logcat:
1) Make sure ADB is installed (https://developer.android.com/sdk/index.html)
2) Open Command Prompt
3) adb logcat -d > logcat.txt
4) Locate the logcat and upload to xda
Quelle --> XDA
TecBoy
Install Instructions: IMPORTANT TO SEE READ ME IN POST #2 It will save you a lot of headaches when upgrading or updating your Tablet.
1) Install the latest CWM (see 1st post for more info)
2) Install ICS bootloaders (1st post) *People who flashed an ICS custom ROM coming from HoneyComb (3.1) do not have the correct bootloaders.
3) Boot into CWM and flash CM10.1 (Please see READ ME in post #2 for more information)
4) Flash gapps-jb-20130120-P75xx.zip (see 1st post for download)
5) Reboot
pershoot has stated before: "best to wipe as some experience lag with multi user." and "if you get any latency/ bizarro behavior, wipe"
F.A.Q
Want Adobe Flash on your Jellybean Tab? (update 01/13/13) New version is (11.1.115.36)
Check out the latest download here: https://helpx.adobe.com/flash-player/kb/archived-flash-player-versions.html Scroll to Flash Player for Android 4.0 archives and download most current (11.1.115.36). *Note: Flash is not supported in Jelly Bean, no support given in this thread as well.
Need Developer options and Performance tabs?
Go to settings>About tablet and start tapping Build number until it says your a Dev.
I am getting sudden reboots or freezes?
Not all tablets are created equal, if you are experiencing sudden reboots after Overclocking, reset your options back to default.
I am still rebooting or freezing? :(
Do a full wipe and DO NOT install anything. If the tablet is not rebooting or freezing, install your apps one at a time to isolate the cause. If you are using Titanium Backup, DO NOT RESTORE DATA FOR SYSTEM APPS.
I get Force Closes (FC) when I launch ____ app?
Try clearing data for the application by going Settings>Apps and locate the app and select Clear Data.
How can I increase Launcher performance?
Enable wallpaper hack (Settings> Launcher>Homescreen) and select Wallpaper quick render to boost home UI response (when using a static wallpaper).
Once I am on CM10.1, do I need to continue getting my updates at get.cm?
No, you can update future nightly builds by going to Settings>About tablet>CyanogenMod updates. Once there, change Update types to "New Versions (incl. Nightlies)" *NOTE: Pay attention to the file name, you might occasionally see CM 9 or 10 in the list, DO NOT FLASH!
Can I enable Voice Calling on my tablet?
At this time, the framework has the hook enabled to allow for users to work on the feature. IT IS 100% UNSUPPORTED at this time because it requires you to flash modems which is a deviation from the recommended setup.
I flashed ___ from another___ thread, now ___ this stopped working?
Wipe data and flash CM 10.1 from get.cm, does this issue still happen? If so, post logcat... if not, seek support from the thread you flashed the file from.
I HATE the new layout with the navigation keys in the middle, can I move it?
At this time, the nav keys in the middle is the design. Who knows, CM Team might change this in future builds.
OH NO! Where did my previous CWM backup go? (update 01/02/13)
4.2. changed the file structure on how internal storage is viewed. Data on the internal/fake sdcard will go to 0/ (i.e. /sdcard/0/; /data/media/0/) (both are the same thing).
Since the internal storage is emulated, it is setup now (using file explorer like ES) /mnt/shell/emulated then you will see /0/; /legacy/; /obb/; and /clockworkmod/. Copy clockwordmod folder to your PC and if you need to, flash back to old ROM with old CWM and then move the backup back to /sdcard and then restore.
Using the latest recovery, to find /sdcard while in recovery, you will need to adb to /data/media/. *Note: Make sure to have a copy on your PC, I ran out of space before restoring since it is all in the /data.
Hey! Did you see the easter eggs!! (update 01/02/13)
So not only is there an easter egg when you press the Android version and long press on the jellybean, but if you hit CyanogenMod version, CM planted one too. But did you know that by doing the easter egg and long pressing on the jellybean, you unlock another one! Go to Daydreams under Display in settings and you will see BeanFlinger!
My sound is really low or really high when I am using headphones! (update 01/03/13)
If you are having really low or high volumes while listening with headphones, I recommend Voodoo Sound from Supercurio in the Play Store (Link). This allows you to take control of your volume and change it to your preferences.
Quelle --> XDA
TecBoy
So, ich habe mir gedacht ich hole mal diese Diskussion bzw diese ROM in unser Forum. Ich selbst habe noch alles auf Stock aber bin am überlegen auf diese Version umzusteigen. Vielleicht hat ja von euch schon einer Erfahrung/en gesammelt mit der ROM.
auf meinem P7501 (p4) läuft CM 10.1 ohne Probleme
bearbeitet von TecBoy
andreas02
TecBoy
Willkommen im Samsung Galaxy Note 10.1 Forum.
Ich denke, dass dein Thread an der falschen Stelle gelandet ist.
Ich werde ihn mal dem richtigen Bereich zuordnen.
:dankescho für deinen JOB.
Andreas
TecBoy
Oh ja, jetzt wo du es sagst.
Da habe ich mich wohl etwas verirrt :icon_bigg
Danke !
andreas02
Hättest es wohl gerne...gibs zu :icon_bigg
Quasi ein "Freudscher Verschreiber" :wave:
Andreas
alexkno
Ich nutze es seit Mitte Dezember und bin sehr zufrieden...schon allein wegen Multi user Support.
Ist relativ zügig und sehr stabil. Und das obwohl wir noch in nightly Status sind. :thumbup:
sent via Tapatalk
TecBoy
Aha, das hört sich ja mal ganz gut an.
Was war der Grund für dich um von der offiziellen ICS weg zu gehen ?
alexkno
Hauptsächlich, die Multi user Funktionalität. Da ich die Samsung apps auch nicht nutze ist es für mich wichtiger ein schlankes schnelles Rom zu nutzen. Hatte auch vor Stock ics mal aokp drauf, aber Kamera etc liefen nicht. Stock ics ist ganz nett und mit switchme ging auch Multi user, aber in 4.2 ist das schneller.
Da der Akku auch ok läuft, denke ich dass ich bis zu einer Samsung Version von 4.2, falls es je eine gibt auf cm10.1 bleibe
sent via Tapatalk
TecBoy
Also ich denke nicht das Samsung da jemals wieder ein Update bringt für unser 10.1 (N)
OK, ich denke ich werde auch mit meinem TAB auf CyanogenMod 10.1 wechseln.
alexkno
Und unbedingt das recovery aus dem Post nutzen. Durch das neue Dateisystem hast du sonst Probleme ;)
sent via Tapatalk
zebra971
Habe per Update jetzt die 4.2.1 Version auf meinem Tab installiert.
Jetzt fehlt auf einmal unten am Bildschirm der Kreis mit den 6 Punkten, das Symbol womit ich auf
alle meine ich installierten Apps zugreifen kann. (Wie heißt dieses Symbol eigentlich?)
Hat jemand eine Idee, wie es wieder "auftaucht"?
Gruß Zebra
Gesendet von meinem GT-P7500 mit Tapatalk 2
alexkno
Kommt drauf an wrlchen launcher du nutzt
Einfach wieder einen Link zum app drawer herstellen
sent via Tapatalk
ox_eye
Also ich habe mir jetzt auch mal diese ROM installiert und kann sie jedem 10.1 Besitzer nur ans Herz legen.
Man ist auf 4.2.1, es läuft total flüssig , der Akku hält ganz normal im deep Sleep und es gibt unzählige Einstellungsmöglichkeiten.
GSteven
Ich hab zwar schon 4.0.4 drauf, will jetzt aber unbedingt jelly bean haben. Wenn ich den cm drauf mache, geht bestimmt alles verloren oder? Also Einstellungen, Apps usw?
sli2k
Habe auch die 4.0.4 (incl. Voice Enabled) drauf und wollte zu dieser offenbar sehr guten Version (4.1.2) springen.
Streng nach Anleitung (Gerät aufgeladen, Gerootet, CWM 5523)
habe ich dann über das Recovery-Menu (Power+Laut ging bei mir gar nicht! Power+Leise kam aber ins DL-Menu, also habe ich vom Desktop über CWM-App in den Recovery-Modus gebootet.
Dort alle Lösch-Manöver (Factory+Cache+Dalvik),
dann über Install Zip via SD die CM-10.1.2(P4) mal vom 29.12.12, mal vom 17.01.13. Beide brechen mit Error 7 ab!?!:redface:
Ich habe zwar die 3G-Varinante 10.1N, also P7501 statt P7500, aber wenn ich das richtig gelesen habe, ist das zwar der Auslöser für den Error 7, aber nur wenn man Dalvik nicht gelöscht hat...
Hat einer noch eine Idee oder gar Lösung für mich?
Dachte schon Bootloop oder Brick lässt grüßen, aber alles blieb 4.0.4 und nur die Grundinstallation musste nachgeholt werden. Puuh. Kein schönes Gefühl!
P.S. Falls es klappt, habe ich nie so ganz klar rauslesen können: Geht das Voice-Enabling auch wieder bei dieser Version? Bei 4.1.1 gab es ja IMHO eine Flash-Lösung.
DANKE!!
dgmx
Habe es auch installiert auf meinem P7500.
Läuft wirklich sehr gut und ist optisch ein Highlight.
sli2k
Irgendwie konnte ich das Tab nun doch überzeugen.
Es läuft!! Und gefällt mir ebenfalls sehr gut.
Was mich jetzt noch irritiert:
Vorher mit der 4.0.4 gingen SMS-Dienste schlecht bis gar nicht mehr später.
Hier geht´s.
Telefonie hingegen mit dem Extra-Flash (Voice-Enabling) funktionierte einwandfrei.
Bei dieser Version hier funktioniert das irgendwie nicht?!
Es sieht zwar aus wie immer (Ziffernfeld, Anrufliste etc.), man kann aber anscheinend nicht angerufen werden und ausgehende Anrufe verstummen und werden mit null Sekunden dargestellt.
Ich hatte das so verstanden, als ob aber in dieser Version per default die Funktion aktiv ist?!
Muss ich da noch etwas umstellen??
(Nein, ich habe nicht via Internet ohne eingetragenen Provider o.ä., sondern via Telefonie eingestellt ;) )
THX
dgmx
Der Akku nimmt aber viel schneller ab als unter 4.0 Stock
Schade....
